Forum » Pomoč in nasveti » IE in pomik po zgodovini brskanja
StratOS ::
Ker moram pri določenih aplikacijah uporabljati IE se mi pri brskanju po zgodovin predvsem nazaj (back) kdaj pa kdaj preskoči kar za več krat nazaj ( če razumete kaj mislim ).
Zanima me kako to spremeniti oz. popraviti. Uporabljam IE7B2 .
Tega problema pri Firefoxu nimam, rad bi pa rešil ta problem.
Vnaprej hvala.
Vnaprej hvala.
"Multitasking - ability to f##k up several things at once."
"It works better if you plug it in."
"The one who is digging the hole for the other to fall in is allready in it."
StratOS ::
Ah, problem že rešil, imel sem namreč prezafilan (150 MB) history buffer na disku in temp. int. datoteke.
Stvar zdaj deluje ok.
StratOS ::
Hja, no ne za vse :)
msnews.microsoft.com 4/7/2006 2:43 PM PST
This is a confirmed bug and will be fixed in the next beta release. See this
Channel 9 discussion:
http://channel9.msdn.com/ShowPost.aspx?...
As Bruce Morgan from Microsoft says:
" This is a confirmed bug; it generally happens with pages that use a meta
tag to change the charset, such as Google.
It was a regression caused by a fix to a different bug involving duplicate
travellog entries. Unfortunately, it was found after the fork for the MIX06
build. "
build. "
| » | The Irishman (2019)Oddelek: Sedem umetnosti | 5176 (3196) | Vazelin |
| » | Glibc bugOddelek: Informacijska varnost | 8671 (8042) | Icematxyz |
| » | eXeem - Decentraliziran BitTorrent (strani: 1 2 3 )Oddelek: Omrežja in internet | 22260 (13496) | OldSkul |
| » | Logitech MouseWare bug (?)Oddelek: Pomoč in nasveti | 2599 (2195) | Swiwer |
| » | WIN XP: RTM (strani: 1 2 3 4 )Oddelek: Programska oprema | 13594 (11337) | Tr0n |
