Forum » Igre » Brezplačne igre (giveaways)
okica11 ::
Ni igra, je pa ZA igre. Če kodo potrebuje popust na Xbox Game Pass za PC - 3 mesece €17.99 namesto €29.99 imam eno odveč za španski amazon. Kdor prvi pride, prvi melje na zs :) (VELJAVNO DO 6.4.2021).
Izi ::
GOG
XIII
Izid: 18. november 2003
Prvoosebna streljačina s stealth elementi.
Giveaway bo trajal še 44 ur
https://www.gog.com/game/xiii
Igra je sicer že precej v letih ampak menda je odlična. Edino vprašanje je kako deluje na modernih računalnikih.
Našel sem še opis igre v preminulem legendarnem Jokerju: XIII
XIII
- spremenil: Izi ()
Deluje brez težav na modernih računalnikih, samo moraš naložiti en popravek:
unofficial patch 1.4.2.1 / XIII+
https://www.moddb.com/games/xiii/downlo...
Description
A custom installer for XIII to install the base game as well as XIII+, a comprehensive set of new features with native multiplayer support and further enhancements, ready out-of-the-box for playing. (physical or GOG version of XIII required)
Have you ever wanted to install XIII but run into obstacles in installing and tweaking it? This release provides a revamped XIII (including brand new content) ready to go! Less fiddling, more playing.
The setup file allows you either to install XIII from scratch by using the retail version or to upgrade an existing installation.
Compatible XIII versions for new installation:
* European XIII Retail version on 4 CDs
* European XIII Retail version on DVD (e.g. Gold Games 8, Computer Bild Spiele)
* Czech XIII Retail version (thanks to Opaquit)
The upgrade-only option is meant for already existing installations, like unmodified retail versions and the GOG one which can install the base game by itself.
CONTENT
Patch 1.4 by Opaquit
All previous patches (1.1; 1.2; 1.3) from Ubisoft and several other bug fixes and new features. See more on Xiii.opaquit.com
Patch 1.4.2.1 by Arthur
Applied GOG XIII version (addressing issues caused by CPU energy saving)
New file structure:
`XIII\Skins` - for any additional skins
`XIII\Maps\BaseSP` - stock singleplayer maps
`XIII\Maps\BaseMP` - stock multiplayer maps
`XIII\Maps` - any custom maps
`XIII\System\PC` -> `XIII\System`
`XIII\TexturesPC` -> `XIII\Textures`
Deleted `XIII\MapsUser` if empty
Deleted `XIII\Support` and moved manual files into `XIII\Help`
Updated `MSL.ini` with all default skins (XIIIPersosPlus.u)
Fixed localization mistakes
Disabled connection to the Ubi.com master server
Removed startup logos entirely
Optimized network settings
Included XIII IP Join
XIII+ by Arthur
Included CTF/4 mode resources
Added additional GUI options inside match sessions as a shortcut to quickly switch servers, set up mutators, ...
Map List view (to prevent hitting the combobox over 9000 times)
Mutator support
(built-in mutators:
AutoChat: Enable automatically appearing chat messages ingame
Players: Customize player stats like health, equipment, jumping strength, ...
Equipment: Set default weapon, primary ammo, secondary ammo, armor, ...
World: Set gamespeed, convert underscores in player name to whitespace
FragFace: Replace the death skull with a custom image
MightyFists: Use your mighty fist as weapon... or rather a special part of it
Visuals: Enable HeadShotSFXTrigger (trigger head shot comic windows as known of single player) and possibly other effects in the future
Online Game Service (connection to master.insidexiii.com)
Addressed the sloppy menu cursor bug including upscaling of the cursor on higher resolutions
Overall GUI improvements
An ingame command list with useful functions
Bot support in listen servers
Shortcut keys to toggle fullscreen/window mode (F11) and to check for FPS and NET stats (F4 / F3)
Assigned appropriate FOV values as default according to Pcgamingwiki.com
Fixed minor issues and warnings...
Hint:
- FMVs are stretched in widescreen.
To keep an 4:3 aspect ratio, see the comments for instructions.
Več informacij in nasvetov tukaj:
https://www.pcgamingwiki.com/wiki/XIII
Description
CONTENT
New file structure:
XIII+ by Arthur
Mutator support
(built-in mutators:
Hint:
- spremenil: opeter ()
acookook ::
Steel Rats je brezplačna na GOG.com
https://www.gog.com/game/steel_rats
Še 30h (30h:50min)
3 out of 10 season two danes ob 17.00 @Epic
- spremenil: mtosev ()
Deponia the complete journey danes ob 17.00 @ epicgames.
ahac ::
EGS
Deponia: The Complete Journey
https://www.epicgames.com/store/en-US/p...
Ken Follett's The Pillars of the Earth
The First Tree
The First Tree
A kr 3 igre hkrati podarjajo? Jaz sn prvo vido in mislil, da je to to.
