Forum » Pomoč in nasveti » QDI Kudoz 7x KT400 napačen bios
Mediator ::
Imam slednjo plato, ki me je začela malce zajeb...
Torej, flashal sm bios, ampak, z nepravim biosom, zamenjal sm z različico 7a, še sam nevem kak.
Seveda, se za tem rač. ni zagnal niti do biosa...tema, potem sm resetu ročno(baterija ven in not), tud jumper sm probu,spet nič...kaj mi je za nardit...zdj še sam včasih piska po presledkih...
Hvala za odg.
Hvala za odg.
El Barto ::
Poskusi tole KLIK
Doma imam pa še nekaj navodil za AWARD BIOS, ki ti jih lahko tudi pošljem, vendar šele popoldne.
LP El Barto
LP El Barto
El Barto ::
Tole je pa še drug del tega.
BAD FLASH BIOSA
ˇ If your motherboard BIOS is supporting boot block, then it will allow you to boot from a floppy disk and reflash. Though in early versions it only supports ISA VGA cards (Meaning no display for PCI/AGP VGA cards).
o How to use boot block on Award BIOS
§ Create a standard bootable floppy disk
§ Add a good(older) BIOS image file along with flash utility
§ If in the "No Display" scenario then create an AUTOEXEC.BAT which executes a command line BIOS flasher to the BIOS, Ex. :
awdflash.exe a7v1005c.awd /py /sn
§ Attach only the following devices : CPU, RAM, Keyboard, Floppy (No HDD, CD-ROM, Sound, Modem, NIC what so ever)
§ Insert the created floppy disk and boot the machine and it pray that it starts reading from your floppy drive
§ It should then make some beep codes
§ 2 short beeps = no bootable diskette in drive A
§ continual short beeps = no floppy disk drive
§ continual long beeps = programming finishes, reset your system
o How to use boot block on AMI BIOS
§ Format a floppy disk
§ Copy a good(older) BIOS image file to the floppy disk
§ Rename the BIOS image file on the floppy disk so the filename becomes "AMIBOOT.ROM"
§ Start the machine with the floppy disk in drive
§ Hold down the keyboard keys CTRL+Home to force the update
§ After some minutes the system will beep 4 times meaning the flashing is complete
ˇ Use the risky Hot Flash, if you know someone with a similar motherboard as you :
o Let him boot from a floppy with flash utilities and BIOS image like he was going to flash his own motherboard
o Take the BIOS chip out of your motherboard
o Exchange it with the one in his motherboard while his machine is running
o Reflash your BIOS chip in his motherboard using the flash utilities on the floppy
o Shutdown his machine put the BIOS chips back
Upam, da ti bo pomagalo, deluje pa 100% (preverjeno)
LP El Barto
BAD FLASH BIOSA
LP El Barto
DejaVu ::
pol se pa nobenemu ni tak uspelo sfukat biosa kot meni :p
z disketo ni nic delovalo, samo servis in da je oni dobil neko maticno, ki je mela isti chip.
kihc ::
Hmmm, meni se je zgodilo nekaj podobnega pa preden vse skupaj dam na reflash bi rad se sam poskusil kaj narediti, samo ne razumem tega cisto povsem...
- Torej na disketo vrzem star bios in awdflash, potem pa v beleznici napisem awdflash.exe [ime biosa].awd /py /sn in shranim z imenom AUTOEXEC.bat
In potem upam da bo delovalo?
| » | Piskanje kompa in ta se ne prizge!Oddelek: Strojna oprema | 1918 (1771) | Morph3us |
| » | Narobe flashan bios na Asus CUSL2-C Black PearlOddelek: Pomoč in nasveti | 2558 (2233) | SkIDiver |
| » | Bios 8rda+Oddelek: Navijanje | 1350 (1248) | kuglvinkl |
| » | ABIT NF7-S rev 2.0Oddelek: Strojna oprema | 2550 (1825) | MALJUTKA |
| » | Šla plata ob updatu biosa?Oddelek: Pomoč in nasveti | 1856 (1509) | ru7 |
