Forum » Pomoč in nasveti » Reboot and select proper Boot Device
or Insert Boot Media in selected device
To se občasno pokaže pri vklopu PC.
Po resetu ponavadi dela.
Kaj bi lahko bilo? Disk crkuje?
Gre za desktop PC, star kako leto. i7 osme generacije.
Verjetno disk, lahko pa je matična.
Če se ti da tole preletet:
https://neosmart.net/wiki/reboot-and-se...
Disk (SSD) je neka čunga-lunga, sem ga že prej sumil.
Bom ga kar preventivno zamenjal iz lastnega žepa (gre za službeni računalnik), če ni čez 50 EUR...
donnar995 ::
It happens as result of a failed Windows or BIOS update or Corrupted or damaged HDD/SDD. I would suggest you to follow these steps:
This can resolve your issue. If you still face the issue then I would suggest you to read these 8 Fixes for the error of reboot and select proper boot device: https://www.coupweb.com/reboot-and-sele...
Press power button to boot your PC
Press F1, F2, F8, F11 or F12 depending upon your PC, to enter BIOS setup
Click on Boot Tab
Choose HD as your PCs first option
Save and Restart
| » | Monitor nima signalaOddelek: Pomoč in nasveti | 2309 (2047) | MIHAc27 |
| » | Unknown deviceOddelek: Pomoč in nasveti | 1802 (1232) | _Denny_ |
| » | Select proper boot deviceOddelek: Pomoč in nasveti | 5491 (3520) | arc-x |
| » | Kako win na eepc904hdOddelek: Pomoč in nasveti | 1279 (1125) | iloveboobz |
| » | ASUS P5KC P35Oddelek: Pomoč in nasveti | 2139 (1931) | Tac20 |
