NVIDIA GeForce RTX 50 (Blackwell)
Nova serija Nvidia kartic RTX 50 verjetno leta 2024.
NVIDIA Next-Generation Blackwell GPU Architecture Will Launch In 2024
https://wccftech.com/nvidia-next-genera...
NVIDIA GeForce RTX 50 Series Rumors
Driven by “Blackwell” architecture, named after David Blackwell
Entirely new SM structure
Chiplet design expected for flagship models
“Massive, MCM monstrosity” already being evaluated
De-noising accelerator added to ray tracing pipeline
“Biggest performance leap in NVIDIA history”
NVIDIA “very” determined to keep its lead over AMD
https://www.thefpsreview.com/2022/12/19...
TSMC might lower 3nm costs to attract companies like NVIDIA and AMD
In the graphics and CPU space, it's expected that NVIDIA's Ada Lovelace successor, Blackwell, will utilize the 3nm process.
https://www.tweaktown.com/news/90012/ts...
Če bodo res prišli modeli RTX50xx leta 2024, potem se splača preskočiti RTX40xx. Sem hotel delati nadgradnjo iz RTX3080 na RTX4070Ti, zgleda da bom raje počakal :D
scythe je izjavil:
Kolk % je RTX 4070 Ti hitrejša od tvoje trenutne grafične?
Jarvice ::
4070 Ti je overall ~25% hitrejša od 3080.
AMD Ryzen 7 5800X3D - Gigabyte B450 Aorus Elite - MSI GeForce RTX 4080 SUPRIM X
G.Skill 32GB 3600 - Be quiet! Straight Power 11 850 - Be quiet! Pure Base 500DX
Dell 32 Curved 165Hz S3220DGF - LG OLED55B13LA HDR 120Hz 4K - Sony PlayStation 5
Jarvice je izjavil:
Za 25% pač ne menjaš, vsaj ne pri trenutnih cenah... Ajde za 100%...
Em, kje ste pa 25% našli? Kar sem jaz gledal teste v 4K je tam tam z 3080. Par FPS bolje. 1080p pa itak nikogar ne zanima več leta 2023.
Jarvice ::
4070 Ti za 4K? :))
Lepo vas prosim... Če se greš high refresh rate 4K, še vzameš 4090 ali pa pusti 4K pri miru.
Kurzweil ::
Jarvice je izjavil:
4070 Ti za 4K? :))
Za kaj za boga bi rabil več kot +-100fps :D Kao neki pro gamerji?! :)) Že 3070ti je dovolj za povsem soliden 4k gaming...
Dejstvo je, da moraš imeti dober razlog za desktop 4k. Z dpi scalingom je itaq vse isti šmorn, od 1080p naprej.
Še najbolj se pri zmernem uporabniku pri delovnem prostoru pridobi s kakšno 32" širokozaslonsko 1440p situacijo.
Osebno poznam situacije, kjer 120Hz zmožni 4k blestijo, ampak ne pri novodobnih igricah.
Pa še pri grafični in porabi prihraniš, če ti ego ne napumpa kakšnega dragega 4k na namizje. ;)
Torej, 3nm nVidia grafične bodo zmogle 1440p pri nižji porabi, kar je vsekakor želen napredek za vsakega razgledanega gamerja.
RedDrake ::
Modi niso preveč za šale, ok, pa naj bo bolj resno napisano.
1. Večina današnjih "gainov" je za našo percepcijo tako inkrementalnih, da je veliko vprašanje če bi nek povprečnež v double blind testu sploh opazil razliko. Recimo razliko med 60fps in 120fps. Ali pa razliko med 144Hz ali 240Hz monitorjem.
Ali razliko med 1440p ali pa 4k v igri.
2. Vse te "izboljšave" se v zadnjih nekaj letih delajo predvsem na račun porabe. Entry level grafika je šla iz 50-70W na 120-150W. Ja, ni čudno da je perf 3x boljši, če je pa poraba tudi več kot 2x višja. Zato sem pisal o 8k in 240kHz monitorjih in jedrskih. Ker v to smer gre. Čeprav že 4k ni "smiseln" ker detajlov ni nič več in ljudje že težko ločimo 60fps in 120fps kaj šele 120 in 240.
Me res zanima kaj bo tisti dogodek, ki bo povzročil, da bo šel trend kontra.
No vsekakor, lahko upamo, da bo nova generacija Nvidia imela vsaj kakšno "normalno" pasivno grafično, tako kot je bilo to "normalno" več kot 20 let do cca 2019.
