Kaj vsi z dragimi RAMi pravite na te trditve?
2 3
Caligula ::
"You are missing a key factor in overclocking A64's. With the A64's onboard memory controller, when you are overclocking ram you are putting additional stress on the CPU. So when you overclock the CPU and the ram together you are putting maximum stress on the CPU. You will always be able to clock your CPU higher at a lower voltage when underclocking ram.
If your max CPU overclock is 2.7ghz with ram at 150mhz, you may only hit 2.6ghz with ram at 200mhz with the same voltage. You can shoot for something like 289x9=2601 with ram divider at 166 (235-236mhz) but you will have to give it 1.55-1.60v on the CPU and 2.9v on the ram.
The isolate and consolidate method was developed before the onboard mem controllers came along, and CPU and ram where totally independent. With A64's the consolidate portion becomes much more difficult and requires sacrificing some CPU and or ram speed.
But honestly high ramspeed doesn't provide nearly as much performance on A64's as high CPU speed. 2.7ghz with ram at 150mhz(DDR300) will probably provide more performance than 2.7ghz with ram at 235mhz(DDR470). Thats why most people experienced with overclocking A64's will tell you expensive overclocking ram is a waste of money on A64's. I sure wish I'd have known that before I bought my OCZ platinum rev2 "
In nasploh naj bi bila spominska prepustnost na A64 sistemih povsem nepomembna pri vsem razen pri benchih za prepustnost valjda.
pinx ::
saj vem da ne spada sem, ker je Socket 462, pa bom vseeno napisal :)
moji ramčki so se končno prebudili... Super Talent DIMM Kit 1024MB DDR400, ki sem dal za njih pred dvema mesecema 20 jurjev.
timingi so original na 2.5-3-3-8, jaz jih mam zdaj na 2.5-3-3-11 in so na moji NF2 plati dosegli 235MHz.
mislim da je to kr dober rezultat za NF2 nabor čipov?
Caligula ::
Jap, to je zelo dobro. Pol bi znal ta ram tudi na Nf3 ali 4 leteti kot hudic ampak zgleda,da to sploh ni potrebno ;)
  • spremenil: Caligula ()
pinx ::
če se kdo spomni, sem se pred časom pritoževal nad navijanjem teh ramov... :D
rame furam na 235MHz (2,5-3-3-11) @ 2,8V in me zanima v čem je catch, da se na timingih 3-3-3-11 par sekund po zagonu mašina restarta?
to je verjetno bil tud razlog za moje pritoževanje čez rame, saj mi je en predlagal naj nastavim timinge na 3-3-3-11 in na teh niso šli čez 215MHz pa da je bog.
ZiPi ::
jst spravim procesor na 2880mHz(320x9), rame pa tud na 320mHz(640mHz)@3-4-3-7@2,85V. Mam pa A64 3000+ Venice in Corsair TWINX1024-3200XL
MSI GX700
pinx ::
320? 8-O
Good Guy ::
ja če sešteješ oba modual skupi :\ >:D :D
http://goo.gl/7ItKpU
Naj računalnik dela za vas^^
igor0203 ::
če se ne motim majo Corsair TwinX 3200XL TCCD čipe in zato lahko tok letijo... ;)
ZiPi ::
320 na vsakem 640 skupaj.. so pa TCCD ja
MSI GX700
Jaffa ::
Moji tud grejo... Oz. so šli, dok nisem procesorja zakuro.
www.markosoft.si | www.markoshop.si
GRYPHON Z87|i7-4770k@4200MHz|16GB VENGEANCE 1866MHz
2x SAMSUNG 850PRO 256GB|GTX960|LIAN LI|BENQ BL3201PT 4K
Legoless ::
ZiPi, Jaffa, do koliko pa prideta z 2,5-3-3? Jaz sem z Corsairi 3200XL TCCD prišel do okoli 275, potem pa konec. Aja, a kdo ve če imajo ti Corsairi Brainpower PCB?
Jaffa ::
Do 290. 1T. 2,58V. Če sm dal več - no go.
ZiPi ::
jup 290mHz 2,5-3-3-7@2,85V. več nisem poskušal.
MSI GX700
Jaffa ::
Si poskusil z nižjo napetostjo ?
ZiPi ::
nisem. bom nekoč..:D sm dal kr na 2,85, ker jih je tud Corsair testiral na tej voltaži pr tej hitrosti..
