Forum » Strojna oprema » Intel Core 8th-gen: Coffee Lake
louser ::
Razlika med 2700X in 8700K (ter 9900K) je v igrah majhna. Celo tako majhna, da morajo igre poganjati na 720p, ali pa v 1080p nižati nastavitve, in še to je zgleda premalo impresivno - za nekaj % ne bo nihče plačeval 100% več. Da dobijo zvenečih "up to 50% faster" se torej poslužijo goljufije, kar je zgoraj lepo pokazano.
Da so za tako slabe rezultate izklopili 4 jedra na 2700X je teorija, ampak samo tako prideš do tako velike razlike med 2700X in 8700K - samo počasnejši spomin ni dovolj.
The benchmarks carried out by Principled Technologies are even more bogus than we first thought. A few viewers pointed out that the Ryzen 7 2700X was listed as tested in the "Game Mode" within the Ryzen Master software and I foolishly thought they might have just made a simple copy and paste error in their document as they would have used this mode for the 2950X. This does explain why the Threadripper CPUs were faster than the 2700X in every test.
What this means is a CCX module in the 2700X was completely disabled, essentially turning it into a quad-core. I've gone ahead and re-run the XMP 2933 test with Game Mode enabled and now I'm getting results that are within the margin of error to those published by Principled Technologies.
It's even worse than we thought!
A veš kaj je fora? Da Se lahko Ryzen Master zahrošča do konca brez kakšnega štoranja in po resetu ostane na takšnih nastavitvah. Število delujočih jeder ni mogoče takrat nastaviti niti v biosu, niti ni mogoče nastaviti niti.
A če se že imaš za nekega specialca, ki testira hw, bi ti ta napaka morala biti znana.
Predator X ::
Seprav IPC je višji za ~3% napram R7 2700X. Okey, Če laufaš 4,2GHz na R7 2700X in 5GHz na i9 9900K.
seprav +19% boost ter 3% IPC = ~ 22,5%.
Če smo realni ima intel, ko imaš enkrat hiter ram pri ryzenu ~3200MHz, samo nekak 22,5% prednosti. Seprav 100fps vs 123fps (max). 5GHz je že kr, gre še višje, ampak poraba je zelo visoka.
ZEN 2 jedro naj bi imel ~15% višji IPC ter izboljšan arch (nižje latence). Mogoče bo res zdej IF pri dekstop laufal pri 1:2 IMC oziroma ne bo lockan.
Bwaze6 ::
"Game Mode" je namenjen Threadripperjem, izklopi jedra, ki nimajo direktnega dostopa do spomina (česar pri Ryzen prosesorjih ni).
29. oktobra pa tako pride gonilnik za Threadripperje z "Dynamic Local Mode", ki bo sam prestavljal zahtevnejše aplikacije na jedra z direktnim dostopom, tako da to itak opuščajo.
Tu ne gre za napako, v testu je napisano po Windows 10 nastavitvami:
"8. On AMD systems download and install the AMD Ryzen Master Utility.
a. Launch the utility, select Game mode, and click Apply."
Seveda so vsi predvidevali, da so mišljeni Threadripperji, a rezultati kažejo, da je isto narejeno za Ryzen.
Smooth.
In potem ima Intel še jajca potrditi, da je vse korektno in da pričakujejo, da bodo neodvisne recenzije to potrdile...
Smooth.
Predator X ::
Sej tud steve na HU ni ravno pošten do Ryzena. Če jst dobim boljši bench s RX 480 v AOTS in R7 1700 3200MHz@3,8GHz@3200MHz DDR4... Na prijateljevem, ki je kupil R7 2700X sva malce navila pa sva bila ~55-56fps. Takrat so bile še cene dokaj vredu in sem mu bolj priporočal i7 8700K, ker pa je vzel ITX, hotel navijati brez delida pa se je potem odločil za i7 8700K. Sicer pa sem tudi sestavil tak PC in potem OCjal i7 8700K na 5,2GHz ter DDR4 3466CL14. Sej PC leti po zraku, stroški in poraba so pa nenormalni... tam nekje 4,7-5ghz je sweet spot za OC gamerja.
- spremenilo: Predator X ()
ziga1990 ::
- spremenilo: ziga1990 ()
ziga1990 ::
https://www.techpowerup.com/247494/firs... tu imajo še več testov
ziga1990 ::
vseno moramo počakati na prave teste. Sedaj je vsaj jasno zakaj je intel omejil 2700X v svojih testih, ker je preblizu in ga vsaj v primeru 9900K 2700X premaga v P/P
Bwaze6 ::
O price / perfornance tu sploh ne moremo govoriti - 9900K je skoraj 100% dražji od 2700X... Bo treba Ryznu še nekaj jeder izklopit...
ziga1990 ::
Gamers Nexus Interview with Principled Technologies
KAVINSKY ::
You are fake news!
