zvok s tv kartice
zvok s tv kartice
Jan987 ::
Imam sistem v podpisu ter pa grafo all in woder 9800se ter pa tv kartico win fast 200/xp expert.
Problem je v tem, da sliko prikazujeta obe, zvoka pa noče nobena. Probal sem tudi ponovno naložiti os a je ostalo isto. Uporabljam xp-je. Zvok v vseh drugih aplikacijah deluje BP.
Kaj je narobe da zvok ne dela?
HerrFlick ::
Pa imaš inštalirani obe kartici naenkrat? Lahko, da se "tepeta" med seboj, če sta obe inštalirani. Poskusi samo z eno (a nima all-in-wonder že svoj tv tuner?).
Jan987 ::
ja sej zdej imam samo all in woder ker sem pač nabavil all in woder grafično tadruga pa ni inštalirana. Tud prej k je bla samo tv kartica niblo zvoka
HerrFlick ::
Si priklopil output z grafikulje na line-in od zvočne?
HerrFlick ::
Selecting the sound card
connector for TV audio input
The sound card connector determines which mixer slider is
controlled by the ATI Multimedia Center’s volume slider.
1 Click the Setup button in the TV Player control panel,
then click the Display tab.
2 Click the Initialization Wizard button, then click the Next
button twice.
3 In the Typical Audio Connections page, check I have
connected the cable to confirm that you have connected
your ALL-IN-WONDER card’s audio output cable to your
sound card’s Line-In connector.
4 Click Next to open the TV Sound Initialization Wizard.
5 Click the audio input that matches the connection between
your ALL-IN-WONDER card and your sound card.
(Line-In is the standard audio input when the
ALL-IN-WONDER card’s audio output cable is connected
to the sound card’s Line-In connector.) If you are not sure
how it is connected, click each source (CD Audio, Line-In,
etc.), and listen for the sound.
Jan987 ::
na grafični so samo video aut in video in ter da dvi in antena priključki.
A mi prosim lahko tist sestavek prevedeš v slo ker ne obvladam glih angleščine najbolj
Jan987 ::
res prosim da jmi kdo pomaha no
Zvok ob predvajanju filma
171308 (1158) iloveboobz
Soundbar ne igra
121985 (1835) eno_ime
Ne predvaja novega audio CD
52606 (2562) Tea Time
pohitritev dsl ali kabelskega neta v win xp
Oddelek: Omrežja in internet
62180 (1918) BlueRunner
Zvok z vecih cd-romov?
Oddelek: Zvok in slika
142562 (2333) Justy
