Forum » Programska oprema » O&O defrag načini
O&O defrag načini
slatibar ::
To je čisto uradno, upam, da boš razumel.
STEALTH Method
The STEALTH method differs from the other methods in that it is much faster and uses
much less central memory for the defragmentation.
The STEALTH method has been designed with large fileservers in mind. It can, however,
be used to great effect on workstations and other computers.
SPACE Method
The SPACE methods offer you a great solution if your volumes are very heavily fragmented. It also allows you
to consolidate your data so that the amount of contiguous free space is as large as possible and further
fragmentation is prevented.
The SPACE method is the best one for your initial defragmentation and for defragmentation in the background,
as long as there is enough free space on the hard disk and the number of files is not too great. Otherwise,
you should consider using the STEALTH method.
The COMPLETE/Access method defragments your files and reorganizes your file structure. Although this method
is slower than the STEALTH and SPACE methods, it guarantees maximum system performance when your files are being read.
The COMPLETE/Access method is suitable for servers and workstations. Please bear in mind that this method uses
a lot of central memory due to the reorganization of your system. If this is likely to be a serious problem for your system,
we recommend you use the STEALTH or SPACE methods.
COMPLETE/Access Method
The COMPLETE/Access method defragments your files and reorganizes your file structure. Although this method is
The COMPLETE/Access method is suitable for servers and workstations. Please bear in mind that this method uses a lot of
COMPLETE/Modified Method
The COMPLETE/Modified method defragments your files and also reorganized your file structure. Although this method
is slower that the STEALTH or SPACE methods, it guarantees maximum performance in the reading of your files.
The COMPLETE method is particularly suitable for databases and fileservers. It is important to bear in mind that
this method requires quite a lot of central memory due to the file reorganization. If this is a serious problem for
your system, we recommend you use the STEALTH or SPACE methods.
COMPLETE/Name Method
The COMPLETE/Name method defragments your files and also reorganizes your file structure. Although this method is slower
than the STEALTH and SPACE methods, it guarantees maximum performance for the read access to your system.
The COMPLETE/Name method is particularly suitable for system volumes. Please bear in mind that this method needs
a lot of central memory due to the reorganization process. If this is a serious problem for your system, we recommend
STEALTH Method
SPACE Method
| » | Ne morem dostopati do folderjaOddelek: Pomoč in nasveti | 867 (827) | medenko |
| » | problem v SolidWorks-uOddelek: Strojna oprema | 1405 (1119) | Isotropic |
| » | Kako v Win2k premakniti mapo Documents and Settings?Oddelek: Operacijski sistemi | 2545 (2511) | Mercier |
| » | Bios 8rda+Oddelek: Navijanje | 1352 (1250) | kuglvinkl |
| » | Fraktal - Le kakšno sporočilo vsebuje ???Oddelek: Zvok in slika | 1432 (1253) | Satanized |