Po teh testih izgleda, kot da so močno omejeni z grafično kartico. Če je 8 gen i7 hitrejši za kakšne 10fps v igrah, ne more iznenada biti enako hiter kot r7.
Meiniken ::
Kaj se kregate fantje, pač napaka v tisku je bila. Ni "up to 50%" ampak "up to 5%"
Res pa je da intel že malce serje zadnje čase ker jim amd diha za ovratnikom.
Kaj bi blo če nebi bilo intelu nobene konkurence
Meanwhile se amd ukvarja s procesorji in grafičnimi karticami.
AapocalypseE ::
Zen 2 pa bo mel up-to 15% boljši IPC.
In že vsi pišejo, da bo mel ziher 15% boljšega.
UP-TO fantje... lahko je samo 5%
Treer ::
50% je malo verjetno, čeprav ne povsem nemogoče za kakšen posamezen primer, ker tisti, ko šprara in vzame Ryzene, bo precej verjetno kupil tudi slabšo plato in ram, ampak tam 20-25% hitrejši ob vseh ostalih pogojih enakih je pa kar fix, z nekaterimi situacijami verjetno tam do 35%. Za vse, ki bojo hoteli res high end (in itak vzeli 2080Ti), ne bo kaj razmišljat...
RegulusDraco ::
5ker tisti, ko šprara in vzame Ryzene,
zanimivo kako so intel fanboyi hitro postali povsem isti kot apple fanboyi.
A coding sequence cannot be revised once it's been established.
Kako?
Jaz sem vzel Ryzena in 3200 CL14 DDR4 RAM (ne glede na ceno).
Potem jaz nisem tipičen kupec. Ali pač? :D
- spremenilo: FireSnake ()
ziga1990 ::
AapocalypseE je izjavil:
Šparaš...
Če hočeš češnjo na torti, je pač treba Intel vzet.
dobiš pa pokvarjeno češnjo pri intelu
Bwaze6 ::
Treer - tudi če ne špilaš v 720p ali 1080p z mid nastavitvami? Govorit o enih procentih na splošno je brez veze - v 4K bo razlike koliko, 4%? V ray-tracingu na 2080Ti in v 1080p blizu 0%?
FlyingBee ::
Kako?
Si pa šparal pri nakupu telefona prek ebay.
Šparaš...
Ti si kupil ryzen 1700 za dobrih 300eur, pc pa uporabljaš pretežno za?
- spremenil: FlyingBee ()
ziga1990 ::
Kako?
Šparaš...
računalniške zadevice
Master_Yoda ::
Seveda je mogoce - ce disablas polovico corov na AMD procesorju, v AMD sistemu disablas XFR, in das slabsi RAM noter.
- spremenil: Master_Yoda ()
Buggy ::
Itaq fejki za owce in ni prvic ne zadnjic. Zato pa teh modrih goljufivih gnojov ne bom podprl in naj si CPU vtaknejo nekam, preden ga seveda prodajo slepim fanboyem.
Šparaš...
Dodal bi že: z zmanipuliranimi rezultati (res jim gre slabo, če morajo to početi
Pa nisem za nobene, mam mašine obeh taborov (Intel prevladuje v razmerju 2:1).
Meiniken ::
Glavno da se za delovanje igric kregamo predvsem o cpu-ju
Sicer pa, nekdo ki bo plačal za procesor 600 eur najverjetneje ne bo potem igral na full HD resoluciji. Ali pač?
Nisem ravno nek PC wizard ampak glede na to kar sem do sedaj videl je, da se zmogljivost cpu-ja primarno meri v programih, ki lahko profitirajo od več jeder in niti (ala content creation, kompresija, streaming,...). Vse kar je višje od 1080p vglavnem bolj visi na grafični (kar se gaminga tiče), torej nekako nima smisla zabijat 600 eur za intel, če lahko das 300 eur za amd in prišparaš oz. ta denar nameniš boljši grafični. + pa še dober cpu hladilnik dobiš zraven
+ A ni Intel nekaj časa nazaj nabijal da nekej ni možno, ko pa je Amd dal ven nove procesorje je pa blo možno? In zdej je spet cel halo. Če bi nekdo, ki ni naklonjen nobeni izmed teh firm to pogledal, bi rekel da ma Intel težave ostajati na vrhu ker je Amd postal konkurenčen.
Če mi pa kdo želi kaj pojasniti se pa toplo priporočam
- spremenilo: Meiniken ()
Treer ::
Z 2080Ti so sedaj razlike prej vidne samo na 1080 praktično enake tudi pri 1440p. In 1440p 144-165Hz postaja zlati standard high-end gaminga. In ja, če si še na nekem 1080p 60Hz monitorju bo dober praktično katerikoli cpu, ampak tukaj se gre za vrh desktop ponudbe, za prestiž kateri flagship je boljši in v tem pogledu bo 9900k odpihnil rdečo konkurenco, res pa da žal za precej visoko ceno.
