A ni čas,da Rusi kolonialno mentaliteto pustijo za sabo? Kdaj si je nazadnje kakšna evropska država priključila ozemlje? Zadnji mislim,da so bili Srbi,ki so si hoteli priključiti dele Hrvaške.
Rusi si ga priključujejo vsakič, ko zahod z širitvijo NATO prečka rdeče črte.
Albanci so si pa priključili Kosovo.
Srbi Albancev niso priznavali kod enakovreden narod. In ga se vedno ne. To jih je pokopalo. Dobro ves, da bi etnicno cistili po Kosovu, ce ne bi NATO posredoval. Oziroma, kaj mislis, da bi se zgodilo?
Napaka je bila, da se Kosovo ni razdelilo - to se strinjam.
- spremenil: kow ()
Dmitry Medvedev : Russia will achieve all set goals. And there will be peace on our terms. And not on terms of those confused political impotents who are screaming in Europe and overseas.
Operacija nevihta 2.0 :)
- spremenil: D3m ()
Ustavite konje, Rusom se je dokončno odpeljalo.
Sem najprej pomislil, da gre za satiro, ampak ne, vse skupaj je objavil Kommersant v lasti z oblastjo zlizanega Ališerja Osmanova.
https://www.yahoo.com/news/russia-says-...
OG članek, uporabi prevajalnik:
https://www.kommersant.ru/doc/5469617
Nearly five months into its senseless war against Ukraine, Russia has concocted a wild new explanation for why the Kremlin’s plans for a quick takeover fell apart so spectacularly—because Ukrainian troops were turned into superhuman killing machines during “secret experiments” in American-run biolabs, of course.
That claim was made Monday by two Russian lawmakers heading up a commission to investigate “biolaboratories” in Ukraine, Kommersant reported.
Konstantin Kosachev, the deputy speaker of Russia’s Federation Council, and Irina Yarovaya, deputy chair of the State Duma, touted what they described as bombshell findings from the “investigation.”
Testing of Ukrainian POWs’ blood, they claimed, uncovered “a range of diseases” that suggest they were secretly experimented on “for military purposes.”
Ukr državno tožilko lahko odpusti samo rada (parlament), ne predsednik na podlagi svojega odloka.
Ampak, koga zanimajo take podrobnosti.
https://mtwitter.com/ivan_8848/status/1...
- spremenilo: sbawe64 ()
@ kow
Ne, ker je pisal o IZKUŠNJAH.
In, kar se tiče lahkote je imel prav. Ukrajina prireja zgodovino.
Tudi, ce jo. Vsaka drzava prireja zgodovino. Saj ves, nacionalni miti pa take fore. A ti res verjames v vse pravljice o moskovskih princih?
Seveda Ukrajinci so se sami izstradali. Stalin in Rusi v centralnem komiteju niso o tem vedeli popolnoma nič. Če bi vedeli,da stradajo ne bi izvažali žita ampak bi ga pustili Ukrajincem. Verjetno so se tudi Irci med krompirjevo boleznijo izstradali sami. Ni mogoče,da bi Angleži imeli karkoli s tem. Jebo vas pas mater.
Jebo te glupač.
Si mogoče kdaj pomislil zakaj izvažajo žito?
Si se informiral do kod je segalo območje lahkote?
Nič od nič.
So tebi govorili, da je tvoja mati kurba? Si jim verjel? NE? Zakaj ne?
No vidiš.
Nič od nič.
No vidiš.
- spremenil: D3m ()
Nisem ustavni pravnik, še manj ukrajinski ustavni pravnik, ampak Ukrajina je država v vojni in ima verjetno razglašeno izredno stanje, kot Madžarska.
Posledično lahko predsednik vlada z dekreji. Zdaj, če to ni znano bivši državni tožilki, zna bit prav, da jo je odstavil.
TezkoDihanje ::
https://twitter.com/CByder/status/15494...
Opa.....Zelensky se boji puča.
A si že spet hotel nekaj razmislt, pa ni šlo... zeh.
https://wartranslated.com/day-145-july-...
UKR officials suspended:
Security Service (SBU) head and Prosecutor General suspended during investigation.
SBU is ongoing complicated transformations, as there are many highly patriotic professionals, and many who are doubtful, corrupt, collaborating. Yesterday former SBU Crimea branch head was arrested.
