Novice » Grafične kartice » Prvi Polaris je tu kot Radeon RX 480
Jst ::
LOL, sem mislil, da je sedaj že v vsaki fizični trgovini, ne pa da na amazonu piše do tri mesece... ajoj, AMD, ajoj.
Kaj pa nvivijin odgovor? So že izdali kartico?
1060 je zunaj, ampak jih vse sproti pokupijo, tko da težko najdeš zalogo. Če danes naročiš, imaš Palitko z dobavo okrog 8.8.
In terms of performance, the ASUS RX 480 really is quite impressive. ASUS has pushed its STRIX model well beyond the capabilities off the reference card, putting it right on par with the more expensive GeForce GTX 1060.
Compared to our reviews of the GTX 1060, the ASUS ROG Strix actually flips DirectX 12 performance around. Whereas the GTX 1060 was pulling in the same frame rates as on DX11, or even less in some circumstances, the RX 480 shows significant performance gains while using both DX12 and in particular Vulkan. We explored this in a previous article, but it's a prime indicator of the forward thinking going on in AMD's driver support. At the moment, Nvidia has a lot of catching up to do in this area, despite offering more brute force performance.
Price may be an issue for some with this particular model. The Strix is stretching dangerously close to 1060 territory, but based on benchmarks it's definitely got the performance to back it up. Considering the advantages it holds in DX12 and Vulkan benchmarks also, it's perhaps the smarter choice in the long run.
Kje os benchi 470, ki naj bi bila od danes naprej na voljo :s. Prokleti salabajzerji!
- spremenilo: tikitoki ()
Pa ne še spet. Fucking mining.
- predlagal izbris: trnvpeti ()
Najbolje, da jih fizično dostavijo v trgovine.
Potlje bi pa takole izgledalo na dan otvoritve.
- spremenil: D3m ()
D3m0r4l1z3d ::
Če bodo 470 pod 200 eur, bo že uspeh.
Nope. Tam 210 za 4GB, 229 za 8GB ali malo več.
- spremenil: D3m ()
8gb bo ziher več kot +20$
če bo 8GB varjanta 210E, bo to kr slab deal.
- spremenil: iloveboobz ()
D3m0r4l1z3d ::
Glede na to, da dobiš 980 performance kot je 1060 že za 279eur http://www.mindfactory.de/product_info...., potem bi morala biti 970 performance kot jo bo verjetno 470 zagotavljala, blizu 200eur ali celo manj, 4gb bo dovolj
PredatorX ::
Anymal brez zamere... ampak GTX 1060 ni kaj prida deal. Mi je RX 480 veliko boljši deal.
- spremenilo: PredatorX ()
ko so custom varjante ta moment 20e dražje in je stvar enako hitra ali slabša, nemorš glih govorit o slabem dealu za 1060
D3m0r4l1z3d ::
Boš šel pač na freesync monitor, zakaj pa ne, samo ne moreš svoje želje na vse poenostavit
D3m0r4l1z3d ::
Pa še p/p si porušiš, če moraš nov monitor kupovat :-()
D3m0r4l1z3d ::
D3m0r4l1z3d ::
http://www.mindfactory.de/search_result...
Mindfactory jih ima od 219 do 279eur, Devil za 219 in Nitro+ za 279eur, vmes pa msi, asus...
Amd pošteno zaj. kupce stock 480 :-)
- spremenilo: D3m0r4l1z3d ()
280 je malo preveč za RX 470, ker dobiš že Devil RX 480 za tak denar.
Čakamo na odgovor nvidie z 1050.
D3m0r4l1z3d ::
Devil je 20eur dražji, za isti denar 279eur dobiš custom 1060
tale msi bi bla zanimiva z 4GB pa sub 200e (pa še samo zato, ker imajo zelo zelo dober hladilnik)... 470ka kot taka je pointless za tako ceno.
kupiš reference 480 z 4gb, odkleneš na 8gb :)
Ja 10% več perfa.. al pa 4GB vrama več.
D3m0r4l1z3d ::
Za isti denar imaš Nitro 480 4GB.
4gb 480 ni samo 480 8gb br3z 4gb rama, ampak je še pri memory hitrosti gimpana in ni kaj dosti hitrejša od 470 4gb
Devil rx 470 je najcenejša, 219eur
8Gb 240€. Ni slaba tole... bi kr naroču.