- predlagalo izbris: Ghost007 ()
acookook ::
(Epic) TLDR; Alien Isolation ter Dungeon-Crawler Hand of Fate 2 od 22.04.21
Wer also bis jetzt noch keine Chance hatte das Spiel Alien Isolation mal zu testen kann ab dem 22. April kostenlos reinschnuppern - dazu muss man einfach das Spiel seiner Epic Games-Bibliothek hinzufügen und kann es für immer behalten. Aber Achtung: Zeit habt ihr nur bis zum 29. April.
Ebenfalls ab dem 22. April gibt es den Dungeon-Crawler Hand of Fate 2 geschenkt. Ein junger Titel der am 4. März 2021 erschienen ist. Auch diesen gibt es wieder vom 22.-29. April kostenlos.
Izi ::
Steam
Utopos
Izid: 29. marec 2021
"Free to keep" če prevzameš danes do 19:00
Multiplayer Action Shooter 2,5D
Utopos
https://www.epicgames.com/store/en-US/f...
Alien isolation in hand of fate 2 danes ob 17.00.
Idle champions of the forgotten realm danes ob 17.00 @epicgames
Izi ::
Steam
Rusty Lake Hotel
Izid: 29. januar 2016
Žanr: Indie, Puzzle, Point & Click
Reviews: Very Positive
"Free to keep" če prevzameš do konca meseca.
Rusty Lake Hotel
Izi ::
Tukaj bi bilo dobro dodati par besed. "Šenkavanje" je tokrat precej neobičajno. "Idle Champions of the Forgotten Realms" je namreč zastonjska igra, ki je in bo vedno zastonj. Ima pa igra kup microtransakcij, ki niso ravno "mikro" saj marsikaj stane po več deset dolarjev
Igre torej ne morejo podariti, bodo pa zato podarili opremo znotraj igre v vrednosti $100.
Kdor bo hotel imeti to opremo bo moral igro najprej naložiti. Igra je dolga samo 674 MB. Potem pa no treba enkrat v tem tednu do naslednjega četrtka igro zagnati in se logirati vanjo. Šele takrat bo ta oprema postala naša last.
Zastonj bomo dobili:
● Odklene se naslednjih 5 junakov: Spurt (Slot 3), Krull (Slot 6), Black Viper (Slot 7), Hew Maan (Slot 8) in Nova V'Ger (Slot 11)
● Spurt Chests: 16 Gold Spurt Chests with 2 guaranteed Shiny equipment cards
● Krull Chests: 16 Gold Krull Chests with 2 guaranteed Shiny equipment cards
● Black Viper Chests: 16 Gold Black Viper Chests with 2 guaranteed Shiny equipment cards
● Hew Maan Chests: 16 Gold Hew Maan Chests with 2 guaranteed Shiny equipment cards
● Nova Chests: 16 Gold Nova Chests with 2 guaranteed Shiny equipment cards
● Dva "Familiara", ki sta drugače po $10: Baby Spurt & Iris the Beholder
Izi ::
Steam
Nubarron: The adventure of an unlucky gnome
Izid: 30. januar 2020
Žanr: Indie, Adventure, Platformer, 2D
"Free to keep" če prevzameš do 9. maja.
Pine danes ob 17.00 @epicgames
Izi ::
Epic ima poleg običajnega četrtkovega šenkavanja sedaj še eno akcijo in sicer šenkavajo "Exclusive Starter Pack" za igro World of Warships, ki drugače stane 22,50 €.
Ta akcija bo trajala do 10. maja.
AngelOfDeath ::
Igra je bila vedno zastonj.
edit: Slovnica
BorutK-73 ::
AngelOfDeath je izjavil:
On ima v mislih starter pack.
Mislim da ta pack deluje samo za nove račune, z obstoječim ne gre. Vsaj tak namen imajo ti packi, isto je za WoT.
Izi ::
Steam
Keyboard Killers
Izid: 21. september 2017
Pravijo, da je zastonj samo začasno, ni pa nikjer nobenih datumov.
Opis:
"Keyboard Killers is not simple keyboard clicker game. In which you should kill meteors to save your starship and your friend dragon. You should be very fast to able to complete the game. More then 500 apm on hardest levels!"
Se pravi samo za tiste, ki jim ni škoda tipkovnice. Rabiš več kot 500 klikov na minuto za višje levele
Keyboard Killers
Opis:
The lion's song danes ob 17.00 @epicgames
ahac ::
Na Slo-Tech discordu imamo bota, ki sporoča tudi male free igre, ampak se mi sploh ne zdi vredno postat sem na forum.
Npr:
https://freebies.indiegala.com/airport-...
https://freebies.indiegala.com/construc...
ST Discord:
https://discord.gg/ppCtzMW
Npr:
ST Discord:
- spremenil: ahac ()
Izi ::
IndieGala in podobne res nima smisla postati, ampak za glavne 4 trgovine (Epic, Steam, GOG in Ubisoft) pa le pošlji, četudi gre samo za male Indie igrice
Na primer tale bi že znala komu priti prav:
Steam
The Dream Machine: Chapter 1 & 2
Izid: 11. maj 2012
"Free to keep" če prevzameš do 17. maja.
