Forum » Navijanje » DDR ram z Samsung TCCD chipi!
Primoz78 ::
Tukaj lahko objavite vse rami, ki imajo Samsung TCCD chipe..., ki naj bi lepo nadomescale slavne BH-5/6 chipe!
A-DATA Vitesta PC4600(DDR566)
Corsair PC3200XXL (DDR400)
Kingston HyperX PC3200 Low-Latency
Mushkin PC3200 Level II V2
OCZ EL DDR PC-3200 Platinum Revision 2
Zaenkrat sem nasel te...ce dobim se kaksne podatke bom dodal!
Lp Primoz C.
Lp Primoz C.
Boki_ ::
Lepo bi blo če bi bli še timingi dopisani pa SPD voltaža. Pa corsairi so XL ne XXL in OCZ, a nima Gold revesion teh čipov gor.
I'm back
Primoz78 ::
Se opravicujem za XXL
glede OCZ pa sem dal podatke, ki so bili na anand-techu...
Lp Primoz C.
Lp Primoz C.
MEDENA ::
XMS-PC3200C2 Rev4.1 (2-3-3-6-1T) Samsung TCCD
XMS-PC3200C2 Rev4.2 (2-3-3-6-1T) should Samsung TCCD
XMS-PC3200XL Rev1.1 (2-2-2-5-1T) Samsung TCCD
Samsung PC4000 CL3 Samsung TCCD
MEDENA ::
OCZ EL Platinum Revision 2 Dual Channel Kit 184-Pin 1GB(512MBx2) DDR PC-3200 - Retail
Cas Latency: 2-2-2-5
Support Voltage: 2.75V
najboljši rami trenutno.....
OCZ’s PC-3200 Platinum Rev 2 Earns Anandtech’s Editors Choice Award
2004-08-11
OCZ Technology Group is proud to announce that the PC-3200 DDR Platinum Revision 2 received an Editors Choice award from Anandtech, a highly regarded tech-review site. Anandtech is a leader amongst a vast field of tech-review sites and is highly trusted by the industry and its daily visitors. Along with the award, Anandtech said, “This OCZ memory stands head and shoulders above the other memory tested in this roundup that are based on the same memory chips. OCZ PC3200 Platinum Revision 2 overclocked 10% higher than its nearest rival, reaching an amazing 40% overclock on a memory rated at DDR400. Performance at DDR400 was outstanding and Platinum Rev. 2 reached the highest memory speeds achieved with any DDR400 2-2-2 memory tested in this roundup.”
http://www.anandtech.com/memory/showdoc...
čisto lepo delajo 2-2-2-5 pri 2.5V
TOM DELONGE to so rami, ki jih rabiš....100%...
2004-08-11
MEDENA ::
Mushkin 1GB PC3200 2-2-2 LII V2
delajo 2-2-2-5 200Mhz pri 2.5V kar je izjema v primerjavi z ostalimi ...
folk baje dosega 230Mhz 2-2-2-5 pri 2.9V
DjTonic ::
Evo OCZ Plat Rev 2 na DFI i875 plati s P4 2.4 GHz. Gredo naviti zelo dobro pa še povrhu s tako nizkimi timingi.
- zavaroval slike: Predator ()
MrGTO ::
Zivjo!
Mene tudi zanima za tele rame. Kje se jih da dobit v Sloveniji? Pa a ni bilo govora da bo nekdo "pripeljal" neke rame iz tujine?
Lp, Blaž
Lp, Blaž
MEDENA ::
GEIL ULTRA-X Dual Channel PC-3200 DDR 400MHz 1GB Kit (GLX1G3200DC)
Ultra-X Series
1GB DUAL CHANNEL ( 2 X 512MB)
PC3200 400MHz CAS 2 5-2-2
GeIL Ultra-X TSOP 32x8 DDR Chips
184pin, Non-ECC, Un-buffered DDR DIMM
Platinum Copper Heatspreader
6 Layers Ultra Low Noises Shielded PCB with Gold 30u" Plating
Temperature thermometers
Retail package
Life time warranty
http://www.geilusa.com/proddetail.asp?l...
ampak niso tok primerni za AMD64
http://anandtech.com/memory/showdoc.asp...
bolj za AMD-XP/M in INTEL P4....
Ultra-X Series
Retail package
Life time warranty
Boki_ ::
A64 S754 ma raje 2X 256 rama. Za S939 pa še ne vem, ker ga nimam (še). Upam da nima takih problemov.
I'm back
OZZY ::
jaz bom nekaj naroča v roku 5-7 dni ..predvsem kingmax ddr500 512Mb, kjer bo cena cc 25000-25500 za modul. Sicer so gor hynix d5 čipi ampak vseeno. Cena je ugodna.
Go with the flow.
mchaber ::
OZZY to bo iz ZDA? za 25k je precej ugodno, sam bi jih mogel kdo prej sprobat šele potem bi jih nabavil
OZZY ::
ja to so rami v tvojem linku.
