New Cloudflare tool can tell you if your ISP has deployed BGP fixes
kuglvinkl ::
Članek: https://arstechnica.com/information-tec...
Link to toola: https://isbgpsafeyet.com/
telemach: Your ISP (Telemach Rotovz - TRIERA Internet, AS3212) does not implement BGP safely. It should be using RPKI to protect the Internet from BGP hijacks.
bluefish ::
T-2 enako.
Yup, telemach Celje, enako, no surprise there.
SHAME.
Your ISP (A1 Slovenija (AS8591 ex-Amis), AS8591) does not implement BGP safely. It should be using RPKI to protect the Internet from BGP hijacks.
Your ISP (Telekom Slovenije, AS5603) does not implement BGP safely. It should be using RPKI to protect the Internet from BGP hijacks.
Evo, ker imam ravno to možnost, sem preizkusil vse 3 moje povezave.
mirzad ::
a je kateri slo isp varent trenutno
Če pa imamo top networking strokovnjake?
joggi79 ::
mirzad je izjavil:
Vsi ;) In dokler nihce od tier1 ne uporablja tega, je dokaj brez veze te stvari implementirati nizje dol. BGP hijacking je tako redka stvar, da se ni pretirano za sekirat zaradi tega.
Razen ko bad buyTM država "po nesreči spusti" celoten promet čez njihov Telekom.
https://www.zdnet.com/article/russian-t...
HotBurek ::
Evo, da vprašam; kaj pomeni kratica AS1234?
root@debian:/# iptraf-ng
Please resize your window
Autonomous System. En otoček na mreži, ki se v bgpju obravnava kot enota.
SeMiNeSanja ::
HotBurek je izjavil:
An Autonomous System Number (AS number or just ASN) is a special number assigned by IANA used primarilly with Border Gateway Protocol which uniquely identifies an network under a single technical administration that has a unique routing policy, or is multi-homed to the public internet.
Če v Google vpošeš npr. ASN5603, ti vrže ven kar nekaj zanimivih povezav...
https://db-ip.com/as5603-telekom-sloven...
https://bgp.he.net/AS5603
https://asrank.caida.org/asns/5603
https://www.peeringdb.com/asn/5603
https://www.bigdatacloud.com/asn-lookup...
Pričujoče sporočilo je (lahko) oglasno sporočilo
- četudi na prvi pogled ni prepoznavno kot tako.
(Zdaj me pa obtožite prikritega oglaševanja, če morete!)
SIOL tujina down? (strani: 1 2 3 4 5 )
Oddelek: Omrežja in internet
22425608 (9400) MacGyver141
Nakup 10Gbps L3 Switcha
212553 (2207) c3p0
ICANN: Sistem DNS je v nevarnosti
107326 (5095) HotBurek
Kaj točni je domenski zapis "A" ?
61173 (1000) Bakunin
Statični vs dinamični IP
174098 (3457) Bakunin
