API getopenfilename in allowmultiselect
mp218 ::
Private Declare Function GetOpenFileName Lib "comdlg32.dll" Alias "GetOpenFileNameA" (pOpenfilename As OPENFILENAME) As Long
vse dela lepo in prav
...ko pa dam allowmultiselect...
OFName.flags = 512
sem mi pokaže tisto arhaičn filedialog od win95!
Dela pa normalno. Samo je neprikladno, ker so 2 filedialoga normalna tretji pa drugačen...
mp218 ::
A set of bit flags you can use to initialize the dialog box. When the dialog box returns, it sets these flags to indicate the user's input. This member can be a combination of the following flags.
OFN_ALLOWMULTISELECT
Specifies that the File Name list box allows multiple selections. If you also set the OFN_EXPLORER flag, the dialog box uses the Explorer-style user interface; otherwise, it uses the old-style user interface.
....malenkosti ubijajo, kajneda ;)
VB.net Excel v Tif
Oddelek: Programiranje
121528 (1427) saule
Dober program za delo na daljavo - brezplacen
Oddelek: Programska oprema
82118 (2001) OwcA
Dvd Podnapisi
Oddelek: Zvok in slika
213561 (3142) Lime
Pomen odstranjevalne datoteke - swap filea? (strani: 1 2 )
Oddelek: Operacijski sistemi
558376 (7350) andrej
Fast Forward DV
Oddelek: Sedem umetnosti
171653 (1498) simy
