12th Gen Intel Core - Alder Lake
9 / 35
Ja, Atom jedra na speedu.. Anandtech lepo pojasni. V bistvu "Skylake" jedra.
Skyman ::
Izid bo konec oktobra,zacetek novembra (slika nakoncu)
Intel 12th Gen Alder Lake Desktop CPU Family
There's nothing much to talk about regarding the Alder Lake Desktop CPUs except the fact that the leaker mentions the exact P-core clock speeds. The Intel Core i9-12900K would operate at 3.20 GHz base and 5.20 GHz boost (TB 3.0), the Core i7-12700K would operate at 3.60 GHz base and 5.0 GHz boost (TB 3.0) while the Core i5-12600K would operate at 3.70 GHz base & 4.90 GHz boost (TB 2.0) boost.
The leaker states that the Non-K versions of the Core i9 and Core i7 CPUs will operate at a 100 MHz lower boost clock. It is also stated that the next-gen Core i3 series won't be a refresh of Rocket Lake and will be based on the Golden Cove core architecture. The iGPU will be the latest UHD 770 series with Xe graphics and the processors will feature support for DDR5-4800 and DDR4-3200 memory. It also looks like Intel may be planning to push forward the release of its entry-level chipsets such as the H670, B660, and H610 to the end of the year though that remains to be seen.
Skyman ::
Sry za dvojni post ne gre editat.
Še ostali 12 gen procesorji i5 ter i3 ter nekaj leak cen
Intel 12th Gen Alder Lake 35W Desktop CPU Lineup Leaks Out - Core i9 With 16, Core i7 With 12, Core i5 With 6 & Core i3 With 4 Cores
https://wccftech.com/intel-12th-gen-ald...
Skyman ::
Intel Core i9-12900K shows up on Ashes of the Singularity benchmark website
https://videocardz.com/newz/intel-core-...
Skyman ::
Intel Core i9-12900K allegedly scores 30K points in Cinebench R23
Gigabyte/AORUS Z690 motherboards for Alder Lake-S CPUs listed by EEC
https://videocardz.com/newz/gigabyte-ao...
Upajmo, da je res in, da bo poraba v mejah normale.
Skyman ::
Ce ne bomo pa 1200w napajalc vzel ane,tko k za grafiko to je zdej in :| cifre so kar lepe po teh leakih bo res 12900 zver za 600€ ce bo seveda.Samo malo bodo z platam nabili te cene,same cudne serije prihajajo ddr4/5
Mislim, da že zaradi modernih graf je logično, da se vzame PSU kateri ima vsaj 1k wattov.
Uradni izid 12. generacije je načrtovan v petek, 19. novembra 2021.
  • spremenil: opeter ()
Skyman ::
mtosev je izjavil:
To glih ne,je pa priporoceno vsaj 850W platinum oz titanium,ali recimo spodnja meja 750w
Sama predstavitev 12gen naj bi bila pa 27.10.
  • spremenil: Skyman ()
keba ::
se pravi še dva meseca do izida, to bom pa še počakal da vidim kakšen bo p/p
Yup. Sedaj je čas za čakanje, ker je izid blizu in samo lahko profitiraš.
strom_15 ::
Intel ponovno v vsej svoji veličini:
Se nad procesorje AMD že zgrinjajo temni oblaki?
Vir: https://racunalniske-novice.com/se-nad-...
Skyman ::
mtosev je izjavil:
Sej to je ze prej bil cas za cakanje,sedaj je res najslabse kupiti neki pc pa nima tukaj veze amd/intel fan prakticno gejmov ni,ce imas 5-6 let stari pc vse lepo poganja.Letos pride 12gen nasledno leto am5.Zakaj bi staro robo kupoval?
strom_15 je izjavil:
Ja potem pa am5 pride bo pa obratna slika,je top ker bo intel z 12 gen blizje kot prejsne generacije definitivno.Plus je pci5.0 imas veliko clankov kaksen odlom bo SSD na 5.0 pci
Kioxia Unveils PCIe Gen 5.0 SSD Prototype Performance - Up To 14000 MB/s Read Speeds & Almost Double The IO Performance Over Gen 4.0 SSDs
https://wccftech.com/kioxia-unveils-pci...
dolenc ::
Odlom ja... Že med sata3 pa nvme pcie3 tist 1%, ki opazi razliko.
Noro :P
Prehod iz hdd na sata ssd je prinesel 4-5x večji bandwidth in 100x nižjo latenco. To se pozna ...
Prehod iz sata ssd na pcie v3 nvme je prinesel 4-6x večji bandwidth in 10x nižjo latenco. To je že težje opazit ...
Prehod iz pcie v3 nvme na v5 nvme bo prinesel 4x večji bandwidth in približno enako latenco ... to za end userja ne bo bistvene razlike. Bo pa za serverje ;)
Nahhhhhh. Nič ne ogrožajo.
Ogrožajo samega sebe, ker nihče ne bo hotel kupovati stare robe.
Še vedno prodajajo NUC z 7. in 8. generacijo procesorjev ter namizne prosecorje 9. generacije v trgovinah.