Tilen88 ::
In kolk bodo te grafe od ngreedije ? 1500+?
RedDrake je izjavil:
Ločiti med 60 in 120 ne bi smelo biti pretežko (po tem, ko se razvadiš, kar je praktično takoj).
Med 144 in 240 pa mislim, da malo težje (ne vem, ker nisem poskusil). To se verjetno pozna, ko malo dlje sediš - glede na "utrujenost".
Gamerji, dajte prepričati filmarje, da je 24fps za v muzej. Ko to dosežete, vam bom verjel, da je 60fps premalo.
pegasus je izjavil:
Sej je in produkcija se pocasi sili na 60 FPS. Preskoki med slikami so pri npr. pleletih pokrajine zelo moteci. Je pa res. da pri vecini scen ni tako hitrih premikov celotne slike in je manj opazno.
Osebno opazim razliko med 60 Hz in 144 Hz, sam ni tako velika, da bi se dol metal. CE pa FPS pade po 50, bog ne dej do 30, je pa grozno.
Če govorice držijo - "Biggest performance leap in NVIDIA history"
Se pravi bo tole velik skok :)
Kurzweil ::
tikitoki je izjavil:
pegasus je izjavil:
Aja? Tole me pa res zanima, o čem govoriš... imaš kakšen source ali referenco... tole pa me res zanima...
Okoli kolk se vrtijo cene npr 4080 in 4090?
Kurzweil ::
mtosev je izjavil:
Pojdi na Geizhals.de pogledat... tam mi je všeč graf, kjer lahko spremljaš gibanje cen za vse komponente... tako da vsaj enkrat tedensko grem na Geizhals malce preverit, kako gredo stvari...
Nvidia Might Switch to GDDR7 VRAM for RTX 50 Series GPUs
https://www.extremetech.com/gaming/nvid...
hamez66 ::
pegasus je izjavil:
V igri, ki podpira maxfps, naštimaj maxfps 24 in potem poročaj, če kaj šteka.
NVIDIA GeForce RTX 50 "Blackwell" GPU Rumors: 3nm Monolithic, Faster Clocks, Over 2x Faster Than Ada RTX 40
https://wccftech.com/nvidia-geforce-rtx...
mahone ::
Vir pa valjda tech tuberji z inside info ;((
The latest rumors come from TechTubers, RedGamingTech & Moore's Law is Dead,...
Maxlos ::
pegasus je izjavil:
Naroči en 144 Hz/FPS monitor na netu. Lepo odpakiraj pa ga uporablaj en teden samo za delo in browsanje. Sporoči mi, kako bo izgleda sedaj scroll na 24FPS-jih, ko boš začel uporabljati stari 60 Hz monitor.
Barking up the wrong tree
Ne skrbi zame, sem na 75Hz že od časa 14" crt monitorjev naprej ... filmarje prepričajte, to sem rekel :) Nazadnje ko sem jim začel pametovati o >24fps, so me skoraj nagnali :D
Med 30, 40 in 60Hz je očitna razlika, se vidi iz aviona. Med 60 in 80Hz se še tudi takoj opazi. Nad 120Hz pa je že bolj odvisno od vsebine. Če mene vprašaš je 80-120Hz nek sweet spot. Seveda pa je zelo odvisno od uporbnika. Za nekoga, ki ure dnevno nažiga nekaj ultra hitrega, bo ta meja višja. Definitivno pa ne bi nikomur priporačal, da si danes kupi 60Hz monitor.
mirancar ::
men je med 60 in 120/144 očitna razlika, med 120 in 144 ne opazim razlike, verjetno tudi od 100-144 (gsync) ne. opazim pa očitno razliko v pixel response time, tudi če je na 60hz, OLED zmaga. tko da treba se je pogovarjat tudi o pixel response time, ne samo o Hz
Samo ko govorimo o OLED 120Hz, smo na 1000EUR+. PC jurja in pol, grafična jurja, monitor jurja pa si na 3500EUR za nek soliden sistem :D
  • spremenil: Magic1 ()
mahone ::
pegasus je izjavil:
Pa ja ne gledas filmov v 60fps? Opera effect zaradi motion interlacinga pri 4k je prav motec nevem kdo bi gledal ta zmazek?
PARTyZAN ::
Interlacinga? Verjetno misliš interpolationa?
