Radeon 9800pro @ 9800XT
_spirit_ ::
Se je že kdo ukvarjal z flešanjem 9800pro v 9800xt?
  • spremenil: _spirit_ ()
so se ze ja..velikrat.:)
_spirit_ ::
Kdo pa? Bi imel par vprašanj za tega, ki mu je to že uspelo :P :D
nevem ce je to smiselno, ker 9800pro nikol ne bo xt pa kakorkoli obrnes. r360 je malenkost optimiziran, tko da se v malenkostih razlikuje od r350, navijes lohk pa tut pro na take frekvence bp.
boštjan ::
mislm,da je edina razlika v rahlo višjih frekvencah in v overdrive
_spirit_ ::
Baje da pridobiš do 20% na zmogljivosti, zato sem se odločil da poskusim, pogledal sem tudi malo morje testov po internetu >:D in vsi so bili zelo obetavni.
Drugače sem pa sledil navodilom flešanja na tej strani:
http://www.3dmaxx.net/articles/xtflash/
Before we flash our 9800's we need to prepare ourselves with what we will need to flash the BIOS. Below is a list/link to everything you will need:
An ATI Radeon 9800NP or Pro capable of 412MHz core clock and 365MHz (730MHz DDR) memory clock
Flashrom 1.3 (Can be downloaded here)
A copy of the ATi Radeon 9800XT BIOS (Can be downloaded here)
A bootable floppy disk (Can be downloaded here)
The desire to have a 9800XT for a fraction of the cost
Now that we know exactly what we need lets begin to flash this bad boy, shall we? Ok, you will begin by creating your bootable floppy disk and placing the extracted flashrom files (DOS4GW.exe, FLASHROM.exe, FLASHROM.rom). Once you have moved these files over to the disk you can place the BIOS file (ATI.9800XT.256.Samsung.bin) on the disk and prepare to flash. Once you restart your PC with the floppy disk in the drive you should see "Caldera Dr.Dos 2.xx" on your screen. Once everything is loaded you are ready to flash. Before you flash however, I recommend backing up your current BIOS by typing " flashrom -s 0 original.bin" at the A:\ prompt. Your BIOS is now saved to the floppy disk and you can use this in case of a bad flash.
Now you are finally ready to flash. After the BIOS has been saved to your floppy type "flashrom -p 0 ATI.9800XT.256.Samsung.bin". Flashrom should begin to flash your BIOS and you should see a final message saying "6xxxx of 6xxxx bytes verified". Once you see this message your 9800 is successfully flashed with the Radeon 9800XT BIOS. Now restart your system and continue to install the drivers of your choice.
"""A word of caution, after flashing your monitor may flicker off while loading windows. This is normal and your monitor should return in the on mode within a few seconds"""
Also when you are installing your video drivers the same thing will take place. Do not worry people, this is normal.
If you have followed these steps you should now have a fully functional Radeon 9800XT. Continue to page 2 for screenshots and a conclusion.
Vse je šlo lepo in prav, dokler nisem prišel do dela katerega sem dal med """ ... tistih few second ni bilo nikoli... monitor se sploh ne užge več. Kje bi se skrival problem pa ne vem. Predvidevam da v ramih, ker je so to navodila za flešat kartice z samsungovimi rami... jaz imam gor pa Hynix-ove. Bi znalo bit to problem?
boštjan ::
ja to bi zanlo bit.upam da si si naredo backup
_spirit_ ::
Sem sem, če ne me zdaj ne bi bilo tukaj :D :D
_spirit_ ::
Zato me zanima če je že komu uspelo najt oziroma ima bios za radeon 9800 xt z hynix-ovimi rami?
boštjan ::
evov sekciji 9800 čisto na dnu sta dva biosa za hynih rame
_spirit_ ::
Prvega, ravno s te strani, sem že poskusil, pa ni delal. Bom še drugega. ;)
boštjan ::
kaj pa tu si že bil?
_spirit_ ::
Jp, samo tukaj sta dva samo za samsungove rame... :( hvala vseeno
boštjan ::
kaj pa malo rusko,eden je,samo ne vem za kake rami je
GF 6200 v 6600
Oddelek: Navijanje
273146 (2176) a13misko
Kako aktivirati senzor za temperaturo na grafični?
61890 (1712) Pyr0Beast
radeon 9800 pro -> XT
Oddelek: Navijanje
132118 (1782) ricola78
QDI Kudoz 7x KT400 napačen bios
61867 (1800) kihc
Updateanje BIOSa
132410 (2161) jlpktnst
