Forum » Pomoč in nasveti » BIOS upgrade
BIOS upgrade
ToNyL ::
Jah no, cel net sem že preiskou, da bi najdu upgrade za Award modular bios v4,51 , ki ga mam na viini plati VT82C691 pa bi vas prosu če ve kdo, kje bi ga dubu...
Rekorder v sesuvanju svojega sistema...
McHusch ::
Na domači strani proizvajalca matične plate. To je edini način, da dobiš zagotovo pravi BIOS za tvojo ploščo.
Caligula ::
Pa isci po vseh iskalnikih. Kje na netu je ze se shranjeno.
Si mors mislit-eno uro sem vceraj iskal Microsoftov patch za bluetooth za XPje!!! Ga na njihovi strani pa skoraj nikjer vec ni.
Pa kaksen P2P program pa mogoce kje komu po disku polezava..
ToNyL ::
Če bo kej pomagalu so tuki lastnosti plate v programu SiSoft Sandra 2002 Standard...
SiSoftware Sandra
Entire System
Manufacturer : VIA Technologies, Inc.
Model : VT82C691
System Mainboard
Manufacturer : Quality Design (QDI)
MP Support : No
Model : 691/596-NS351
BIOS ID : 10/29/98-691/596-NS351-2A6LFQ19C-00
Chipset : VIA VT82C691 Apollo Pro Chipset
Memory Controller
Error Detection Method : None
Error Correction Capability : 1-bit
Supported/Current Memory Interleave : 4-way / 1-way
Number of Memory Slots : 4
Maximum Installable Memory : 1024MB
Maximum Module Size : 256MB
Supported STD/FPM/(B)EDO Speeds : 70ns, 60ns
Supported SDRAM Speeds : PC66, PC100
Supported Memory Types : STD, FPM, EDO, Parity, ECC, SIMM, DIMM, SDRAM
Supported Memory Voltages : 5V, 3.3V
Physical/BIOS Memory Banks
BANK_0 (RASL-1) : 128MB DIMM SDRAM single-bank
BANK_1 : Empty
BANK_2 : Empty
BANK_3 : Empty
System Chipset
Model : VIA Technologies Inc VT82C691/693A/694X Apollo Pro/133/133A System Controller
Bus(es) : ISA AGP PCI USB SMBus/i2c
Front Side Bus Speed : 1x 67MHz (67MHz data rate)
Max FSB Speed / Max Memory Speed : 1x 100MHz / 1x 100MHz
In Order Queue Depth : 4 req(s)
Logical/Chipset Memory Banks
Bank 0 Setting : 128MB SDRAM 7-1-1-1R 4-1-1-1W 3-2-2CL
Multiplier : 1/1x
Power Down Mode : No
Fixed Hole Present : No
Memory Modules
Memory Module 1 : Transcend Information 128MB 8x(16Mx8) SDRAM PC133U-333-542 (CL3 upto 133MHz)
AGP Bus
Version : 1.00
Speed : 68MHz
Current Data Transfer Rate : 2x 68MHz (136MHz data rate)
Side Band Enabled : No
Side Band Support : Yes
Fast-Writes Enabled : No
Aperture Size : 128MB
PCI Bus(es)
Version : 2.10
No Bridges : 1
PCI Bus 0 : 32-bit PCI (34MHz)
Multiplier : 1/2x
LPC Hub Controller 1
Model : VIA Technologies Inc VT82C596/A/B "Mobile South" PCI to ISA Bridge
ACPI PM Enabled : Yes
Random Number Generator Enabled : No
Speed Multiplier : 1/4x
Speed : 9MHz
DMA Multiplier : 1/2x
DMA Speed : 5MHz
USB Controller 1
Model : VIA Technologies Inc VT83C572,VT82C586/A/B,VT82C596B,VT82C686A/B USB Controller
Version : 1.10
UHCI Interface : Yes
Channels : 2
Speed : 48MHz
Legacy Emulation Enabled : No
USB Controller 2
Model : CMD Technology Inc USB0673 USB Controller
Version : 1.00
OHCI Interface : Yes
Channels : 2
System SMBus Controller 1
Model : VIA 596A SMBus
Speed : 16kHz
Expansion Slot(s)
ISA : ISA 16-bit 5V FullLength
PCI (8h) : PCI 32-bit 5V FullLength InUse (CMD Technology Inc USB0673 USB Controller)
PCI (9h) : PCI 32-bit 5V FullLength Available (Ensoniq (Creative) Creative Sound Blaster AudioPCI 64)
PCI (Ah) : PCI 32-bit 5V FullLength Available
Port Connector(s)
PRIMARY IDE : None - ATA / None
SECONDARY IDE : None - ATA / None
FDD : 8251 FIFO Compatible - Floppy / None
COM1 : Serial Port 16450 Compatible - 9 Pin Dual Inline / DB-9 pin male
COM2 : Serial Port 16450 Compatible - 9 Pin Dual Inline / DB-9 pin male
LPT1 : Parallel Port ECP/EPP - DB25 pin female / DB25 pin female
Keyboard : Keyboard Port - None / PS/2
PS/2 Mouse - Detected : Mouse Port - PS/2 / PS/2
USB : USB - None / None
Performance Tips
Notice N224 : SMBIOS/DMI information may be inaccurate.
Tip T2505 : System does not support memory error detection. Some memory errors may go unnoticed.
Tip T2511 : Some memory slots are free so the memory can be easily upgraded.
Tip T2524 : AGP Aperture size should be less or equal to system memory.
Tip T2 : For more information about tips, press F1 and scroll to the Tips section.
SiSoftware Sandra
Entire System
Model : VT82C691
System Mainboard
MP Support : No
Memory Controller
BANK_1 : Empty
BANK_2 : Empty
BANK_3 : Empty
System Chipset
Multiplier : 1/1x
Memory Modules
AGP Bus
Version : 1.00
Speed : 68MHz
PCI Bus(es)
Version : 2.10
No Bridges : 1
Multiplier : 1/2x
Speed : 9MHz
DMA Speed : 5MHz
USB Controller 1
Version : 1.10
Channels : 2
Speed : 48MHz
USB Controller 2
Version : 1.00
Channels : 2
Speed : 16kHz
Expansion Slot(s)
Port Connector(s)
Performance Tips
McHusch ::
Vzami knjigico od plate, pa poglej na platnice, kako se plata kliče, no! Sodeč po Sandri imaš plato QDI Advance 4.
@ljash ::
po mojem imaš DFI plato, tko kt jast - ima VIA čipovje.
Poglej na DOMAČO STRAN IZDELOVALCA - KLIK pa si izber svoj model.
Jst grem pa dele flashat - prvič v življenju in upam da ne zadnjič..
| » | (x) ubuntu internet nehal delatOddelek: Operacijski sistemi | 2072 (1834) | motorc |
| » | Procesor AMD 2500+ BartonOddelek: Strojna oprema | 2120 (1935) | jest10 |
| » | disk?Oddelek: Kaj kupiti | 1627 (1375) | maticm |
| » | Program, ki pove katero matično ploščo imam?Oddelek: Programska oprema | 4196 (4098) | Han |
| » | Procesor ko žerjavica?Oddelek: Hlajenje in modifikacije | 2086 (1852) | T0RN4D0 |
