Forum » Programska oprema » Downgrade iz IE 7 na IE6
anddrej ::
Kako izvesti zadevo, glede na to, da tudi po "kao odstranitvi" IE7, sistem še zmeraj javi, da je nameščena novejša različica explorerja.
Andrej
- premaknilo iz Pomoč in nasveti: bastadu ()
kingkong ::
http://geekswithblogs.net/virgild/archi...
še to
''nevermind, i found a helpful post on dslreports.com, the uninstall
folder is in the windows folder, $NtUninstallie7beta1$\spuninst
of course the folder is hidden, but if you run the uninstaller you see
there, it says you must uninstall it from the user account that you
installed IE7 under. of course I only use my own account, so you have
to go into spuninst.inf and delete the line after Prerequisite. now
run the uninstaller and voila, even the more pesky IE7 Beta1 uninstall
problems are solved.''
upam, da bo kaj pomagalo...
še to
- spremenil: kingkong ()
| » | Internet explorer se ugasa - sam od sebe... HELP !Oddelek: Pomoč in nasveti | 2090 (1978) | jarni2 |
| » | Izšel je Internet Explorer 7.0 beta 3 (strani: 1 2 )Oddelek: Novice / Brskalniki | 12010 (10244) | [BISI] |
| » | Windows Vista preložen (strani: 1 2 3 )Oddelek: Novice / Operacijski sistemi | 17695 (12343) | Jst |
| » | Internet Explorer 7 beta 2 težaveOddelek: Programska oprema | 1521 (1299) | BendeR |
| » | Internet Explorer 7 Beta 1Oddelek: Novice / Brskalniki | 6544 (5227) | njok |
