Windows xp in samo 127 GB
Cranchi ::
Zivjo 15 min sem brskal po forumu z fuknkcijo isci in zal neuspesno, torej kupil sem nov disk in sicer seagate 160 GB ob formatiranju mi ga zazna nekaj cez 120 gb po namescenih windowsih pa 127 GB, mislim da je finta v SP2 imam ga sicer nalozenega pa vendar niso windowsi ze SP2 tako da jih nalozim naknadno, je kaksna varjanta da ta problem resim brez "dolvleke" novih windowsov ki imajo ze integriran service pack 2 ?
hvala lepa za hitre odgovore.
Goldee ::
Baje, da si lahk nalozis neke driverje za disk. Poglej na proizvajalcevi strani. Ponavadi pa SP2 resi ta problem.
Cranchi ::
sem bil ze dobre volje da bo pomagalo na proizvajalcevi strani sem nasel tole ter namestil ampak zadeva je po zagonu se vedno enaka:
Reg48bitLBA for Windows XP SP1 and Windows 2000 SP3
Windows XP Service Pack 1 and Windows 2000 Service Pack 3 operating systems, or higher, are required to support ATA disc drives larger than 137GB. The registry setting EnableBigLBA needs to be set after the proper level service pack is installed.
If you use the traditional Microsoft Disk Administrator or Disk Management tools to prepare your drive or you need to check the status of the EnableBigLBA registry setting, you can use the Ontrack Reg48bitLBA utility to set or confirm if the setting is enabled.
Goldee ::
Ej dej si raje SP2 namesti. Mislim, da bi potem moralo zaznat kot 160. Moj bratranec je imel isti problem. 160gb disk mu je zaznalo kot 137. Na novo je nalozil windowse, ter instaliral SP2.
SasoS ::
Poglej v diskmanagement če imaš unpartitioned space...
ricola78 ::
Kako pa imaš v bios-u nastavljeno? Al ima disk kakšne extra jumperje za nastavlat kapaciteto?
Cranchi ::
ni jumperjev in tudi neparticiranega prostora ne zazna..
sinko999 ::
>MORE INFORMATION
>> WARNING: If you use Registry Editor incorrectly, you may cause serious
problems that may require you to reinstall your operating system. Microsoft
cannot guarantee that you can solve problems that result from using Registry
Editor incorrectly. Use Registry Editor at your own risk.
>> Follow these steps:
>> Locate and then click the following key in the registry:
>> HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\atapi\parameters
>> On the Edit menu, point to New, and then click DWORD.
>> Type EnableBigLba, and then press ENTER.
>> On the Edit menu, click Modify.
>> Type 1, and then click OK.
Ni? ni ve?no !
flashek ::
lahko si z cdjem od win98 nardiš particijo v fdisko al pa če dobiš une winxp k majo že sp2 zraun.tisti ti prepoznajo cev disk
AMD Athlon 64 3000+ ; 2x512 MB ; Radeon X700 pro ; ASUS A8N-SLI Deluxe
smonito ::
Pozdravlejn!
JAz sem imel isto finto s svojim hitachijem 160Gb ter matično Gigabyte K8nf -9. Problem je v tem ce mas S ATA disk moras v biosu izklopit IDE ter ko prvič inštaliraš Win, moras dati gonilnike za sata disk. Meni je tudi prvo zaznalo okrog 124Gb ko sem pa izklopil IDe ter dal gonilnike na disketi za sata disk pa mi je zaznalo normalno 160Gb. To nima nobene povezave z SP2, ker tudi sam uporabljam SP2.
flashek ::
sej ni kdo rek da ma veze...
Cranchi ::
sem probal vse kar ste predlagali in nobena zadeva ne funkcionira..
se kaksna ideja ?
hvala
Cranchi ::
downloadal sem nove windowse z integriranim SP2 paketom in zadevo prepozna v celoti, hvala..
flashek ::
no vidiš;)
Cranchi ::
Ja hvala, hehe sej sem ze nekje prebral da je to resitev pa se mi je zdelo zamanj formatirat pa sem ocitno moral :D
težava z diskom
81512 (1329) nbicek
pomoč-disk
91299 (1245) mikkk
Nov 160GB vendar zazna samo 130GB (strani: 1 2 )
586082 (4908) Yamasaki450
trdi disk 160 G - javi da je 128 G
171671 (1480) K0K0
Disk 200GB je v winsih samo 128GB?
51537 (1421) danielka84