SBU is not the type of organization, where director controls everything, many things can be hidden under pretense of national secrets or operative information. 60 government officials keep working for RU in occupied territories, there are almost 700 cases of treason, collaboration, etc. President Zelensky is not satisfied with speed of investigations of treason and collaboration. 2 months ago there was 12k such cases.
pangro ::
Verjetno se čisti korupcijo pod taktirko američanov navsezadnje je v njihovem interesu da se tistih 40 miljard čimveč prelije na fronto da se izžene ruse ven. Je jeba če pošiljaš miljarde v koruptivno greznico, je bistvena razlika če pošiljaš opremo in denar recimo Izraelu ali pa koruptivni greznici.
Jebo te glupač.
Nič od nič.
No vidiš.
Jebi se govno. Itak so Ukrajince izstradali židi al ne? Pojdi na 4chan po novo dozo driske. Jebeni naci.
TezkoDihanje ::
Jebo te glupač.
Nič od nič.
No vidiš.
Umiri se naci.
Glej "Golden embargo" za takrat.
Pa malo se izuči.
Droughts and famines in Russia and the Soviet Union @ Wikipedia
Da ne boš čisto iz sebe.
TezkoDihanje je izjavil:
Ne trudi se opravičevati. :)
Saj moraš vedet, da NSA na polno išče ruske vohune po Ukrajini. Prisliškovanje vsega in svačega. Data collecting/mining, etc.
Vem, da išče. In verjamem, da je Zelensky dal določena pooblastila tujim agencijam.
- spremenil: D3m ()
Jebo te glupač.
Nič od nič.
No vidiš.
Umiri se naci.
Pa malo se izuči.
Seveda glupi naci spet nisi prebral kar si objavil.
Michael Ellman's analysis of the famine found that "there is some evidence that in 1930-33 ... Stalin also used starvation in his war against the peasants", which he calls a "conscious policy of starvation", but concludes that there were several factors, primarily focusing on the leadership's culpability in continuing to prioritize collectivization and industrialization over preventing mass death,[18] due to their Leninist stance of regarding starvation "as a necessary cost of the progressive policies of industrialisation and the building of socialism", and thus did not "perceive the famine as a humanitarian catastrophe requiring a major effort to relieve distress and hence made only limited relief efforts.
Seveda sem bral.
Verjamem pa, da si razlagaš po svoje.
Na pa še svoj Gold embargo si vtaknil v rit.
from 1926 indeed mentions the gold embargo as detrimental to Soviet-British trade, thus the embargo did exist, at least for some states. On the other hand, it also mentions that in the years its authors investigated (1917 -1925) Britain imported over 6 million pounds of gold and silver from USSR (while exporting about 7 million), so we can safely assume that by 1925 the embargo was nonexistant.
But by 1928 the gold reserve of USSR was at a historical low - while the exact amount was undisclosed, it is estimated that in 1918 it amounted to ~1000 tons of gold, and by 1928 it was down to ~150 tons. Stalin's government took radical steps towards increasing the production, started actively confiscating gold and foreign currency, and cut down on imports (until 1941 Stalin was very reluctant to spend any gold from the reserves at all), but the reserve only started growing again around 1934 - for example in 1932 Soviet mining efforts yielded only 32 tons of gold. (Source: Л.В. Сапоговская, "Золотопромышленность Республики Советов - СССР - РФ: эволюция отрасли в альтернативных системах хозяйствования", "Экономическая история. Ежегодник. 2003" (М.: РОССПЭН, 2004. С. 266-308))
So, while USSR was not prohibited to export gold, there was not much of it that it actually could or wanted to sell, and while grain was not the only export, it was the main source of income in Soviet international trade.
Ukrajinci pravijo, da so nad Novo Kakovko sestrelili rusko letalo, verjetno Su-35. Zadeva na prvi pogled deluje far fetched, saj je kraj pod okupacijo, Ukrajinci pa tam redno radirajo skladišča z orožjem.
Morda spet prijateljski ogenj?
https://twitter.com/search?q=nova%20kak...
več videov sestrelitve na povezavi
Po liveuamap so prvi ukrajinski položaji kakih 50 km stran. Ne bom rekel nemogoče, vsekakor pa zelo malo verjetno.
- spremenilo: Pac-Man ()
Griffin R500 je izjavil:
Solzenicin nima pojma.
Oh Ye of Little Faith.
Zdaj mi pa razlozi - zakaj je on avtoriteta za Ukrajino? Ker je pisal knjige o gulagu?
Za Boštjana izključno,ker je bil proti Židom. A ne veš,da so židi vedno nekje v ozadju. Vlečejo niti. Čisto mogoče,da so tudi za Putinom. Zakaj bi se drugače beli kavkazijski Slovani pobijali med sabo?
A ti veš, da je holokavst še ena izmed zgodovinskih laži?