Pohiti, ker so se verjetno zmotili, saj je ista od msi 4gb dražja od 8gb http://www.mindfactory.de/product_info....
D3m0r4l1z3d ::
GenZNPC ::
Anymal :: danes, 18:26:18
Prekleti Rockstar, jemlje denar od nvidie
Fuj to.
470 se sigurno odklene na 480... ;) ;)
470 je pocasnejsa od navite 280x ?
Upgrade iz 270X na 470 je velik korak za Predatorja in se vecji za clovestvo.
skibidi
- spremenil: GenZNPC ()
Jst ::
Zakaj moderatorji 4 osebke iz te teme ne naženejo ven???
Pa ne samo iz te teme, pojavljajo se v vseh AMD in Nvidia temah.
In morebitni kupec potem pojma nima... je oblje da vrže kovanec, ker zadnjih 10 odgovorov od omenjenih osebkov, nismo zvedeli nič koristnega. Pojdite na guru3d.com forume, tam vam bodo vsaj svetovali kaj kupiti, tu pa je očitno od moderatorjev dovoljen fanboyjizem, ki sliko tako deformira, da je človek zmeden še bolj...
Ni čudno, da je v zadnjih nekaj letih zapustilo slo-tech ene 8 res dobrih članov.
No, nehej jokcat.
http://www.alexa.com/siteinfo/slo-tech....
Napajalc ::
No, nehej jokcat.
A prov vidim da odkar so zaklenil rx 480 temo pada promet?
011011100111010101100010
Prvi test
Asus RX 460 STRIX Gaming 4 GB
http://www.guru3d.com/articles-pages/as...
LOL.
Po performancu je enaka Asus HD 7870 DirectCU II.
LOL.
- spremenil: D3m ()
sepravi 950 performance at best in poraba tamtam z 75W različico 950.
Meh, nič nepričakovanega
Poraba, noise on-pair z 950. V novejših igrah hitrejša od 950.
Edina slabost, da ni "čisti" Polaris 11
Čisti je tale
Čisti je tale
pa overclock je švoh, medtem ko maxwell.... Nebi bil presenečen, če bi nvidia zadevo rebrandala v 1040ko
Saj so primerjave z 950 OC.
Manjka tisih 14% shaderjev.
Ta čip bi moral it v prenosnike, 1024SP različico pa sem.
in spet za prenosnike ni dobra izbira, ker je že lanskoletni maxwell enako efficient ali še bolj. Torej kjer šteje poraba in gretje (pri prenosnikih vsekakor) je spet amd v k***, sploh če se nvidia odloči poknat ven GP108/107 čip
- predlagalo izbris: PredatorX ()
D3m0r4l1z3d ::
Tepe ji pač, da so izdali p/w izdelke letos, kar je konkurenca že 2014 imela, preko tega ne morejo kar tako cigumigu, še posebej, ker so na 14nm to dosegli, kar je še toliko slabše
PredatorX ::
iloveboobz je izjavil:
Hehe. Da nebo potem zelo konkurencnih cipov.
Napajalc ::
D3m0r4l1z3d je izjavil:
Slabše? navi gtx 960 da bo izenačen performance v dx12 in vulcan z rx 460 in poročaj o porabi, trenutno je 73w vs 119w v prid rx 460.
| » | Prvi Polaris je tu kot Radeon RX 480 (strani: 1 2 3 4 … 8 9 10 11 )Oddelek: Novice / Grafične kartice | 137812 (113535) | Predator X |
| » | Nadgradnja Grafične kartice (strani: 1 2 3 )Oddelek: Kaj kupiti | 18648 (16097) | fender2206 |
| » | Gtx 1060 ali RX 480 (strani: 1 2 3 4 … 25 26 27 28 )Oddelek: Kaj kupiti | 272476 (236188) | Predator X |
| » | Mnenja o grafični kartici 380 in 380XOddelek: Kaj kupiti | 4315 (3825) | xrotek |
| ⊘ | AMD Radeon R9 400 Series (strani: 1 2 3 4 … 118 119 120 121 )Oddelek: Strojna oprema | 956393 (813049) | gddr85 |
