Ne morem dostopati do folderja
medenko ::
Nekaj sem se igral ponesreči z pravicami itd....zdaj pa ne morem samemu sebi kot adminu dati full control....je kakšna fora?
nekaj v tem smislu:
http://www.addictivetips.com/windows-ti...
Changing Permission
If you are an administrator and cannot access a folder, this is due to permission error. To give complete permission to yourself, right-click the file or folder and select Properties. Now go to Security tab, and hit the Edit button.
Here select your username(account) and check the Full Control checkbox. When done, hit OK. Note that when you will check the Full Control checkbox, all others will be automatically checked too.
Update: This method is not working for most users. Since many folders and files are locked, the only way to access them is to first unlock them using LockHunter.
medenko ::
 tole recimo mi javi...
a probam system restora na včerajšnji datum?
  • spremenilo: medenko ()
amigo_no1 ::
medenko ::
katero opcijo se priporoča...se lahko kaj zjebe? :D
amigo_no1 ::
Prvo.
Poglej kaj ukaz naredi.
  • spremenilo: amigo_no1 ()
medenko ::
Jaz sem v bistvu en account "ACCOUNT UKNOWN z dolgim nazivom" ponesreči odstranil/remove...zdaj ko sem hotel pa dodati mi pa ne dovoli, čeprav sem logiran kot admin na PC.
SMB povezava Winows 10 s Synology NAS
Oddelek: Operacijski sistemi
324351 (3617) dukedl
win srv 2003 - file sharing
192553 (1718) Eureka
Windows 7 Installer (64-bit) - težave
Oddelek: Programska oprema
153674 (3064) fr!Xy
Windows Server 2008 network sharing
192807 (2508) mazupan
win2k & paging fajli
291721 (1520) Mercier
