Forum » Programiranje » API getopenfilename in allowmultiselect
mp218 ::
Private Declare Function GetOpenFileName Lib "comdlg32.dll" Alias "GetOpenFileNameA" (pOpenfilename As OPENFILENAME) As Long
vse dela lepo in prav
...ko pa dam allowmultiselect...
OFName.flags = 512
sem mi pokaže tisto arhaičn filedialog od win95!
Dela pa normalno. Samo je neprikladno, ker so 2 filedialoga normalna tretji pa drugačen...
OFName.flags = 512
mp218 ::
A set of bit flags you can use to initialize the dialog box. When the dialog box returns, it sets these flags to indicate the user's input. This member can be a combination of the following flags.
OFN_ALLOWMULTISELECT
Specifies that the File Name list box allows multiple selections. If you also set the OFN_EXPLORER flag, the dialog box uses the Explorer-style user interface; otherwise, it uses the old-style user interface.
....malenkosti ubijajo, kajneda ;)
| » | VB.net Excel v TifOddelek: Programiranje | 1528 (1427) | saule |
| » | Dober program za delo na daljavo - brezplacenOddelek: Programska oprema | 2118 (2001) | OwcA |
| » | Dvd PodnapisiOddelek: Zvok in slika | 3561 (3142) | Lime |
| » | Pomen odstranjevalne datoteke - swap filea? (strani: 1 2 )Oddelek: Operacijski sistemi | 8376 (7350) | andrej |
| » | Fast Forward DVOddelek: Sedem umetnosti | 1653 (1498) | simy |
