Prenosnik: Standby vs. Hibernate
B-D_ ::
Za hibernacijo vem, da predstavlja kopiranje kompletnega rama na disk kateremu sledi shutdown mašine in potem kontra nalaganje ko spet zbudiš comp. Kako pa je izveden Standby in zakaj je bolj energijsko potraten pa (še) ne vem. Zanima me tudi kateri način izklapljanja prenosnika pred transportom je (če nam je vseeno za manjšo integriteto baterije) bolj varen za komponente.
Tnx za odgovore, lp. :)
smolep ::
Ja StandBy je energijsko bolj potraten zato, ker se ti računalnik ne ugasne čisto. Mislim, da ostane aktivno osveževanje rama in najbrš še vse tisto, kar je povezano s tem, torej kaki kontrolerji in ... Če bi prenosniku med standby-jem zmanjkalo baterije, bi šli vsi podatki v ramu (mogoče tudi v raznih cachih) rakom žvižgat8-O . Tko si jaz predstavljam ;) . Ne vem pa če je čist ql.
CCfly ::
Imaš hibernacijo kjer je vsebina ostane v ramu in kjer se vsebina pomnilnika presname na disk.
Documentation: The file /sys/power/state || /proc/acpi/sleep
To conserve energy while remaining quickly available, ACPI-compatible PCs may enter system sleep states. The ACPI specification defines 5 of these states, known as S-states. Unlike the processor sleep states described later, no work is done by the system under S-states. Each state introduces greater power savings but requires commensurately more time to awaken and begin performing work. These are patterned on system states from the APM standard, a predecessor of ACPI.
After the explanation of the usage for each kernel version, a more general explanation about the single sleep states is attached.
Sleep States
S1 - "Stopgrant"
Power to cpu is maintained, but no instructions are executed. The CPU halts itself and may shut down many of its internal components. In Microsoft Windows, the "Standby" command is associated with this state by default.
S2
While defined in the spec, this state is not currently in use. It resembles S3 with the qualification that some devices are permitted to remain on.
S3 - "Suspend to RAM"
All power to the cpu is shut off, and the contents of its registers are flushed to RAM, which remains on. In Microsoft Windows, the "Standby" command can be associated with this state if enabled in the BIOS. Because it requires a high degree of coordination between the cpu, chipset, devices, OS, BIOS, and OS device drivers, this system state is the most prone to errors and instability.
Pavel Machek has created a small document with some hints how to solve problems with S3. You can find it in the kernel sources at Documentation/power/tricks.txt.
S3 is currently _not_ supported by the 2.4.x kernel series in Linux.
S4 - "Suspend to Disk"
CPU power shut off as in S3, but RAM is written to disk and shut off as well. In Microsoft Windows, the "Hibernate" command is associated with this state. A variation called S4BIOS is most prevalent, where the system image is stored and loaded by the BIOS instead of the OS. Because the contents of RAM are written out to disk, system context is maintained. For example, unsaved files would not be lost following an S4 transition.
S4 is currently _not_ supported by the 2.4.x kernel series in Linux, but you might have good luck with SWSUSP. Some machines offer S4_BIOS whose support is considered to be experimental within ACPI4Linux.
S5 - "Soft Off"
System is shut down, however some power may be supplied to certain devices to generate a wake event, for example to support automatic startup from a LAN or USB device. In Microsoft Windows, the "Shut down" command is associated with this state. Mechanical power can usually be removed or restored with no ill effects.
Računalnik se noče prebudit - AMD
377425 (6926) opeter
Odkrit razlog za večjo porabo energije v novem Linuxovem jedru (strani: 1 2 )
7330567 (25929) MrStein
Računalnik noče zaspati
467076 (6572) opeter
Procesor over clip intel core i7 920
10963 (888) ModriN96
Nov članek: "All your firmware are belong to us" (strani: 1 2 3 )
Oddelek: Novice / Nova vsebina
13820230 (17070) arrigo