All Reviews: Very Positive
The Dream Machine is an award-winning point & click adventure game about exploring other people's dreams. It's built by hand using materials such as clay, cardboard and broccoli.
Sta sicer samo prva dva poglavja od šestih, ampak reviewerji pravijo, da sta ravno prva dva poglavja odlična in edina ki se ju splača preigrati, potem kvaliteta pada, konec je pa sploh zanič.
Izi ::
Steam
Company of Heroes 2 + (DLC) Company of Heroes 2 - Ardennes Assault
V paketu šenkujejo igro in še en DLC.
"Free to keep" če prevzameš do 31. maja 2021
Cena za paket je drugače 35 €
Na uradni strani Company of Heroes 2 pa se lahko še registriraš in dobiš še drugi DLC zastonj:
(DLC) Company of Heroes 2 - Case Blue Mission Pack
- spremenil: Izi ()
yoco ::
Steam
Little Nightmares 1
https://store.steampowered.com/app/4248...
Je poteklo, ker meni kaže da je 20€?
acookook ::
Potem že, sem za 0EUR dobil & na redditu je blo.
- spremenil: acookook ()
Izi ::
Microsoft Store
Tell Me Why: Chapters 1-3
Izid: 27. avgust 2020
Za PC in Xbox
Da ne bo nesporazuma. Prvo poglavje je bilo zastonj tudi do sedaj, prvo je zastonj tudi na Steamu, Microsoft pa sedaj šenkuje še ostala dva. Se pravi, na voljo je celotna igra.
Ponudba velja še 29 dni. Torej tam nekje do konca junija.
Za PC in Xbox
- spremenil: Izi ()
ahac ::
Microsoft Store
Za PC in Xbox
Še na Steamu:
https://store.steampowered.com/app/1180...
Igra je free cel "Pride month". Da ne bo kdo potem presenečen nad vsebino.
Warhammer Skulls Digital Goodie Pack Giveaway on GOG.COM
https://www.gog.com/partner/warhammer
https://www.gog.com/game/warhammer_skul...
This pack includes:
+ A classic strategy game Warhammer: Shadow of the Horned Rat.
+ A batch of cool Warhammer Skulls and Adeptus Titanicus: Dominus wallpapers.
+ A World Eaters sampler from The Black Library in PDF, epub, and mobi.
+ A free Warhammer 40,000 Roleplay Adventure titled Rain of Mercy in PDF.
+ A Warhammer: Mark of Chaos - The Collected Concept Art album in PDF.
+ An original soundtrack from Warhammer 40,000: Mechanicus in FLAC and WAV.
+ A 15% off discount code for Warhammer merch (valid until 31st August 2021 for use in the official store)
Akcija velja do 10. junija 2021, 17.00 (5 pm UTC).
This pack includes:
Izi ::
Steam
Museum of Other Realities
Izid: 26. februar 2020
"Free to keep" če prevzameš do 21. junija 2021
Pravijo, da je tole obvezna izkušnja za vse, ki imajo naglavni komplet za navidezno resničnost.
Notice: Requires a virtual reality headset.
- spremenil: Izi ()
Izi ::
Realnočasovni Loria je postala brezplačna igra na GOG.com
Ustvarjalci so inspiracijo dobili od starih Warcraftov.
Več pa tukaj:
https://www.gog.com/news/get_loria_an_e...
https://www.gog.com/game/loria
Več pa tukaj:
acookook ::
Epic
Control
Izid: 27. avgust 2019
Epic se spet razmetavaControl je zastonj do 17. junija 2021
še čas si pozabil, te dopolnim, prevzamemo jo lahko do 16:59 po CEST.
acookook ::
Get 3 Months of Discord Nitro, free for new Nitro users. Offer ends June 24, 2021 at 11am EDT. Personalize your profile, screen share in HD, upgrade your emojis, and more!
acookook ::
Get Surviving Mars - Deluxe Edition now
Subscribe to the Humble Bundle newsletter and we'll email your free game to you. Hurry, this offer is available only while supplies last, or until June 14, 2021 at 10:00:00 AM PDT!
https://www.humblebundle.com/store/surv...
acookook ::
(Steam) Titan Souls
https://store.steampowered.com/app/2971...
Get Titan Souls
Free to keep when you get it before 14 Jun @ 7:00pm. Some limitations apply. (?)
Get Titan Souls
AgiZ ::
Hvala, vzel :)
| » | Epic Games Store (strani: 1 2 3 4 … 16 17 18 19 )Oddelek: Igre | 210802 (3428) | Zmajc |
| » | Spiderman PS4 (2016)Oddelek: Igre | 3363 (654) | Gregor459 |
| » | Saints Row (2022)Oddelek: Igre | 4498 (2028) | Gagatronix |
| » | XCOM 2 (strani: 1 2 )Oddelek: Igre | 12210 (5455) | FireSnake |
| » | Igre za mladoletnikaOddelek: Igre | 4053 (2412) | mtosev |
