Factory data reset
Factory data reset
Tiha voda ::
Na telefonu se mi izpiše:
Can't load Android system. Your data may be corrupt. If you continue to get this message, you may need to perform a factory data reset and erase all user data stored on this device.
Try again
Factory data reset
Po večkratnih "try again", se sistem še vedno noče zagnati. Ali mi ostane še kaj drugega kot factory data reset in kaj se ob tem izbriše (vse slike, naloženi appi...)? Kaj bi lahko bil razlog za napako? Telefon je Xiaomi Mi A2.
Hvala za pomoč in nasvet.
nsa_ag3nt ::
Ugasni telefon, odstrani sim kartico.
Prižgi, če se sistem postavi, nastavi jezik na english.
Problem se je pojavil kako ?
Druga rešitev:
Had this exact issue today on my 6P coming from the latest version of Nougat straight to Beta 4. No amount of 'Try again's worked (I must have tried 30+ times).
I did fix it however! The trick seemed to be clearing the cache.
I couldn't get into recovery mode initially because a) I wasn't near a PC and b) selecting recovery from Fastboot was just taking me back to the same failure screen.
Steps to resolve:
Let the phone boot to the failure screen
Select "Try again" and then as soon as the screen goes blank, hold Power and Down to enter Fastboot. You have to do it at this step otherwise the phone knows there is a problem and returns you to the error.
Select recovery from the Fastboot menu and press power briefly. Hopefully now the screen will load with the android and "no command" message.
hold power and press up - Actual recovery should load
Scroll down to 'Wipe cache partition' and press power
Scroll to Yes and press power.
Scroll to 'Power Off' and press power
Turn phone back on - hopefully it boots now!
Kako prideš v recovery mode
https://www.android.gs/enter-recovery-m...
Method 1 - the classic way
First of all, turn off your Xiaomi Mi A2: press and hold the Power button for a few moments just until the shut down process is completed; or press the Power key once and choose 'power off'.
Afterwards on your phone press and also hold the Volume Up and Power buttons.
After a few moments the Android Robot image will show up. When you see that image release all buttons.
Now, press Volume Up and Power keys to open the recovery mode menu.
That should be all; in recovery use the Volume rocker keys to navigate and the Power button to select.
You can return to Android mode by choosing 'reboot system now'.
https://gizmodo.com/c/goodbye-big-five
  • spremenilo: nsa_ag3nt ()
Tiha voda ::
Poskušam vse omenjeno, a ne deluje. Telefon je še v garanciji, ali bi mi problem rešili na servisu?
Pomoc za Xiaomi Mi A1
162323 (1580) grga1975
zaklenjena tablica
83994 (3758) rutar11
Android safe mode
94246 (3973) Opkow
Custom ROM za Nexus S pomoč
Oddelek: Mobilne tehnologije
61257 (1091) klinker
Samsung galaxy note BRICK
204595 (4082) CaqKa
