Novice » Operacijski sistemi » Windows 8 uvaja hitri zagon
Jst ::
>(U)EFI je osnova.
Česa? Kaj naredi od reset vektorja v procu, ko prižgeš mašino ali jo rebootaš?
BIOS in POST postopek sem pa moral za šolo vedeti menda tudi v spanju. Zato mi ne gre, da je BIOS "dodatek," če pa BIOS pripravi okolje za boot. Potem (U)EFI kot osnova, ne bi imel smisla. In ker se vse začne od odvisnosti od procesorjeve arhitekture in reset vektorja, da se pripravi boot okolje in nato preide v bootstraping... mi pač ne gre v glavo, kaj ti misliš, da je osnova.
Moral bi odgovoriti nekdo, ki je danes na FRIju ali Vegovi in če se še učijo zgodovino, podati razlago ali linke. For once and of all.
Glej, če se kaj spoznaš na PC-je, je to osnova. Ki je očitno ti ne poznaš.
Firmware v modernih PC-jih je (U)EFI. (na Mac-ih že od nekdaj, na PC pa posamično, a vedno več).
To je alfa in omega. Do trenutka boot-a.
"BIOS" pa je compatibility layer oziroma add-on, da se DOS in druge 30 let stare zadeve še vedno lahko poženejo.
Tak, kot če cygwin na Window instaliraš. Glavni je še vedno Windows.
Jst ::
In IBM PC compatible computers, the basic input/output system (BIOS), also known as the System BIOS or ROM BIOS (pronounced /'ba?.o?s/), is a de facto standard defining a firmware interface.[1]
The BIOS software is built into the PC, and is the first code run by a PC when powered on ('boot firmware'). The primary function of the BIOS is to set up the hardware and load and start a boot loader. When the PC starts up, the first job for the BIOS is to initialize and identify system devices such as the video display card, keyboard and mouse, hard disk drive, optical disc drive and other hardware. The BIOS then locates software held on a peripheral device (designated as a 'boot device'), such as a hard disk or a CD/DVD, and loads and executes that software, giving it control of the PC.[2] This process is known as booting, or booting up, which is short for bootstrapping.
vir: wiki:BIOS
Osnov očitno ti ne poznaš. Ali pa wiki laže.
(To o reset vektorju v procesorju je že višje znanje od SŠ, mogoče tudi faxa.)
Jst ::
BIOS is primarily associated with the 16-bit, 32-bit, and the beginning of the 64-bit architecture eras, while EFI is used for some newer 32-bit and 64-bit architectures. Today BIOS is primarily used for booting a system and for video initialization (in X.org); but otherwise is not used during the ordinary running of a system, while in early systems (particularly in the 16-bit era), BIOS was used for hardware access - operating systems (notably MS-DOS) would call the BIOS rather than directly accessing the hardware. In the 32-bit era and later, operating systems instead generally directly accessed the hardware using their own device drivers.
Jaz sem še iz stare garde, ki pozna bedarije, ki jih še danes x86_64 nosi s seboj. Pa prekope stanj, ki se morajo zgoditi, registri, ki morajo imeti prave vrednosti,... ampak to znanje bledi, ker ga ne potrebujem. Zato sem mogoče napisal kakšen kiks, a v osnovi je BIOS pač nuja, preden smo prišli do EFI, ki je nastal z namenom, da se ukine počasnost BIOSa in omogoči boljšo kontrolo in varnost nad hardware-om.
edit: Jaz sem vedno govoril o IBM_BIOSu in kako naj bi deloval "po pravilih." Mogoče je tu ta točka, kjer ne prideva skupaj. Na današnjih platah pa, se strinjam, je BIOS postal drugačen, namenjen za hitrejši zagon, saj je na plati pač zalotan hardware in ni več nujna polna inicializacija, ki bi se drugače dogajala med POSTom.
- spremenil: Jst ()
matejdro ::
Ravnokar probal windows 8 developer preview: do dual boot menija malo rabi (do tam, ko izbereš Windows 8 ali pa 7), ko pa izbereš osmico pa se praktično naloži takoj. Netbook z atomom in HDD.
matejdro ::
Tako nekako je:
BIOS
Boot screen (nalaganje) 3-5 sekund
Boot menu
Izbereš Windows 8
Črni ekran z Please Wait (nekje 2 sekundi)
Pokaže se home screen
Brez boot menija se bi verjetno zagnalo še hitreje.
Je pa res, da če izbereš Windows 7, se bo računalnik še enkrat resetiral in šele nato začel nalagati sedmico.
BIOS
Boot menu
Izbereš Windows 8
Lion29 ::
Tako nekako je:
BIOS
Boot menu
Izbereš Windows 8
lol, wonder why :D
Nice trick!
Looooooka ::
Ammm...sej se ni final verzija.Mene moti samo to, da ko kliknes start meni odletis nazaj na tist metro screen.ampak ok....motil me je tudi ctrl+alt+delete in tist fancy gui namesto taskbara.
Mogoce so pa zracunali, da smo ze vsi tok stari, da se bomo kmalu stegnili in stavijo na mladino...ki jih pac lahko navadijo na nov vmesnik :)
matejdro ::
Developer Preview je namenjen razvijalcem aplikacij za tablične uporabnike, zato so verjetno bolj delali na tabličnem vmesniku in pride desktop vmesnik kasneje.
techfreak :) ::
Task manager (verjetno to misliš) se mi zdi veliko boljši.
To tudi mene moti, tisti fix pa mi potem ne omogoča uporabe Metroja.
Jst ::
Lahko kdo da screenshot tega novega task managerja?
Jst ::
Mešani občutki...
| » | Nadgradnja Windows 10 (strani: 1 2 )Oddelek: Pomoč in nasveti | 32841 (27961) | R1710 |
| » | Kaj je boljše? W7 ali W8? (strani: 1 2 )Oddelek: Operacijski sistemi | 19920 (15737) | Hayabusa |
| » | Windows 8 uvaja hitri zagon (strani: 1 2 3 )Oddelek: Novice / Operacijski sistemi | 38006 (32195) | Jst |
| » | Windows 8 neuradno drugo leto (strani: 1 2 )Oddelek: Novice / Operacijski sistemi | 30688 (27710) | darkolord |
| » | [Windows Vista] Izboljšanje zagonskega časa s pomočjo Windows Performance Toolkit (WP (strani: 1 2 )Oddelek: Operacijski sistemi | 13039 (10023) | vbohinc |
