Forum » Strojna oprema » Ne najdem supporta za plato HELP!!!
sverde21 ::
Rabu bi bios nadgradit na moji plati pa ne najdem enga supporta pa sm cel google že narobe obrnu
Podatki o moji plati kopirani iz SiSoft Sandre:
Mainboard
Manufacturer : Procomp Informatics
MP Support : No
Model : i810-W83627HF
System BIOS : 09/21/2000-i810-W83627HF-6A69MPNAC-00
Chipset : Intel 810 (Whitney)
FLASH Memory Controller
Error Correction Capability : None
Number of Memory Slots : 2
Bank0/1 - A0 : DIMM 64MB/64
Bank2/3 - A1 : DIMM 64MB/64
Chipset 1
Model : Intel Corporation 82810 810 Chipset Memory Controller Hub
Bus(es) : ISA PCI USB i2c/SMBus
Front Side Bus Speed : 1x 67MHz (67MHz data rate)
Maximum FSB Speed / Max Memory Speed : 1x 100MHz / 1x 100MHz
Width : 64-bit
IO Queue Depth : 4 request(s)
Chipset 1 Hub Interface
Type : Hub-Interface
Version : 1.00
Number of Ports : 1
Width : 8-bit
Full Duplex : Yes
Multiplier : 1/1x
Logical/Chipset 1 Memory Banks
Bank 0 : 64MB SDRAM 3-3-3CL
Bank 2 : 64MB SDRAM 3-3-3CL
Shared Memory : 1MB
Width : 64-bit
Refresh Rate : 15.60žs
Power Save Mode : No
Fixed Hole Present : No
Memory Module(s)
Memory Module 1 : 64MB 4x(8Mx16) SDRAM PC133U-333-542 (CL3 up to 133MHz) (CL2 up to 100MHz)
Memory Module 2 : 64MB 8x(8Mx8) SDRAM PC133U-333-542 (CL3 up to 133MHz) (CL2 up to 100MHz)
Environment Monitor 1
Model : Winbond W83627HF ISA
Version : 2.01
Mainboard Specific Support : No
Temperature Sensor(s)
Board Temperature : 37.0°C / 98.6°F
CPU Temperature : 43.0°C / 109.4°F
Power / Aux Temperature : 73.0°C / 163.4°F
Cooling Device(s)
Auto Fan Speed Control : No
CPU Fan Speed : 5273rpm
Voltage Sensor(s)
CPU Voltage : 1.71V
Aux Voltage : 2.54V
+3.3V Voltage : 3.44V
+5V Voltage : 5.00V
+12V Voltage : 12.16V
-12V Voltage : -11.62V
-5V Voltage : -5.05V
Standby Voltage : 4.97V
Battery Voltage : 3.41V
PCI Bus(es) on Hub 1
Version : 2.10
Number of Bridges : 1
PCI Bus 0 : PCI (33MHz)
PCI Bus 1 : PCI (33MHz)
Multiplier : 1/2x
LPC Hub Controller 1
Model : Intel Corporation 82801AA 8xx Chipset LPC Interface Bridge
ACPI Power Management Enabled : Yes
Random Number Generator Enabled : No
Random Number Generator Support : Yes
Delayed Transaction Enabled : Yes
USB Controller 1
Model : Intel Corporation 82801AA 8xx Chipset USB Controllers
Version : 1.10
UHCI Interface : Yes
Channels : 2
Speed : 48MHz
Legacy Emulation Enabled : No
System SMBus Controller 1
Model : Intel 801xx SMBus
Version : 0.02
Slave Device Enabled : No
Speed : 16kHz
Expansion Slot(s)
PCI (1Eh) : PCI 32-bit +5V Full-Length Used (Intel Corporation 82801AA 8xx Chipset Hub to PCI Bridge)
PCI (10h) : PCI 32-bit +5V Full-Length Available
PCI (14h) : PCI 32-bit +5V Full-Length Available
PCI (B4h) : PCI 32-bit +5V Full-Length Available
Port Connector
PRIMARY IDE : None - ATA / None
SECONDARY IDE : None - ATA / None
FDD : 8251 FIFO - Floppy Disk / None
COM1 : Serial Port 16450 - 9 Pin Dual Inline / DB-9 pin male
COM2 : Serial Port 16450 - 9 Pin Dual Inline / DB-9 pin male
LPT1 : Parallel Port ECP/EPP - DB-25 pin female / DB-25 pin female
Keyboard : Keyboard - None / PS/2
PS/2 Mouse - Detected : Mouse - PS/2 / PS/2
USB : USB - None / None
Performance Tips
Notice 224 : SMBIOS/DMI information may be inaccurate.
