[ c# ] NullRefferenceException
atasmrk ::
Torej, sledeco kodo sem skopiral z neta (no, ne cisto vse, tisto if in naprej dol).
public bool startMonitoring()
   IntPtr pNotifyInfo = IntPtr.Zero;
   IntPtr handle = IntPtr.Zero;
   int change = 0;
   int waitResult = 0;
   handle = FindFirstPrinterChangeNotification(hPrinter, PRINTER_CHANGE_JOB, 0, IntPtr.Zero);
   waitResult = WaitForSingleObject(handle, INFINITE);
   if ( FindNextPrinterChangeNotification(handle, ref change, IntPtr.Zero, out pNotifyInfo))
      PRINTER_NOTIFY_INFO info = (PRINTER_NOTIFY_INFO) Marshal.PtrToStructure (pNotifyInfo, typeof (PRINTER_NOTIFY_INFO));
      int pData = (int)pNotifyInfo + Marshal.SizeOf( ypeof(PRINTER_NOTIFY_INFO));
      PRINTER_NOTIFY_INFO_DATA[] data = new PRINTER_NOTIFY_INFO_DATA[info.Count];
      for ( uint i = 0; i < info.Count; i++ )
         data[i] = (PRINTER_NOTIFY_INFO_DATA)Marshal.PtrToStructure((IntPtr)pData, typeof(PRINTER_NOTIFY_INFO_DATA));
         pData += Marshal.SizeOf( typeof(PRINTER_NOTIFY_INFO_DATA));
      FreePrinterNotifyInfo( pNotifyInfo );
      Console.WriteLine("konec branja strukture");
   return false;
pred tem pa imam deklarirani strukturi v istem razredu
struct PRINTER_NOTIFY_INFO
	public uint Version;
	public uint Flags;
	public uint Count;
	// Array of PRINTER_NOTIFY_INFO_DATA follows
struct PRINTER_NOTIFY_INFO_DATA
        public ushort Type;
	public ushort Field;
	public uint Reserved;
	public uint Id;
	public uint cbBuf;  // or adwData[0]
	public IntPtr pBuf; // or uint adwData[1]
Ob prevajanju te kode mi javi warning
PRINTER_NOTIFY_INFO.Version' is never assigned to, and will always have its default value 0
ob izvajanju prve vrstice znotraj if-a pa tisti slavni
System.NullReferenceException: Object reference not set to an instance of an object.
Tu imam pa toliko stvari, da ne vem, kateri ogjekt zadeva misli. Se komu kaj vec sanja?
  • spremenilo: atasmrk ()
Kekec ::
Za začetek bi lahko preveril če ti je sploh kaj dalo v pNotifyInfo, če je pa prazen pa je exception čist razumljiv!
atasmrk ::
Ja, ekekec, to je bilo to. Nic se ni tja noter zapisalo. In ko sem se se malo poglobil v MSDN, sem opazil, da s tistim IntPtr.Zero sploh ne zahtevam podatkov. Tako sem deklariral se eno strukturo PRITNER_NOTIFY_OPTIONS
struct PRINTER_NOTIFY_OPTIONS
	public uint Flags;
	public uint Count;
	public IntPtr buf;
in jo porinil na tisto mesto v klicu procedure, kjer je bila potrebna. tistega buf se sploh nisem dotika, ker sem flags nastavil na PRINTER_NOTIFY_OPTIONS_REFRESH, in bi torej ta funkcija morala vse druge clane te strukture ignorirati.
Sedaj pa dobim NullRefferenceException v klicu funkcije FindNexPrinterChangeNotification(). In mi se zmeraj ni jasno, kaj je narobe. Kaj bi pa sedaj, laho bilo 0?
atasmrk ::
ce pa naredim
PRINTER_NOTIFY_OPTIONS notifyOptions;
IntPtr no = IntPtr.Zero;
notifyOptions.Count = 0;
notifyOptions.Flags = PRINTER_NOTIFY_OPTIONS_REFRESH;
notifyOptions.Version = 2;
notifyOptions.buf = IntPtr.Zero;
no = Marshal.AllocCoTaskMem(Marshal.SizeOf(notifyOptions));
in potem klicem
if (FindNextPrinterChangeNotification(this.hChangeObject, ref change, no, pNotifyInfo))
pa stvar vrne false, GetLastError() pa vrne ERROR_INVALID_PARAMETER. Kaki prebliski?
[C#] pixel scan z Thread
Oddelek: Programiranje
121620 (1402) perooo25
kako narediti program ki bere drugi program
467151 (5464) imagodei
video v c#
241857 (1397) boss-tech
[C#] Sesutje aplikacije
112007 (1842) Jean-Paul
[C#] unmanaged->managed code
112557 (2432) Zzzzzzz
