Forum » Pomoč in nasveti » Zvok ob predvajanju filma
medosg ::
Pozdravljeni!
Ob predvajanju filma v kateremkoli programu (vlc, gom... ) je slišen zvok v ozadju in glasba, govor pa ne.
Morda ve kdo možen razlog?
Priklopljene imam logitech z 130 zvočnika.
Hvala v naprej in lp, seba
- polepsal: Mavrik ()
mahone ::
V Vlcju / Zvok poglej ce nimas Stereo nacin vklopljen ga vklopi. Sem imel isti problem s slusalkam
medosg ::
v VLC mi ne da možnosti vklopiti (stereo)- bled zapis v kaskadi.
Vmes, če dam popolnoma na glas zvočnike je malce slišati govor - vendar popačen.
Jst ::
Računalo (program) misli, da imaš center zvočnik priklopljen.
Tu je polno idej: http://www.techspot.com/community/topic...
pa še fizično malo potegni banaco ven in provaj eno točko ujet, če slučajno preklopi na pravilen zvok
stonarda said: ?
I had this issue before. If you go to your sounds driver settings, there si sometimes a karaoke mode, or a setting that removes speech. Switch it off and it should work!!
The most obvious way of fixing the problem is to completely uninstall the sound driver then reinstall them with the latest driver from your mobo manufacturer.
after fiddling with the Audio manager I found that choosing 'Speaker Out' instead of Headphones on the "connector retasking" (pop up when you plug them in) solved the problem.
I am running windows 8.1 so it might be a little bit different. Go to the sound manager and get to the "sound effects" page(the one with the option to turn karaoke on and off). In the bottom left hand corner there should be a small slider next to the larger slider for "main volume". Move the small slider all the way to the left and that should fix the problem
GOTO MIXER on the volume selection (Right Corner below beside time)
click on the mixer you will see system sounds ---> Click on them and you will see task bar
quickly go to playback tab --> double click on the speakers, you will see speaker properties with 4 tabs
goto Enhancements --> un tick the (Bloody) voice cancellation box....
Go to control panel, hardware and sound, sound, manage audio devices,
then you must highlight speakers - click on speakers, then click on properties,
then enhancements.
At this point as you scroll down there is an option of "voice cancellation." Make sure that is unchecked. Once I did that all the voices came back..
childofthetao said: ?
Your sound is most likely set to 5.1 and trying to play some sounds out of speakers you don't have. Change it to stereo 2.1, assuming you have two speakers.
This is quite a rational conclusion as well, as 5.1 sound uses phase differentiation to route vocals to the (presumed nonexistent), center channel
ce mu jutub dela, potem je problem drugje.
afaik so dvdji mel neke zascite,kjer je bil podoben scenarj kot ga opisuje op..
| » | Dober Singleplayer campain FPS špil?Oddelek: Igre | 5803 (4977) | Bor H |
| » | Ne predvaja novega audio CDOddelek: Pomoč in nasveti | 2618 (2574) | Tea Time |
| » | CATALYST 3.6Oddelek: Programska oprema | 9018 (8503) | freejack |
| » | Logitech MouseWare bug (?)Oddelek: Pomoč in nasveti | 2611 (2207) | Swiwer |
| » | A so te hi-fi komponente OK?Oddelek: Kaj kupiti | 2919 (2554) | Dami |
