Morphlingov MK4 v tujih rokah?
J.F.K. ::
Na Overclockers forumu se omeni Morphlingov blok. Tema drugace govori o testu pretoka dveh radiatorjev. Avtor teme je SemiCycle. Slovenec, Morphling sam ali tujec?
http://www.ocforums.com/archive/thread/...
IZSEK IZ FORUMA
"SemiCycle
You must be talking about my MK4. The waterblock is fine, but that picture does make it look like it is cracked. The thin line near the barb is teflon tape, and the stuff to the right is trapped air. It is an old picture that was taken while filling the system.
A more recent picture is below. As you can see, that piece of teflon tape is still hanging there :). The crappy tubing in the bottom picture has been swapped out for clearflex tubing. No kinks now.
[IMG]http://members.cox.net/semicycle/system...
[IMG]http://members.cox.net/semicycle/lian/0...
TribesMan ::
Jap morphlingovi bloki so kar dobro znani po tujini, ne samo na overclockers.com. Tudi na xtremesystems.org in procooling.com se velikokrat omenjajo. Pač dobro blago se samo hvali...
TribesMan
J.F.K. ::
Aha, no to pa nisem vedel, da seze dober glas celo tako dalec.
Sem pa poiskal par tem v katerih je sodeloval morphling na extremesystems.org
Kar zanimivo branje in seveda hvaljenje njegovih izdelkov.
V bistvu opazam, da rabim nov blok. :)
Za vse navijalce CPU Pentium 4 (3.0 GHz)
Oddelek: Navijanje
362296 (1929) Good Guy
forward z xp na linux
Oddelek: Omrežja in internet
101299 (1161) CCfly
MK4 aka. Morphling Kinetic (strani: 1 2 3 )
11714834 (10194) Boki_
prevajalnik
Oddelek: Programiranje
102212 (2083) goku :)
Kje kupit stvari za vodno hlajenje?
303269 (2519) Eddy
