Forum » Operacijski sistemi » EndeavourOS Dual Monitor
errhec ::
Išči na njihovi STRANI.
It should be system settings>hardware>display and monitors. Here you can set resolution and position of each. You will also want to disable “unify outputs” this is what will make them mirror each other instead of extending the desktop between them.
dd
| » | Seznam Airdropov! Free crypto (strani: 1 2 3 4 … 24 25 26 27 )Oddelek: Kriptovalute in blockchain | 194537 (14405) | sharma08 |
| » | Steel Division: Normandy 44Oddelek: Igre | 1970 (1687) | opeter |
| » | Poštnina pri Amazon.co.uk?! Pa smo v EU al ne?!Oddelek: Loža | 11167 (10738) | GregiB |
| » | Kaj za vraga je to RAID?Oddelek: Pomoč in nasveti | 2826 (2491) | krucymucy |