Odslej bo AMD "stara roba".. Intel bo pa imel na voljo 10. gen za siromake in 12. gen za "rudarje". :)
Bo zanimivo dogajanje.. V prihodnjih dneh in tednih bo čedalje bolj curljalo o DDR5, Z670 ploščah, procesorjih, morda 12VO napajanju.. Potem pa je tu še Win11, zloglasni taks scheduller, DirectStorage, itd, itd.. #Good_pandemic_ times:P
Skyman ::
Ce kdo rabi..
GIGABYTE GeForce RTX 3080 Vision OC 10G LHR, Grafikkarte 1,199€
https://www.alternate.de/GIGABYTE/GeFor...
DarwiN je izjavil:
Nič od tega, kar je v korist everage joe.
Janez počaka leto ali dve in dobi vsa ta zadovoljstva za đabe, a ne.. Tko da so hude novosti dobrodošle za vse.
Skyman ::
Sory za zgorni post šele sedaj opazil my bad :|
Potem bos sam se obicn janez,loh bi bil pa pro"janez" :)).Hja jz dejansko ne kupujem zato ker bi bil glavni janez na vasi,ampak zato ker imam ze stari PC,in sem z razlogom se malo pocakal (ddr5,pci5.0).Kdaj tocno bom to rabil pa noben ne ve.Še vedno bom kasneje lahko bp dal notri pci5.0 SSD recimo,ker ce sedaj bi kupil si z 10 oz 11 gen ali am4 tega "luksuza" nebi mogu privoscit,bi bil spet nov sistem.
DarwiN je izjavil:
Fanboy much? Ostali čakamo na teste. Napovedi so optimistične, sam so bile tud za tiger lake in vsi vemo, da ni prinesel obljubljene revolucije.
Skyman je izjavil:
Da da. cez dve leti bos menjal platformo. Glede na to da je to intlova rev 1 limanja jeder skupaj, ravno nebi bil early adopter.
Skyman ::
MSI confirms Intel Alder Lake launch date
https://videocardz.com/newz/msi-has-jus...
Core i5-12600K Beats Core i9-11900K (Alder Lake)
https://www.guru3d.com/news-story/core-...
Wrop ::
Številke za 10. in 11. gen jim ne štimajo. Nesposobneži eni.
Sicer pa upajmo, da Intelu uspe nekaj dobrega izdati. Naj se boj začne, jaz bom nižje ob reki čakal, da naplavi kakšen dober p/p CPU.
Čas bi že bil za nekaj konkretnega, saj smo vendar že vse od leta 2015 na Skylake IPCju.. Tudi ZEN3 je podoben šmorn kot Skylake oz. prednjači za mišjo dlako. 8700k = 5600X, give or take. V 6+ letih smo v bistvu pridobili le nekaj malega frekvence in pri porabi, edini pravi napredek pa jasno pri številu jeder.
Ampak bi bil že čas, da se tudi pri IPCju kaj premakne.
DarwiN je izjavil:
A res.... 6 Years At 14nm: What Are The Real Gains? Intel 5th Gen vs. 10th Gen Core Architecture
Če bi bila ta Famozna Gen12 tako dobra, Verjetno nebi ustrajal na teh 250+W.
Tako da ja Počakajm mo kaj pride ven, ker bo izid čez kak mesec samo Serija K. Po novem letu pa pa ostale verzije... Čez pol leta pa potem pride Gen 13, potem pa spet sledi nova plata.
Če so te številke in testi, tako fenomenalni, zakaj skrivajo porabo ?
Nihče nič ne skriva. Intel še preprosto ni predstavil arhitekture.. To bo sledilo šele čez mesec dni.
Poraba najbrž ne bo briliantna, ampak tudi slaba verjetno ne.. Še posebej pri workloadu z majhnimi učinkoviti jedri.. Po moji prognozi zna bit poraba pri gamingu boljša od ZEN3, oziroma vsaj perf/watt "mora" bit boljši. Pri all-core opravilih pa "mora" pri perf-watt zmagat ZEN3.
Wrop ::
Če številke držijo, bo ST precej dober. 25 % več od 5950X. Po vseh razredih cca 25 % večjo zmogljivost v ST. Tega AMD ne bo ulovil vsaj do zen 4. Tu mu tudi dodajanje dodatnega L3 in +15 % zmogljivosti ne bo pomagalo držati ST krone. En 12600K (6/12) v MT bi moral v CB20 skoraj doseči 5800X, brez dodatnih jeder. Z dodatnimi jedri pa dobi še verjetno okoli 20 % od 6/12 rezultata. Torej tam okoli 20 % več od 5800X.
Če bo cena za 12600K pod 300 €, se lahko AMD kar tresejo hlače. AMD bo moral ceno 5800X krepko prilagodit, če se bodo te številke izkazale za resnične. Četudi bo imel Intel krepko višjo porabo. 6/12 + 4/4 za 280 € za 20 % večjo zmogljivost in nekaj 10 W višjo porabo, ali 8/16 5800 za 380 €. To bi bilo že 100 € razlike, kar že pokrije plato in mogoče celo ram.
