Forum » Informacijska varnost » New Cloudflare tool can tell you if your ISP has deployed BGP fixes
kuglvinkl ::
Članek: https://arstechnica.com/information-tec...
Link to toola: https://isbgpsafeyet.com/
telemach: Your ISP (Telemach Rotovz - TRIERA Internet, AS3212) does not implement BGP safely. It should be using RPKI to protect the Internet from BGP hijacks.
Your ISP (A1 Slovenija (AS8591 ex-Amis), AS8591) does not implement BGP safely. It should be using RPKI to protect the Internet from BGP hijacks.
Your ISP (Telekom Slovenije, AS5603) does not implement BGP safely. It should be using RPKI to protect the Internet from BGP hijacks.
Evo, ker imam ravno to možnost, sem preizkusil vse 3 moje povezave.
joggi79 ::
Razen ko bad buyTM država "po nesreči spusti" celoten promet čez njihov Telekom.
https://www.zdnet.com/article/russian-t...
HotBurek ::
Evo, da vprašam; kaj pomeni kratica AS1234?
root@debian:/# iptraf-ng
Please resize your window
SeMiNeSanja ::
An Autonomous System Number (AS number or just ASN) is a special number assigned by IANA used primarilly with Border Gateway Protocol which uniquely identifies an network under a single technical administration that has a unique routing policy, or is multi-homed to the public internet.
Če v Google vpošeš npr. ASN5603, ti vrže ven kar nekaj zanimivih povezav...
https://db-ip.com/as5603-telekom-sloven...
https://bgp.he.net/AS5603
https://asrank.caida.org/asns/5603
https://www.peeringdb.com/asn/5603
https://www.bigdatacloud.com/asn-lookup...
Pričujoče sporočilo je (lahko) oglasno sporočilo
- četudi na prvi pogled ni prepoznavno kot tako.
(Zdaj me pa obtožite prikritega oglaševanja, če morete!)
| » | SIOL tujina down? (strani: 1 2 3 4 5 )Oddelek: Omrežja in internet | 25608 (9400) | MacGyver141 |
| » | Nakup 10Gbps L3 SwitchaOddelek: Omrežja in internet | 2553 (2207) | c3p0 |
| » | ICANN: Sistem DNS je v nevarnostiOddelek: Novice / Omrežja / internet | 7326 (5095) | HotBurek |
| » | Kaj točni je domenski zapis "A" ?Oddelek: Omrežja in internet | 1173 (1000) | Bakunin |
| » | Statični vs dinamični IPOddelek: Omrežja in internet | 4098 (3457) | Bakunin |