- spremenil: Treer ()
FlyingBee ::
Gre se za to, da je ravno zdaj čas, ko so cene Intelov ponorele, prej je bil 8700k tudi dražji od 2700x, ampak je hitrejši. Kaj dosti za pojasnjevati ni, bi pa morali ločiti pri namenu za kaj ga želiš imeti. Za pretežno igre je razmišljanje popolnoma drugačno kot pri pretežno za pro, kjer tudi zaslužiš z delom na pcju. Za računalniške zadevice, kot ga uporablja ziga1990, je 1700 overkill in bogve zakaj je dal 100eur več za cpu, če bi lahko v kakšno drugo komponento vložil in već pridobil.
Za 1080p 60hz monitor več kot 200eur za procesor itak ni za razmišljati, odvisno tudi kakšno grafično imaš.
ziga1990 ::
Za 1080p 60hz monitor več kot 200eur za procesor itak ni za razkišljati, odvisno tudi kakšno grafično imaš.
imam rad računalnik dlje časa tako da 1700 ni overkill
fireX88 ::
Res ne stekam, kako si upajo v ime napisat "refreshed"
gendale2018 ::
Computeruniverse cene nič za vidt
https://m.computeruniverse.net/de/c/har...
še une cene od učeri so bile za vsaj 150 eur previsoke, pol pa to
ja sam mali poštar, kurac mi je oštar
čuvajte se žene, bit ćete jebene
RegulusDraco ::
fun fact...........v igri kjer Intelovi testerji trdijo da je i7-9700k 50% hitrejši od konkurence so drugi testerji ugotovili, da so AMDjevi procesorji dejansko 18% hitrješi od Intla.
rofl.
facepalm.
omg.
https://www.forbes.com/sites/jasonevang...
In Ashes of the Singularity, his Ryzen 2700X was 18% fasterEven more fascinating is Walton's Assassin's Creed: Origins result. In the published report by Principled Technologies, Intel's i7-8700K was 36% faster than AMD's Ryzen 2700X. Even when Walton overclocked the memory, his result shows the 8700K only being 10% better.
rofl.
facepalm.
omg.
- spremenil: RegulusDraco ()
gendale2018 ::
>un fact...........v igri kjer Intelovi testerji trdijo da je i7-9700k 50% hitrejši od konkurence so drugi testerji ugotovili, da so AMDjevi procesorji dejansko 15% hitrješi od 9700k.
zato pa ugasneš en ccx na 2700x
klinker ::
Seveda je tako. Samo nekemu frocu kot je teer to ne bo jasno. On ima Intela in je to edina prava stvar po namazanem kruhu, vse ostalo je neuporabno
ziga1990 ::
Evo Caseking je dal svoje cene in so bolj normalne:
9900K: 650€
9700K: 530€
https://www.caseking.de/search?sSearch=...
9900K: 650€
9700K: 530€
Bwaze6 ::
Principled Technologies Replies to Controversy Surrounding Their Intel i9 9900K vs AMD Ryzen 7 2700X Benchmark
Ker AMD predlaga uporabo "Game Mode" na Threadripperju, so ta način uporabili na vseh AMD procesorjih. Ker retardiran izgovor. Me prav zanima, kaj bojo polomili v svojem "updejtu", če bo sploh kdaj prišel...
Use of "Game Mode" on the AMD Ryzen™ 7 2700X: Some inquiries we have received concern the use of the Ryzen utility and the number of active cores in the AMD-based systems. Based on AMD's recommendations and our initial testing on the Threadripper processors, we found installing the AMD Ryzen Master utility and enabling the Game Mode increased most results. For consistency purposes, we did that for all AMD systems across Threadripper™ and Ryzen™. We are now doing additional testing with the AMD systems in Creator Mode. We will update the report with the new results.
FlyingBee ::
Je tako težko počakati na proper teste na guru3d, techpowerup, anandtech, tomshardware,...
Ni. Samo ne maramo PR bullshita.
Sedaj bodo še bolj na udaru, ker ne morejo obljubiti up to 50%.kriv je pa njihov izvajalec.
- spremenil: D3m ()
ziga1990 ::
zanimivo je to da stane 9600K malo več kot pa 2700X
FlyingBee ::
Saj niso sposobni. 7nm jim bo le več razpona dal.
| » | Nakup CPUja 2019 (strani: 1 2 3 )Oddelek: Kaj kupiti | 24381 (20019) | Predator X |
| » | i7-9700k ali i9-9900k ? (strani: 1 2 )Oddelek: Pomoč in nasveti | 12254 (10632) | TheKingZiga |
| » | AMD najavil Ryzene 3000 in Radeone 5000 (strani: 1 2 3 )Oddelek: Novice / Procesorji | 51960 (45547) | Predator X |