Warning 2507 : Mainboard has too few memory slots. Upgrading the memory may be difficult or expensive.
Warning 2508 : All memory slots are full. Upgrading the memory may be difficult or expensive.
Warning 2544 : System/Video shared memory greatly reduces performance. Use external video card.
Warning 2518 : Mainboard temperature is too high.
Tip 2 : Double-click tip or press Enter while a tip is selected for more information about the tip.
Mainboard
MP Support : No
Chipset 1
Width : 64-bit
Version : 1.00
Number of Ports : 1
Width : 8-bit
Full Duplex : Yes
Multiplier : 1/1x
Shared Memory : 1MB
Width : 64-bit
Memory Module(s)
Version : 2.01
Cooling Device(s)
Voltage Sensor(s)
CPU Voltage : 1.71V
Aux Voltage : 2.54V
+5V Voltage : 5.00V
Version : 2.10
Multiplier : 1/2x
USB Controller 1
Version : 1.10
Channels : 2
Speed : 48MHz
Version : 0.02
Speed : 16kHz
Expansion Slot(s)
Port Connector
Performance Tips
Bx ::
evo,
v google sem vpisal bios ID 09/21/2000-i810-W83627HF-6A69MPNAC-00
potem sem šel sem Identfy motherboard by Procomp
tukaj sem potem poiskal tip MB glede na bios, ki je bil BIW1M kar sem vpisal v Google : BIW1M
in sem šel na prvi LINK ki mi ga je ponudil, tu pa sem opazil en Bios v1.3 za to plato (vsaj mislim, da je to to).
potem sem pa še v vpisni vrstici mal skrajšal link (do driver) in našel še BIOSe za ostale plate ter BIOS in CHIPSET UTILITY
tukaj sem pa našel sliko tvoje osnovne plošče pa mal poglej če je ta prava
Bx
- spremenil: Bx ()
sverde21 ::
TNX sm že jest tud po procompovi strani isku (sam jest pa tiste njihove grable je pa neki
) ok dej me pa še zanima kak bi jest tisto slikco v biosu zamenju sm članek prebrau sam mi ni jasno kje najdem tisto številko de vidim a lahka spremenim slikco al ne.
Aja pa mal helpa bom nucu tud z samim flashanjem k prvič delam to
TNX za any help
TNX za any help
sverde21 ::
A mi lahk edn dej pove kak nej jest flasham bios kr na oni strani ni nobenih navodil ipd.
TNX
TNX
Bx ::
kaj pa če bi mal pogledal pod ISKANJE : flash+bios
poglej mal po starejših temah, nekaj se bo že našlo, ker se mi zdi, da je bilo o vsem tem in pa tudi o tvoji slikci ( ISKANJE: epa+slikca) dosti napisanega
Bx
- spremenil: Bx ()
| » | Procesor AMD 2500+ BartonOddelek: Strojna oprema | 2121 (1936) | jest10 |
| » | disk?Oddelek: Kaj kupiti | 1627 (1375) | maticm |
| » | Program, ki pove katero matično ploščo imam?Oddelek: Programska oprema | 4196 (4098) | Han |
| » | BIOS upgradeOddelek: Pomoč in nasveti | 2060 (1890) | Dead_Eye |
| » | Procesor ko žerjavica?Oddelek: Hlajenje in modifikacije | 2086 (1852) | T0RN4D0 |
