Forum » Pomoč in nasveti » Powershell exe problem Windows 7 x64
fb99 ::
Pri neuspešnem nameščanju programske opreme se prikaže sporočilo: unable to execute file: powershell exe create process failed; code 2
OS: Windows 7 Ultimate x64
errhec ::
This error can occur if you have anti-virus software installed and the anti-virus software is incorrectly reporting that one of the files installed contains a virus.
Unfortunately anti-virus software often gives "false positives", i.e. wrongly concludes a file contains a virus.
Here's what I inadvertently tried and it worked: I say inadvertently because I have no idea how I stumbled upon this dialog box as I didn't even know it existed.
Control Panel
Windows Defender Firewall
Allowed Apps
Randomly highlighted an app
Clicked change settings (upper right), at which point Allow another app becomes available at bottom right
Clicked Allow another app at bottom right
Browsed to downloads folder where EZVid was saved
Error message is gone!
Control Panel
Allowed Apps
dd
| » | Bitdefender AVOddelek: Programska oprema | 3840 (3359) | bambam20 |
| » | Nemški zvezni trojanec na tapetiOddelek: Novice / Varnost | 9184 (6956) | jype |
| » | Nov članek: "All your firmware are belong to us" (strani: 1 2 3 )Oddelek: Novice / Nova vsebina | 20157 (16997) | arrigo |
| » | Win XP SP2 in BlutoothOddelek: Pomoč in nasveti | 2434 (2279) | jast |
| » | Ms blast ali zakaj se mi sistem ugaša po eni minuti? (strani: 1 2 3 4 5 6 )Oddelek: Pomoč in nasveti | 44169 (19151) | brainiac20 |