MSI GX700
Jaffa ::
Jah, moji so tui na 2,8 testirani. Sam jim ni delat na tej voltaži. 8-)
Legoless ::
Torej boljše kot jaz.. Hmm, kaj vem, mogoče je bil proc krivec. Zato me mika, da bi skočil do kolega in si jih sposodil za nekaj benchev na Dothanu.. 270x10 recimo.. Seveda če bo procesor pri volji :)
Sparky69 ::
A bi se mogoče komu dalo stestirat, če izjave, ki jih je Caligula napisal, držijo? Saj bi sam, pa še nimam A64 proca.
World is my playground
eDDi ::
te izjave nikakor ne držijo in je razlika občutna med posameznimi rami. v winraru pomenijo zelo majhne spremembe nastavitev ramov, ogromne razlike v rezultatu. takisto v superpiju.
Primoz78 ::
Pa tudi v 3d marku je tko kot pravi eDDi in v igrah seveda...je pa res, da zategnjeni timingi in pa visok FSB ramov dodatno obremenjujejo procesor in zato rabi visjo voltazo za stabilno delovanje pri doloceni frekvenci pri kateri bi deloval na nizji voltazi ce bi imel relaxirane timinge...
Lp Primoz
GAMING HTPC I5 2500k/ASUS P8P67/4GB CORSAIR XMS3/
VERTEX 3/ASUS 670 GTX OC/Antec TP-650 NEW/
Sparky69 ::
Hvala za odgovore!
cbelica ::
Drzijo... za A64 je najpomembnejsa hitrost CPU-ja.
Ce pa to vrednost fiksiramo (2000MHz v mojem primeru, A64 3000+ s754), potem pa so razlike med zategnjenimi timingi nasproti hitrosti (MHz) RAM-a. Sem testital, in prisel do ugotovitve, da se bolj splaca 2-2-2-7 pri 200MHz kot pa 2.5-4-3-7 pri 250MHz; saj so rezultati zelo podobni, a pri 200MHz je potrebna nizja voltaza CPU-ja (ocitno je memory controller manj obremenjen).
98% of the teenage population does or has tried smoking pot.
If you're one of the 2% who hasn't, copy & paste this in your Signature
Jaffa ::
Sej to je blo nekje (se ne spomnim zdaj kje) testirano na ful proramih/igrah in je res. V praxi se hitrost rama ful malo pozna... Sam če overclockaš, pol pač gledaš na finese... 8-)
Caligula ::
Tudi RAR bo tekel hitreje na visjem CPU clocku dosezenem zaradi manj clockanega RAMa, sploh pa mu koristijo nizje latence, ki jih tam doseze ram.
Nasploh je popolnoma jasno, da ima recimo za igre veliko vecjo vrednost 1 giga rama za 20.000 SIT kot 512 MB rama za 30 in vec tisoc sit.
Kake poceni TCCD rame se se splaca kupovati, Bh cipi so pa res samo za folk, ki ima fetis RAM navijat just for the hell of it.
V koncni fazi ima lahko kdo s poceni rami, ki jih ima neclockane, hitrejsi sistem od nekoga s prakticno enako konfiguracijo z clockanimi, zaradi posledicno nizjega navitja CPUja.
Good Guy ::
"Nasploh je popolnoma jasno, da ima recimo za igre veliko vecjo vrednost 1 giga rama za 20.000 SIT kot 512 MB rama za 30 in vec tisoc sit."
ni nujno če ej recimo 1 giga noname rama ima verjetno velike latence medtem ko ap ma 512 dobrega rama latence nizke (1.5....) in mislem da se tut latence poznajo pri špilih čeprav je količina manjša
Jaffa ::
Ko ti bo igra požrla več rama, kot ga imaš, ti nobena latenca na svetu na bo pomagala. Simple as that.
Ko bo pa disk mel tako nizke dostopne čase in prepustnosti, pol bo pa druga stvar...
Good Guy ::
sej tega ne vem sam predvidevu sm
eDDi ::
jst ne vidim sploh smisla teh trditev.
zmeraj, beri zmeraj bo bolje, če bodo stvari tekle z višjo frekvenco. Absolutno je boljše razmerje proc/ram 2800/280 kot 2800/200, pa če ne vem kaj rečeš.
kot tretje, TCCD čipi so generalno DRAŽJI od bh5.
RC14 ::
Točno tako. 512MB rama je za današnje igre absolutno premalo.
Kdor veliko igra igre, je bolj pomembna hitrost procesorja in zadostna količina rama. Kaj ti pomaga super hitri ram ki dela na 2-2-2-5, če ga je samo 512Mb.
