python flappy bird
python flappy bird
dejco_h ::
dober dan malo se igram in delam nekoč popularno igro flappy bird v pythonu.Ampak ker se naletel na težavo se obračam na vas napaka je zelo banalna ampak dejansko ne vidim napake v kodi.torej namesto da bi se mi pipes(cevi) pojavljale pred mano se z nekega čudnega razloga pojavljajo za mano. kaj mi lahko prosim samo kdo pove ali namigne kje je napaka?
Hvala vsem za odgovore že vnaprej
import pygame
import sys
import random
pygame.init()
WIDTH,HEIGTH=551,720
win=pygame.display.set_mode((WIDTH,HEIGTH))
pygame.display.set_caption("FLAPY BIRDS")
black=(0,0,0)
clock=pygame.time.Clock()
bird_images = [pygame.image.load("assets/bird_down.png"),
               pygame.image.load("assets/bird_mid.png"),
               pygame.image.load("assets/bird_up.png")]
skyline_image = pygame.image.load("assets/background.png")
ground_image = pygame.image.load("assets/ground.png")
top_pipe_image = pygame.image.load("assets/pipe_top.png")
bottom_pipe_image = pygame.image.load("assets/pipe_bottom.png")
game_over_image = pygame.image.load("assets/game_over.png")
start_image = pygame.image.load("assets/start.png")
scrool_speed=1
bird_start_position=(100,250)
class Pipes(pygame.sprite.Sprite):
    def __init__(self,x,y,image):
        pygame.sprite.Sprite.__init__(self)
        self.image=image
        self.rect=self.image.get_rect()
        self.x=x
        self.y=y
    def update(self):
        self.rect.x-=scrool_speed
        if self.rect.x<=- WIDTH:
            self.kill()
class Bird(pygame.sprite.Sprite):
    def __init__(self):
        self.image=bird_images[0]
        self.rect.center=bird_start_position
        self.image_index=0
        self.vel=0
        self.flap=False
    def update(self,user_input):
        self.image_index+=1
        if self.image_index>=30:
            self.image_index=0
        self.image=bird_images[self.image_index//10]
        self.vel+=0.5
        if self.vel>7:
            self.vel=7
        if self.rect.y<500:
            self.rect.y+=int(self.vel)
        if self.vel==0:
            self.flap=False
        self.image=pygame.transform.rotate(self.image,self.vel*-7)
        if user_input[pygame.K_SPACE] and not self.flap and self.rect.y>0:
            self.flap=True
            self.vel=-7
class Ground(pygame.sprite.Sprite):
    def __init__(self,x,y):
        self.image=ground_image
        self.rect.x,self.rect.y=x,y
    def update(self):
        if self.rect.x<=-WIDTH:
            self.kill()
def main():
    bird=pygame.sprite.GroupSingle()
    bird.add(Bird())
    pipe_timer=0
    pipes=pygame.sprite.Group()
    x_pos_ground,y_pos_ground=0,520
    ground=pygame.sprite.Group()
    ground.add(Ground(x_pos_ground,y_pos_ground))
    run=True
    FPS=60
    while run:
        for event in pygame.event.get():
            if event.type==pygame.QUIT:
                pygame.quit()
                exit()
        win.blit(skyline_image,(0,0))
        if len(ground)<=2:
            ground.add(Ground(WIDTH, y_pos_ground))
        usr = pygame.key.get_pressed()
        pipes.draw(win)
        ground.draw(win)
        bird.draw(win)
        pipes.update()
        ground.update()
        bird.update(usr)
        if pipe_timer<=0:
            x_top,x_bottom=550,550
            y_top=random.randint(-600, -480)
            y_bottom=y_top+random.randint(90,130)+bottom_pipe_image.get_height()
            pipes.add(Pipes(x_top,y_top,top_pipe_image))
            pipes.add(Pipes(x_bottom,y_bottom,bottom_pipe_image))
            pipe_timer=random.randint(180,250)
        pipe_timer-=1
        clock.tick(FPS)
        pygame.display.update()
if __name__ == '__main__':
    main()
Return ne deluje[python]
Oddelek: Programiranje
81477 (1341) Jonatan
[Python3] Izvajanje ukazov po določenem času
211966 (1576) noraguta
Predstavitev dvojiškega drevesa z seznamom
142692 (2292) ktka
[Python]Naloga z razredi in dedovanjem
101540 (1292) ktka
python -slovar
223800 (2779) Valex86