Prazen si, ko kokica. Zaslepljen si že od otroštva. Mogoče ti bo do smrti uspelo spoznat kanček resnice ampak dvomim, ker slepo slediš medijem.
To je pa beseda, zaradi katere se gre v nekaterih državah na sodišče! Tako, da lepo te prosim vse ima neke meje!
- spremenil: fur80 ()
Vidim da sem v prejšnjem sporočilu nekaj za zašuštral.
Delujoč link
https://twitter.com/ivan_8848/status/15...
https://dailybanner.co.uk/content/zelen...
Seveda.
Vse se lahko graja samo izbrano ljudstvo ne. ;)
LightBit ::
Saj nisem presenečen da si naci.
A ti veš da je zanikanje holokavsta nezakonito v Rusiji in večjem delu Europe?
Tu je še lepši posnetek, ko je padel direkt pred ruske sile! :D
Downing of airplane in Kherson Oblast, fell down in front of Russian positions.
Let's see if it's another blue on blue by Russia AD.
https://twitter.com/tinso_ww/status/154...
Ali so ga svoji ali pa UA.
Ukrajinci pravijo, da so ga oni.
Še največ bo povedal pilot.
Ukrajinci tudi rusov ne. Pa kaj potem?
Ter ali resnično misliš, da je NATO posredoval, ker so se jim smilili albanci na Kosovu?
Kaj ti blodis? Da Ukrajinci ne priznavajo Rusov za enakovreden narod?
Da, tudi to je bil razlog. NATO ni zelel pizdarij v Evropi. Seveda je to izkoristil tudi, da stratesko oslabi rusko vazalno drzavo - Srbijo.
- spremenil: kow ()
Video, ko pada v "flat spin". Ob zadnjem obratu mi deluje kot Su-27/30/34/35 familija.
Rusi menda pravijo, da so sestrelili dron :)
Me
HEHE, zraven je pa še video, kako se iz drona pilot izstreli in pada s padalom! :D
Se še komu zdi, da se je Putler tu še bolj spremenil? Če ga tukaj pogledamo v obraz. Kam je padel vladar, da ga takole Iranec vozi in prijema za roko?
Meni se ne zdi niti malo OK, za njega je še Biden atlet!
https://twitter.com/200_zoka/status/154...
A dronu so se na koncu izstrelile toplotne vabe? Sam,če Rusi pravijo,da je dron pol bo že držalo
A dronu so se na koncu izstrelile toplotne vabe? Sam,če Rusi pravijo,da je dron pol bo že držalo![]()
Se pravi je dron, jaz sploh ne vem kaj dvomimo! Kaki nevedneži smo mi, jao...
Ukrajinec piše, da so rekli rusi.
Pa gledam ruske OSINTE pa noben tega ne piše.
C'mon man.
Ne, to je bila zgolj in samo pravljica za domačo rajo, da je podpirala imperializem.
Kar je več kot očitno tudi iz posledic preteklega stoletja ameriške pomoči.
Škoda, reveži se že stoletje trudijo, pa jim še kar ne uspeva.
Ne, ne... Nikakor. NATO je posredoval zaradi zalog nafte in plina. Pa ker so hotl bazo in nukice postavit na rusko mejo.
TezkoDihanje ::
https://twitter.com/AgathoGeorgius/stat...
HIMARS straight to the bullseye
Destroyed Russian 48Ya6-K1 "Podlet K1" radar, Kherson Oblast
nekaj so morali dobit Ukrajinci proti radarjem
haha, puhličar LOŽAR v svojem elemntu.
Kje si študiral zgodovino, da si tako zabit.
- spremenil: TezkoDihanje ()
TezkoDihanje ::
Perfect Air-Intelligence and Artillery Co-Op: Four russian artillery guns destroyed (ENG Subtitles)
Nizko je padel Putler, včasih je nekaj pomenil, sedaj so Rusi pajaci, prosijo za denar po Kitajski, Indiji, prosijo Iran za drone, Turki jih pa ne jebejo več 5%!
Seems like Erdogan has won this turn of waiting game
https://twitter.com/ragipsoylu/status/1...
TezkoDihanje ::
jernejl ::
Kaj bi rad? Da gremo z razvojem nazaj in se priključimo neuvrščenim?
Nope - zgolj to, da se prenehamo vtikati v stvari, ki se nas ne tičejo. Od Iraka in Afganistana, pa do Ukrajine.
Stanje v ukrajini se nas še kako tiče, zato bi bilo edino pravilno, da popolnoma polomimo zobe tistim, ki se vtikujejo v naše sodelovanje z ukrajinci. Tistim, ki nam onemogočajo dobavo dobrin, nam povzročajo težave v dobavnih verigah in pošiljajo begunce.