Tud nizke latence oz če imaš namesto 280 pač 250Mhz ram so razlike minimalne. Spet govorim za igre.
Za tiste ki jim je to hobi in jim je pomemben vsak Mhz bo pač kupil takšne rame.
Caligula ::
Eddi, ja pri istih frekvencah je seveda boljse, ce je RAM hitrejsi. Problem je, da navit ram zbija najvisji Mhz procesorja.
Ze ce se procesor navije za 100 Mhz vec, pa ceprav pri pocasnejsih ramih, se splaca, ker je cel sistem se vedno hitrejsi.
Pa cisto vsi RAMi, ki so zdaj na trgu, pri FSBjih okoli 200 na a64 sistemih dosegajo ful nizke latence.
Se moja jetra, k na NF2 tud priblizno niso mogla zivet pri nizkih timingih, na NF3 pri 200 mhz laufajo pri 1.5,2,2,2X
BH cipi so pa nadloga. A ni nadlezno ,da ti neki v kisti, kjer procesor rabi komaj kaj vec kot 1.5v ali kvecjemi 1.6v, nekaj rabi 3.5v za normalno delo?
Visoke voltaze pomenijo nizko ucinkovitost. TCCD so vsaj ucinkoviti bolj. Pa resnicno vsak ram lahko na A64 sistemih laufa na ful nizkih latencah pri FSBju 200. Sam folk niti proba ne.
Naj vsak proba dat RAM na 2,2,2,X pri 2.9 v pri 200 mhz. Cisto za stos. Govorim o vseh, ki nimajo BH cipov.
eDDi ::
žal bom moral spet proti tebi nastopit oz. proti tvojim trditvam.
primer mojega računalnika:
procesor gre max 2800 full stabilno, kar pomeni 311x9, če imam ram na dividerju 166, mi znese 254 frekvenca rama, pri tem uporabim timinge 2,5-3-3-4, pi rezultat 30s.
druga varianta je 1:1, in mi takrat gre max 308x9 na 2,5-4-4-7, kar je 30mhz manj na procu, ampak pi mi pa zračuna v 28s.
tak da boljši ramo so boljši.. tud winsi se hitrej naložijo...
Caligula ::
Sam malo si si tudi sam odgovoril. Poglej kako majhna je razlika v navitju, ce sploh nebi uporabil tako dragih ramov.
Pa pri nalaganju Windowsov je pri teh procesorjih ozko grlo disk in ne vec procesor.
Pi je sinteticni test.
V praksi bi bilo ob tvojem procesorju verjetno bolje meti 1 giga povprecnega poceni RAMa in tistih dodatnih 30 jurjev v boljsi graficni ali pac se malo hitrejsem procesorju.
Pa ti mas tudi vodno hlajenje, ki pac se dodatno zniza nestabilnost memory controllerja. Pri zracnem bi bila razlika se bolj ocitna.
Probaj pa se se malo igrat tako ,da das memory na 2:3 pa zategni timinge.
Je pa zanimivo, da ti Z LCjem 550 tako lepo laufa vse. Marsikdo tukaj bi ti verjetno hitro zacel teziti, da bi teh prisparanih 30 jurjev lahko vlozil v boljsi napajalec, ces da je ta zanic.
Kar nekaj takega folka je tu.
RC14 ::
te nizke latence in visoka frekvenca rama se dosti pozna v WinRaru. To je pa tud edini program ki je praktično uporaben in mi hitreje odpakira recimo kakšne XXX.:D Drugje pa so razlike zelo majhne.
Tud sam vidim da ni neke bistvene razlike v igrah če imam latence na 2.5-3-3-7 ali na 3-4-4-7 in tud ni neke razlike razlike če dela ram na recimo 230 al pa na 260Mhz. Tu so razlike max 2-3 FPS. Kdor igra veliko igre, je bolje da kupi en slabši ram (1GB) in tisto razliko v ceni to je recimo tud 30k doda k boljši grafični in bo imel dost več od mašine. To je recimo razlika 6600GT in 6800GT.
Za večina ljudi res, treba je dodatno hladit, visoke voltaže, eh za normalno uporabo, torej za igre, srfanje po netu ...brezveze. Spet pravim za tiste ki jim je pomemben vsak Mhz in vsaka sekunda v super PI in te stvari je stvar uredu. Za večina ljudi pa ne.