Vse je odvisno od Intela in njegovih cen. Če navedene cene držijo, potem bo AMD moral krepko znižati svoje cene. 3000 serijo bodo lahko kar nehali prodajat. cene 5000 serije pa postavili kjer se nahaja trenutno serija 3000.
Če Intel res kaj ne prikriva, potem bo november vsekakor vroč. Pri nakupih CPU se verjetno splača počakat še en mesec, da bomo videli kaj bo.
Nekako mi občutek pravi, da bomo kmalu videli 5800X + v-Cache za 300 €.
Nyana ::
Mr.B je izjavil:
Ta komentar mi je najbol na mestu glede na hype, ki se že ustvarja okol 12. gen...
keba ::
Nekaj se govori, da je ZEN3+ skenslana in se osredotočajo na ZEN4, ki ga pa ne bo vsaj še do H2 2022... Je še kdo to zasledil?
Mogoče jih je Intel pohodil in pojedel proizvodne kapacitete na katere so računali.
Intel ima verjento prioriteto z 10nm za prenosne procesorje. Verjetno kapacitete/process še niso tu tu za ostale "non" K variante.
ngc2392 ::
treba je hype nardit...amd ga je naredu in se "zaklal", ker ni dobavljal naročenih izdelkov. no...za rajo. dražje zadeve je uspešno prodajal. očitno je moda, da narediš tak hype, da bi še marsovci hodil po robo na zemljo, na koncu pa ni ne robe in ne hypa. ali pa obojega zelo malo, pa veliko scalperjev. in folk se slini in slini pa slini...potem mu pa dojadi in kupi trenutno zadevo.
United We Stand, Divided We Fall
Skyman ::
Intel Core i9-12900K spotted running alongside overclocked DDR5-8000 memory
toro69 ::
Izid bo ravno pravšnji, da nadomesti mojega Threadripperja.
Zima bo lepša z 230W TDP ob bosih nogah.
Meizu ::
kek, tanovega threadripperja nabavi, ne moreš tega primerjat z i Inteli.
Skyman ::
Dutch Amazon begins listing Intel Core i9-12900K at 847 EUR, other Alder Lake CPUs listed as well
https://videocardz.com/newz/dutch-amazo...
49106 ::
Predrago, kar naj ga imajo za tako ceno.
Skyman ::
Za to ceno ga itak nekaj prav prodali ne bodo,sploh 12600k bo malo slabsi in bodo vsi rajse amd vzeli.Glede na to da intel še ni enakovredn amdju bodo z cenami se lazjo odlocitev dali.Sicer pa še nikol ni bilo preoder nekega cpu,gpu cenejse kot dejansko izid.Jaz mislim da tam 650€ bi mogel biti 12900k.
Ampak če ta nerealna predprodajna cena za 12600k znaša 324€, potem res lahko pričakujemo dejansko ceno 12600KF modela okrog 260-280€.. In tu govorimo o 10 jedrnem oz. 16 nitnem procesorju, ki bo najbrž v vseh pogledih boljši od 8-jedrnega Ryzena 5800X..
Se splača počakat. Pa zraven eno H670/B660 ploščo in DDR4 rami.. Zna bit huda p/p kombinacija. Res pa je, da bo tudi AMD odgovoril z nižanjem cen.
Kaj kadiš? Bi probal.
Kaj ti gre v nos, tiki?
V nekaterih testih se alder lake obnese slabo, ti pa pričakuješ najmanj vstajenje. Da se ne bo ponovno tresla gora in rodila miš.
Testi v zadnjem tednu/dveh so kar konsistentni.. Ti imaš verjetno v mislih kak test hudo hendikepiranega ES primerka. No, we'll see čez mesec dni.
Skyman ::
Zna biti kar dober procesor,napram prejsne generacij.Mislim pa da bi rekel da bodo prehiteli amd pa nism cisto siguren,tudi sami so rekli da tam 2023/24 naj bi se lahko šele enakovredno borili ali prevzeli krono ali dohiteli.(bil je en clanek ze dolgo nazaj)
Te cene so itak take nerealne,seveda ce si prvi trgovec lahko das 2 jurja ceno,ko pa bo dejanska dobavljivost,in prisli na sceno še ostali trgovici pa bo ta nizja.Koliko nizja bomo videli cez 1 mesec.
DarwiN je izjavil:
Bomo videli. Super, če bo dober p/p. Takoj nabavim. Sam nisem je zelo verjetno, da bom presedlal na amdjevo platformo
Zanimivo da se ni nobenih testov za igre. Glede na sintetiko bi morala biti to raketa.
9 / 35
14th Gen Intel Core - Meteor Lake (strani: 1 2 3 4 5 6 7 8 9 )
41091730 (16315) Horzen
AMD najavil procesorje Ryzen 7000 (strani: 1 2 3 )
Oddelek: Novice / Procesorji
10928271 (11677) D3m
Procesorji Alder Lake prispejo 4. novembra (strani: 1 2 )
9224498 (19532) FireSnack
11th Gen Intel Core (strani: 1 2 3 4 … 13 14 15 16 )
787135121 (92300) mtosev
