Dober program za delo na daljavo - brezplacen
Cokolesnik ::
Poleg Remote desktopa, ki je del WindowsXP bi potreboval kaksno dobro alternativo, vendar za brezplacno uporabo tudi v podjetju oz. v poslovne namene.
Ima kdo kaksno izkušnjo oz. ime? :\
Uporabniki naj pred pisanjem sporočil uporabljajo iskalnik www.google.com.
Čokolešnik ne vsebuje nobenih aditivov, konzervansov ali umetnih barvil.
Wox ::
VNC.
Commodore 64
sash ::
RealVNC, ThinVNC
Think different...
TOROiD Group
Ziga Dolhar ::
V čem so pravzaprav razlike med raznimi vnc-ji?
https://dolhar.si/
Cokolesnik ::
Kako bi izklopil full screen, ko se povežem na oddaljen računalnik v RealVNC ?
Lith ::
takole piše:
realvnc.com/products/free/3.3.7/winvncviewer
Full-screen mode
The VNC viewer can be switched into a fullscreen mode. This is particularly useful when connecting to a remote screen which is the same size as your local one. If the remote screen is bigger, you won't get any scrollbars, but you can scroll by bumping the mouse against the edge of the screen.
To leave fullscreen mode you must disable it from the menu, but the menu is no longer visible! So you have to bring the taskbar to the front by typing Ctrl-Esc Esc, and then right-click on the vncviewer icon. A dialog box will appear when you select fullscreen mode to remind you of this; if, after a while you get annoyed with the dialog box, you can disable it by creating a DWORD registry value named
HKEY_CURRENT_USER\Software\ORL\
VNCviewer\Settings\SkipFullScreenPrompt
and setting it to 1.
torej greš v meni in ga izklopiš takrat ko se priključiš
¤ black holes rule; I like the speed, speed kills ¤
Cokolesnik ::
Ctrl+Esc+Esc ne deluje? :\
berta ::
Zame je še vedno najboljši UltraVNC.
OwcA ::
Putty. ;)
prenos podatkov med računalniki
101745 (1662) Voluharr
VNC+ varnost + dinamični IP. Kako ??
Oddelek: Omrežja in internet
354945 (3961) flisko
Windows Remote za začetnike
92316 (2016) Lincolin
RealVNC WinXP -> Mandriva
Oddelek: Programska oprema
71370 (1287) DEFA
povezava na oddaljen rač
131991 (1813) waters
