Forum » Strojna oprema » Kako aktivirati senzor za temperaturo na grafični?
anza00 ::
Mene pa zanima kok aktiviraš senzor za temparaturo na grafični GF A6200TD
- premaknilo iz Pomoč in nasveti: bastadu ()
Timo ::
pogledaš u biose upam da veš kako se to nardi
Pazi življenje je smrtno nevarno še nihče ga ni preživel
5er--> ::
Originally Posted by Symbios
By "Symbios"
Step 1: Create a bootable floppy with Nvflash included.
1. Place a blank floopy into drive a:.
2. Chose format and check the "create a boot disk for DOS" box.
3. Download NVflash.
4. Put Nvflash.exe and Cwsdpmi.exe onto the boot disk you’ve just created.
Step 2: Save that BIOS!
1. With the floppy you created still in your drive, restart your computer and let it boot off of the floppy.
2. Type “Nvflash –b biosbackup.rom” (without quotes) and hit ‘enter’.
3. Nvflash will now save your bios to the floppy.
4. When it’s done, remove the floppy and restart your computer.
Step 3: Edit the BIOS.
1. Download a hex editor, I prefer Hextreme.
2. Launch the editor insert your boot disk once again. Browse to the floppy, you should find a file called “biosbackup.rom”, open it.
3. Search for “04031201” (make sure you are in Hex mode, click the dropdown menu next to the binoculars and select “HEX”), right after that sequence you should see “10 0A 01 11”. Highlight the “10” in the string and change it to “00” so it looks like this, “00 0A 01 11”
4. Save the edited bios to your floppy. Be sure to save it as something different then the original (we want to keep the original intact incase something goes wrong). To keep things simple, save it as “Biosmod.rom”.
Step 4: Flash your card with the edited BIOS.
2. Type "nvflash -5 -6 biosmod.rom” (without quotes) and hit ‘enter’.
Nvflash will now flash your cards BIOS. When it’s done, remove the floppy and restart your computer.
Congratulations! You should now be able to monitor the temperature of your Nvidia GeForce 6600.
By "Symbios"
fastfury ::
Sklepam, da velja isti postopek tud za Radeon 8500 al ne? Obstaja kakšen software za merit temperaturo grafe?
program NE meri tepmerature, ampak jo samo odcita iz senzorja, da pa lahko odcitas to vrendost, more bit pa senzor gor.
Pyr0Beast ::
Ka ma FX5500 Inno3D 256; temp senzor ?
| » | Leadtek A6200TD@6600Oddelek: Strojna oprema | 2960 (2016) | Fatboyslim |
| » | GeForce 6600GT pasivno hlajenje?Oddelek: Hlajenje in modifikacije | 1914 (1588) | sirotka |
| » | GF 6200 v 6600Oddelek: Navijanje | 3148 (2178) | a13misko |
| » | Grafična Kartica point of view 6600 128MB AGP8X prosim za pomoč :'( (strani: 1 2 )Oddelek: Strojna oprema | 5138 (4460) | DR4G0N |
| » | 6600agp za 34k sit (strani: 1 2 3 4 5 6 7 )Oddelek: Kaj kupiti | 21311 (14763) | Nande |