Tilen ::
Jaz sem zelo vesel uporabnik 1 GB TCCD RAMA (Apacer), ki sem ga dobil relativno poceni in mi deluje BP 215 @ 2 2 2 5 pri 2.8 in mi na kraj pameti ne pride da bi kupil zdaj ene rame za 30k+ da bi mel pol lahk nwem 250 2 2 2 5. Je pa res da dosti gram igre in bom ce bom se odlocil se za nakup ene ploscice bom kupil se 512 tega TCCD-ja kr so zame cist OK. :)
  • spremenil: Tilen ()
RC14 ::
Tilen: Pravilno razmišljaš. Boš imel več od tega.
Za tistih 30k+ , si še kupiš 512Mb rama pa še parkrat lahka greš na pivo.:D . Ali pa dodaš za boljšo grafo ane?
Tilen ::
Itak, sam o obljsi grafi ne razmisljam ker posedujem 6800GT zato si raje omislim se 512 tega TCCD-ja.
Caligula ::
Tilen govori, kot da bi imel nek slab ram :D
TCCDji so hudo dobri. Sploh pa optimalni za A64 sisteme.
Tilen ::
Caligula, ne trdim tega. Hocem povedat, da je TCCD zelo dobr ram za to ceno in ce se da dobit za 16-18K 512 TCCD-ja (Apacerjevega) me noben nebo preprical da nabavim za 30k+ neke nwem ... jake rame.
A64 sistema zal nimam, sem pa slisal da se z 3000+ Venice ne razumejo prevec. Lahk kdo potrdi?
Lex ::
http://forums.anandtech.com/messageview.aspx?catid=28&threadid=1475190&enterthread=y
tak mimgrede.. mislim da edina primerjava value in high-end ramov. Tak k je že en reku, boljši ram se pozna pri winraru pa namenskih testih. V praxi bolj malo.
Caligula ::
Tule povprasaj in se nasploh malo informiraj, ker je za DFIje tole najbolj aktualno. No ja, za overclockanje nasploh.
eDDi ::
zgleda da ne veste koliko pomeni ena cela sekunda, mogoče celo dve v piju in je bolje da tu debato nehamo, vsi ostali pa juhu na en poceni ram in naprej verjeti v miklavža, saj je to nepomebno. yeah right.
btw: v moji mašini so delali že Apacerji, Twinmosi, Geil Ultra Platinum, Geil UltraX, Atada Vitesta, Mushkin Redline in še kopica cenejših ramov in definitivno je razlika v prid boljšim ramov.
Apacer 512k stane 22k in je bolj kilav ram, v tem cenovnem razredu je bolje kupiti twinmos speed premium za 16k.
aja, glede mojega LCja, ki te zgleda moti. sem imel možnost probat še kkšen napajalnik, sicer še ne tiste v cenovnem razredu 30+, ampak v primerjavi z drugimi, je pa ta LC kar cool in z drugim ne pridobim niti 1Mhz navitja več. V trenutnku, ko si bom dokazal drugače, kupim nov napajalnik.
Caligula ::
eDDi, tudi sam imam enak napajalnik kot ti. Misljeno je bilo sarkasticno, ker folk vedno najeda, da ker je poceni je ziher slab. In to ponavadi samo taki, ki ga sami niso sprobali.
Kar se tice Pija. Jaz z njim v real lifu nic ne pocnem. Stiskam video, igram igre, surfam po netu,... in pri vsem tem je na A64 sistemih celo bolje imeti RAM na 133 in na nizkih timingih, ker je tako najhitrejse.
Pa ne bit uzaljen zdaj. Jaz samo misli, da forum ne sme bit nek prostor, kjer zato, ker nekateri imajo drag RAM, pol pac kar obvelja, da mora to vsak met, da potem Noobi stran denar mecejo za brezveze.
Ti si vsaj pri napajalcu pametno zadel. Predstavljaj si folk, ku kupi RAMe za 60 jurjev, napajalec za 40 in potem takega prepricaj, da ni vredno. Prej bo sel v grob kot, da bi se s tem sprijaznil.
Tilen ::
eDDi, oprosti ampak za 2 sekundi manj ne dam 20k več.