Će sp za kaj...Jah kot rami z d5 čipi. Moj frend z njimi nima problemov. Sem pa dvema z ST tud iste rame prinesu pa če se oglasta pa poveta kako se obnesejo. Samo kake nizke latence z njimi ne bo...Grejo ponavadi na 2-3-3-5 ..pač kot d5 čip..Moji testrani so delal tako.
Go with the flow.
LittleDevil ::
Ali mi lahko kdo pove koliko so tej rami vredni oziroma koliko bi dali zanje OCZ EL Platinum Revision 2 Dual Channel Kitl KLIK
Manufacturer: OCZ Technology
Speed: DDR400(PC3200)
Type: 184-Pin DDR SDRAM
Error Checking: Non-ECC
Registered/Unbuffered: Unbuffered
Bandwidth: 3.2GB/s
Organization: two 64M x 64 -Bit
Warranty: Lifetime
Če jih kdo rabi ZS ali E-mail
Bandwidth: 3.2GB/s
Warranty: Lifetime
- spremenil: LittleDevil ()
MEDENA ::
vredni gor ali dol.....
gledam ceno v zda in v eu...v eu so cca 400€ kar je absolutno precenjeno...
nekje 35k na modul ...hehe..
LittleDevil ::
400€ je res prevec, 55k so pa v ZDA.
Če bi pa ti lahko zrihtal en modul za 35k, potem pa tudi jaz zelo ugodno dobim v sloveniji te rame
Boki_ ::
Dej pošli ceno ZS, js če bi bi vzel eno ploščico od 512MB če se da, pa tut če je 2X256 MB ni ravno slabo, če gresta obe ploščici kar visoko....
I'm back
LittleDevil ::
Hehe sem pogledu vsa sporočila.... Aja rami imajo garancijo in vse. Ce so pa v avstriji 400€ pa niso dragi pri meni.
haha, samsung pwnzor.
cist obicajne palcke za mal dnarja, pa delajo bols kot neke ultra hyper hardcore money eating big shit brand name memory...
Alexius Heristalski ::
Dr_M: Kateri Samsung to? PC4000? Imaš kako povezavo?
glej slike
Aha, ti si mislil čipe tccd same. Se pravi ni važno ali so na OCZ-ju ali Gskillu, na obeh se obnašajo podobno. Cena pa se precej razlikuje. Sem zadel bistvo?
tako nekako ja
samo fora je, da ksn OCZ tut slabse cipe proda extremno drago. pa sej ne sam OCZ, ampak vsi bolj znani.
dost podobno je blo z BH6 in 5....lohk si jih dubu ful pocen, al si pa za njih ledvico prodal, ampak navijal so se v parih % razlike.
- spremenil: Dr_M ()
Gskill je zgleda nekaj takega kot TwinMos/Winbond v časih BH5 čipov. Dobro to. A zakaj se naši prodajalci ne zganejo in jih uvozijo? To bi po moje šlo za med.
DjTonic ::
Ti OCZ s TCCD imajo res visoko ceno, naprimer podobne Corsairje 3200 XL dobiš že za manj kot 35k komad (512MB ploščica).
billy ::
Kje le? Mogoče v ameriki? Ampak pri nas so XL definitivno dražji. Splioh nisem nikjer zasledil, da bi jih kdo imel. Recimo JAE ima:
CMX 512-3200LL 512MB DDR 400Mhz 43.440,00
Pa so XL še nekoliko hitrejši torej še dražji...
mazy ::
majo tut v hrvaški
links.hr
ram pc-3200, 256mb, corsair xl, black, ddr 400 mhz, cmx256a-3200xl - 711HRK - 22,5ksit
ram pc-3200, 512mb, corsair xl, black, ddr 400 mhz, cmx512a-3200xl - 1310HRK - 41,5k sit
links.hr
OZZY ::
cenej te pride če naročiš iz nemčije preko overclockers.de...skuapj z ptt in nakazolom je 295 evrov ali 70k.
Go with the flow.
OwcA ::
@LitleDevil: tisto je že dolgo znani hrošč ob zelo nizkih množilnikih (da zadevščina ne teče na toliko je razvidno tudi iz rezultata).
| » | Nov ram in nič OC :( (strani: 1 2 3 )Oddelek: Navijanje | 8790 (7298) | ekseR |
| » | SiSoft Sandra 2004 Memory Bandwith Benchmark rezultati (strani: 1 2 3 )Oddelek: Navijanje | 13068 (8977) | GaS |
| » | BH-5 se vrača med nami v polnem zamahu... (strani: 1 2 )Oddelek: Navijanje | 7336 (5889) | mzidy |
| » | DDR 2 2 2 5Oddelek: Kaj kupiti | 1957 (1614) | JIM22 |
| » | TCCD pri nas (strani: 1 2 3 )Oddelek: Kaj kupiti | 11665 (8280) | OZZY |
