Forum » Pomoč in nasveti » Soundbar ne igra
Soundbar ne igra
eno_ime ::
Philips tv, philips soundbar.
Povezava HDMI.
Soundbar mode na hdmi act.
Tv, zvok , easylink on, auto easylink. Hdmi-1 se prikaze na meniju, in je tudi vklopljen.
Ko prizgem tv, napise, da se povezuje na glasbeni sistem, po nekem casu javi napako, ne morem se povezati, in preklopi na zvočnike od tv-ja.
Kje bi lahko bil problem?
Povezava HDMI.
dukedl ::
ker imamo kristalno kroglo, točno vemo kater model soundbara imaš... :)
je pa tle napisano, da ima sb HDMI OUT..in ne IN http://download.p4c.philips.com/files/h...
torej televizijo nanj priklopiš s kakšnim drugim prklopom
lp dukedl
dukedl ::
hmmm...pomoje more met tv tudi HDMI ARC
http://www.cnet.com/news/what-is-audio-...
In theory, ARC is supposed to let you have one connection between your TV and whatever you use to create sound: a receiver or a sound bar. You send video to the TV with an HDMI cable, and that same HDMI cable sends audio from the TV back down the same cable.
This is great for smart TVs, where the TV itself is creating the audio (via apps like Netflix and Pandora). Instead of suffering through a TV's terrible speakers, the audio gets sent to the receiver/sound bar for a massive improvement in sound quality.
Another way this is great is if you have multiple sources (Blu-ray, cable box, Roku), but only one input on your sound bar. With ARC, you can connect everything to the TV, and the TV will send audio down an HDMI cable to the sound bar. No extra cables needed (i.e. an optical cable).
lp dukedl
eno_ime ::
Imam Philips series pfl8600
Soundbar pa zanimivo dela na pfl7600 series.
8600 sem tudi ponastavil nastavitve na tovarniske, nadgradil firmware na zadnji, nic ne pomaga.
Sedaj mi se ostane povezava mimo HDMI.
Zadaj imam povezave:
1.Slusalke
2.Digital audio out
3.Vga-dvi-hdmi digital in
Kaksen kabel rabim , da povezem Philips Soundbar HTL3110B, verjetno bo to slo preko 2.Digital audio out?
Bi prosil za nasvet kakšnega, ko se spozna.
1.Slusalke
2.Digital audio out
dukedl ::
1.Slusalke
2.Digital audio out
čak, kerga maš? a to ni tale http://download.p4c.philips.com/files/h... ?
ker na strani 6, so narisani drugi vhodi
lp dukedl
eno_ime ::
Ja, to si dal , kateri so na soundbarju,
Jz sem napisal, kaj imam zadaj na Philips TV.
Torej kaksen kabel rabim?
dukedl ::
a sorry...torej Digital audio out iz tvja povežeš z sb..zdej al maš koaksialen izhod al pa optični na tvju (sb ima obe vrsti)?
lp dukedl
| » | Kateri soundbarOddelek: Kaj kupiti | 9630 (814) | Kalamarus |
| » | Kako povezati tv in soundbar,prosim pomočOddelek: Zvok in slika | 7998 (3453) | Škorc |
| » | Priklop 2.1 zvočnikov (jack) na novejši TV (brez jacka)Oddelek: Zvok in slika | 7222 (6904) | LooK |
| » | Zvok iz TV na hišni kinoOddelek: Zvok in slika | 4672 (3221) | billy |
| » | Zvok TV-ja skozi receiverOddelek: Zvok in slika | 3005 (2950) | icurk |