Izjemno velika napaka je, da ukrajincem ne pomagamo, oziroma to počnemo zgolj simbolično. Pravzaprav bi jim morali pomagati že takrat, ko so jim agresorji zasedli krim, pa smo se delali francoze. Danes jim vsaj simbolično pomagamo, vendar bi ta pomoč moral biti za nekaj velikostnih razredov večja. Že davno bi jim morali poslati vojaška letala in rakete dolgega dosega ter nekaj jedrskih konic in seveda protiraketne sisteme. Ukrajinci bi morali odgovoriti s protinapadom v zaledju, torej v sami rusiji in uničiti tamkajšnje vojaške cilje in infrastrukturo, NATO bi pa moral z blitzkrieg akcijo uničiti vojaške cilje in infrastrukturo v belorusiji, od koder se izvaja agresija in povzroča škoda evropi. Protinapad je najboljša obramba. Prej in bolj silovito kot jih bomo uničili, manj škode nam bodo povzročili.
Nevtikovanje v stvari, ki se nas tičejo (kar zagovarjate nekateri), je najslabši možen scenarij.
- spremenil: jernejl ()
Ma dejte. Kaos v Ukrajini se ni zaćel letos februarja, ampak že dosti prej. In kaj se je do sedaj vse takega pomembnega storilo??
Z orožjem se ne da doseči nič, bodite pametni.
We are fine without wings.
Težko dihanje; Sedaj si linkal YouTube posnetek, ki potrjuje tvojemu prepričanju, posnetku stran dve nazaj, kateri pa razlaga,zakaj misli, da je na sliki HIMRAS pa ne verjameš?! Človek ni trdil, da so Rusi tega uničili, ampak, da so ga našli.
V glavnem selektivno s predsodki podprto prepričanje ni produktivno. Ni problem, če ne verjameš, večja težava zate je, da nimaš drugih argumentov za to, ampak samo en posnetek, ki ti ustreza.
Ali so Rusi uničili kakšen HIMARS ali ne, ne vem, slik uničenega ni na spletu, tako da je vse to lahko le ruska propaganda.
- spremenilo: fikus_ ()
PacificBlue je izjavil:
A z orožjem se ne da doseči nič? A Putin to ve?
apropos od tistih dveh penzionerjev z novo Lado namesto padlega sina in ker je nekdo prijavil, da v ZDA dobiš bupkis - izplačajo 100k $.
https://myarmybenefits.us.army.mil/Bene...
The Department of Defense provides a one-time lump sum Death Gratuity of $100,000 to the primary next of kin of a Service member who dies while on active duty. Its purpose is to help the survivors in their readjustment and to aid them in meeting immediate expenses incurred. The gratuity is paid by the last military command of the deceased.
"Stanje v ukrajini se nas še kako tiče, zato bi bilo edino pravilno, da popolnoma polomimo zobe tistim, ki se vtikujejo v naše sodelovanje z ukrajinci."
Zanimivo, še eden , ki misli podobno kot Putin na drugi strani. To je recept za vojno do zadnjega UA vojaka.
jernejl ::
Ravno nasprotno, to je recept, da bodo ukrajinski vojaki še obstajali. Če bi putlerju pustili, da počne, kar hoče, ukrajinskih vojakov tako ali tako kmalu ne bo več. Tudi ukrajincev in ukrajine ne. In vsakih nekaj let bi nestrpno pričakovali, kdo bo naslednji. To je treba preprečiti s silovitim odporom.
IMO bodo imeli v Rusiji prej revolucijo.
| » | Rusija čedalje bolj izolirana od interneta in elektronskih plačilnih storitev (strani: 1 2 3 4 5 6 )Oddelek: Novice / Ostale najave | 79957 (47715) | Mr.B |
| » | Londonsko vozlišče prenehalo izmenjevati promet z ruskimi operaterjiOddelek: Novice / Omrežja / internet | 11198 (8677) | jotunn2 |
| » | Nedeljski izpad CenturyLinka promet po internetu oklestil za 3,5 odstotkaOddelek: Novice / Omrežja / internet | 5448 (4810) | SmeskoSnezak |
| » | Rusija se bo poizkusno odklopila od internetaOddelek: Novice / Omrežja / internet | 13885 (9863) | Mare2 |
| » | Veliki Brat na internetu: tudi v Sloveniji (strani: 1 2 )Oddelek: Novice / Zasebnost | 14572 (14572) | GBX |