Idealno bi bilo, če bi filmarji dejansko snemali na večjem frameratu, ne da si moramo frejme "izmišljevat". Hobbit je bil pri nas recimo na voljo v HFR (48FPS) in je bil milina za gledat proti ostalim filmom - pri panih in hitrih scenah se sploh pozna, nič več zmazanih diapozitivov.
Zmazek je dobesedno tisto, kar dobiš pri "filmskih" 24FPS.
mahone ::
In ravno zaradi je ogromno ljudi sovrazilo Hobbit :))
To je tebi vsec?
PARTyZAN ::
To specifično ne, ker je interpolacija slaba. Če bi bilo snemano na višjem frameratu pa bi bilo boljše, ja.
RTX 50 BLACKWELL Is CRAZY Fast - Specs & Performance Targets
RTX 5090 release date speculation and expectations
https://www.wepc.com/gpu/guide/rtx-5090...
RTX 4090 - October 2022
RTX 3090 - September 2020
RTX 2080 - September 2018
Drugo leto RTX 5090 ? :P
  • spremenil: oo7 ()
mailer ::
Drugo leto je refresh +25% rama na vse. :)
Polda ::
Rtx 5090 to bo za 8k igranje. Takt 3ghz in vram gddr7 512 bitov 2tb na sekundo.
R.i.p. AMD
Rumor | Nvidia RTX 50 GB102 Blackwell early internal performance gains only in range of Pascal to Turing and not 2.6x from AD102, increased SM counts on the anvil
https://www.notebookcheck.net/Nvidia-RT...
Prve govorice pa so bile "Biggest performance leap in NVIDIA history"
Furbo ::
Polda je izjavil:
R.i.p. AMD
Kakšen 8k, morda bo igre izdelane z Unreal Engine 5 poganjal v 4K pri 60FPS. Morda.
HUGE Performance Leap For RTX 50 Blackwell & Nvidia Teases Date
Nvidia RTX 5000 graphics cards rumored to launch next year with massive performance increase
https://www.techspot.com/news/98922-nvi...
Morajo zdaj dobre novice šopat, da bo delniški trg letel naprej. Samo kaj jim je pa problem dosežt "massive increase", uporabijo 2 4090 čipa, 4 slotno kartico, 800W in imajo hitro 2x performance. Seveda 2000$+ za 5090...
dolenc ::
MASSIVE PERF IMPROVEMENT!!!!... Torej 3060ti=>5060non-ti ! Noro :P
Morate brati med vrsticami. Dodali bodo dodaten fake frame in nasponal marketing na 200%.
Moja naslednja grafa verjetno. Upam, da cene ne bodo preveč poskočile.
Polda ::
mtosev je izjavil:
Saj rad podpiraš velike korporacije pa plačuj visoke cene. To ti je usojeno.
Saj ni problema. Sem se že sprijaznil, da bom za grafo plačal cca 1500€.
Na internetu o takih kupcih, ki prodajo ledvico za igračkanje obstajajo različni reki in izrazi:
- "Money can't buy you skill."
- Ultra Andy
  • spremenil: Jarno ()
Jarno je izjavil:
- Ultra Andy
Vmes imas pajace, ki sam pisejo kaj so domnevno kupili.
yayo ::
100 ljudi 100 čudi ampak zgleda kot, da so se vse škrtice zbrale na slotechu. Saj ni nič slabega biti škrtac, gre pač za eno od mnogih življenskih strategij pogojenih z geni ali vzgojo. Ampak, ko je zavist zraven (in ponavadi je) potem pa je zabavno. :P
Anekdota: imel sem kolega elektrotehnika, ki je vse računalniške komponente kupoval na sejmih rabljene opreme v Italiji. Obenem je plačeval davek na obresti na banki in bil zaradi tega strašno jezen, potem pa je umrl pri 58 letih.
  • spremenil: yayo ()
Nvidia roadmap shows GeForce RTX 5000 cards set for 2025 launch
1 / 62
S.T.A.L.K.E.R. 2: Heart of Chornobyl (strani: 1 2 3 4 … 109 110 111 112 )
Oddelek: Igre
5592795564 (81) Gregor459
NVIDIA GeForce RTX 60 (Rubin 3nm) (strani: 1 2 )
9710875 (572) FlyingBee
Prvi geforci serije RTX 50 prispejo še ta mesec (strani: 1 2 )
5913337 (10148) bm1973
NVIDIA Blackwell (3nm GPU) (strani: 1 2 )
8910056 (5526) bluefish