Glede raranja pa tudi, govoris kot da ti cel dan raraš in so ti te sekunde tako pomembne.
eDDi ::
jst sem pristaš tega da se mora vsak stvar probat in če je boljša, vsak presodi sam. sam nekateri se pač obnašajo tako da ko vidijo, da ima kdo kaj boljšega, grejo kar popljuvat ne da bi sami probali in na ta način sebe tolažijo, da ne rabijo denarja zapravljat. vsakemu svoje.
jst lahko grem nardit sedaj 10 debilnih testov v katerih bo 6800GT boljša za 10% od 6600GT in govorit da so vsi butli in debili ki imajo 6800GT. vendar vsakemu svoje.
tilen: vsi smo si različni, jest ti dam zdejle 40k, če mi pridelaš še dve skundi v piju.
Tilen ::
Nenene, nisi me raumel. Jaz nisem rekel, da je to slabo kar imas ti, pravim le, da me ni prepricalo.
RC14 ::
Tisti ki pač hočejo biti prvi na raznih lestvicah pač naj imajo najboljše stvari oz bolje rečeno jih morajo imeti. Je pač to njihov hobi in dajo skoraj vso svoje premoženje v rame, grafe itd. Eni pač dajo v avte, spojlerje, pijačo itd.. Vsak pač ma svoje veselje, js dam temu prav.
Ampak za večina ljudi so pa vrh glave dovolj eni apacerji ali tile twinmosi ki do dokaj poceni. No nek no name ram pa en hud procesor in plata res ne gresta skupaj. Tudi sam sem kupil Geile PC4000 in sem dal za njih če se prav spomnem 45k,kupil pa sem samo zato takšne rame da lahko furam ram na 240-260 na 1T na 2.85V recimo da furam mašino na 312x9=2808Mhz in ram na 255Mhz in to je zame vrh glave dovolj. Bi pa bil sedaj tud čisto zadovoljen z kakšnimi cenejšimi, ker se v igrah res ne pozna kaj dosti.Sam sem pričakoval da bodo dosti hitreje igre letele, da se bodo dosti hitreje naložile, haha malo morgen. Skoraj ne opaziš razlike.Za gamerje pravim da največ pridobiš z navijanjem procesorja in grafe. In tud napajalnik za 9k je čist dober za te svari (LC550W).
Z rami ki stanejo 60k in več, pridobiš mogoče 5-10% v hitrosti (že to je veliko) v igrah in uporabnih programih, daš pa za njih mnogo mnogo več kot za kakšne solidne rame.
Tisti ki nonstop poganja superPI-je, 3dmarke, sandre itd.. naj imajo take hude rame in sami sebe preprečujejo da je to full boljš kar je res, ampak samo v teh programih. Večina folka ki ima dobro grafo bo raje zaigral kakšno dobro igro, in se ne bo sekiral a mu ram dela na 230 al pa na 240Mhz ane??
eDDi:
Kateri testi na primer??
eDDi ::
RC14: če ne uporabljaš cukrčkov kot so AA in ostale dobrote, na 1024*768, je manj kot 10% razlike v fpsjih. no res pa je, da je moja 6600GT stalno navita, tista 6800GT ko sem jo imel doma, pa ni bila kaj dosti. ampak vseeno.. zakaj bi dajal tolko več denarja?
tisti ko ji imajo doma že vedo.
Tilen ::
Jaz jo imam ker sem jo dobil skor 50% ceneje, če sem pošten in to pred pol leta.
Morm pa rect da imam kr sreco pr nakupu komponent. Mislim s ceno. Ce je nebi dobil za tako ceno bi najbrz kupil 6600GT in bi se strinjal z eDDi-jem da je nakup 6800GT potrata denarja :P
RC14 ::
Tudi jaz sem svojo dobil takrat zelo ugodno, drugače bi kr ostal na 9800PRO oz bi mogoče zamenjal za 6600GT. Ker 100k in več ne dam za grafo.
No raje se držimo teme.:)
Tilen ::
Tut js sm mel 9800PRO -a takrat :)
Sam sem mel takrat samo 512 RAM-a menda :)
2 3
SiSoft Sandra 2004 Memory Bandwith Benchmark rezultati (strani: 1 2 3 )
Oddelek: Navijanje
10313076 (8985) GaS
OCZ VX 3200 (strani: 1 2 3 )
Oddelek: Navijanje
14610217 (7171) PrimozR
Ram za AMD Venice
191601 (1395) Jaffa
DDR ram z Samsung TCCD chipi! (strani: 1 2 3 4 … 10 11 12 13 )
Oddelek: Navijanje
61141730 (26148) Tilen
So tile poceni Apacer RAMi pri PC-DOMu za kaj? Se kaj navijajo?
262001 (1345) OZZY
