Forum » Mali oglasi » 32GB DDR4 ECC Registered (RDIMM) SK hynix, 2933 MHz (PC4-2933Y), model HMA84GR7JJR4N-WM
Keyser Soze ::
Prodam dve 32GB "palčki" server rama. Rabljeno, brezhibno delujoče.
Specifikacije:
Capacity 32GB
Memory Type DDR4
Speed 2933 MHz
PC Rating PC4-23400
Voltage 1.2V
CAS Latency (CL) CL21
Form Factor RDIMM (Registered DIMM)
Pins 288-Pin
Error Correction ECC (Error Correcting Code)
Features Registered, Server Memory, High-Efficiency
Use Case Server, Enterprise Workloads
(https://memory.net/product/hma84gr7jjr4...
Prevzem Ljubljana.
Info na tel: nič tri ena tri nič ena šest sedem devet
Cena: 140 EUR po kosu oz. po dogovoru
Specifikacije:
Capacity 32GB
Memory Type DDR4
Speed 2933 MHz
PC Rating PC4-23400
Voltage 1.2V
Pins 288-Pin
Prevzem Ljubljana.
OM, F, G!
