problem v SolidWorks-u
MiKo1982 ::
Pozdravljeni!
Imam problem z SolidWorks-om. Pri modeliranju parta se mi program sesuje in javi naslednjo napako.
Display driver NVIDIA Windows Kernel Mode Driver, Version 261.28 stopped responding and has succesfully recovered.
Karakteristike racunalnika:
- Intel Core i7, M640, 2,8GHz,
- RAM 4GB
- Windows 7, 64bit
- GeForce NVS 5100M, 1GB
- SolidWorks 10-11, studentska verzija
Iscem resitev za moj problem? Kje je problem? graficna, software, operacijski?
Lp, Miha
M-XXXX ::
Poskusi z drugimi gonilniki za grafično.
MiKo1982 ::
Sm tudi to probu in na zalost ne deluje...
matonson ::
Tele NVS grafične so bolj 2d usmerjene. Za solidworks je bolj primerna quadro 880m.
amigo_no1 ::
Prvo dokončno odstrani prejšnje driverje ( http://phyxion.net/item/driver-sweeper.... )
http://www.guru3d.com/category/driversw...
How to use ?
There are two methods to use Driver Sweeper.
Both methods achieve the same results. This method is always able to clean all files.
This method will delete remaining files upon reboot (if deleting failed). You can clean your drivers this way:
Use the official uninstaller(s) of the driver(s) you want to uninstall.
Reboot your PC in Safe Mode.
Run Driver Sweeper and select what to clean.
Analyse lists all the entries possible to remove, cleaning removes the entries selected.
More drivers can be selected for the same cleaning process.
Kot prvo: NVS serija ni nikoli dosedaj bila namenjena za 3d modeliranje, prej za Word in podobno.
http://www.nvidia.com/object/notebook-n...
Problem je v tem, ker ima to v laptopu.
SPECviewperf, zaženi in če naredi teste skozi gre za bug v SW
http://www.spec.org/gwpg/downloadindex....
WarpedGone ::
Nema veze čemu je kaj namenjeno, nima se kej sesipavat.
To je čisto navaden BUG. Kje točno je pa vprašanje za miljon dolarjev, če bi moral stavit bi stavil na drekaste drajverje za grafiko.
Zbogom in hvala za vse ribe
matonson ::
Ja no. Na nvs140m solidworks ni delal. Ta je sicer veliko boljša, ampak driver je pa gotovo enak. Jst bi se pozanimal, če je NVS 5100m sorodna kakšni quadro 3d kartici. Mislim, da je prav 880m, saj obe temljita na gt330m. Mogoče se da modificirati driver, da ti jo prepozna kot quadro 880 ali pa geforce gt330m.
Highlag ::
Pod performance odkljukaj use Software OpenGL.
McLuzo ::
Upam da bo znal kdo svetovat. Na sliki bi rad na mestu črtkane črte stvar zakrivil pa ne vem kako... Sem se igral z sheet metal, pa ni pravega učinka oz. ne razumem vedno kaj vse točno hoče funkcija imeti, da tam ustvari krivino.
 SW
SW
  • spremenilo: McLuzo ()
Isotropic ::
najprej naredis tisti del spodaj kvader z sheet metal, base flange
potem edge flange, pac das radij in dolzino pa je. lahko das tam se edit profile in takoj od zacetka naredis tisti krog zgoraj.
pa glej tutoriale najprej.
pa predlagam, da zacnes od zacetka (pri mojem prvem stavku)
Sesuvanje računalnika (NVIDIA)
101669 (1311) KTr1sk
štekanje
141900 (1717) toma168
display driver atikmdag stopped responding and has successfully recovered" error
51137 (1070) _nomis_
NiBiTor in nVidia Geforce go 7800 GTX
6975 (919) kiros
windows 7 driverji
Oddelek: Operacijski sistemi
82027 (1884) zzitop
