3tb diski na p45 matičnih ploščah
Isotropic ::
a kdo ve, kako je s podporo večjih diskov na P45 ploščah (ali p43)? to je socket 775.
rad bi kupil enega 3tb (hitachi najbrž) pa sem bral, da so neki problemi lahko.
rad bi ga uporabljal tut kot secondary boot za win 7 / server 2008 ali kaj podobnega.
alternativno, katerega od WD diskov naj vzamem, če bi ga rad mel tudi za boot
konspirator ::
V gpt formatu mora biti win particija, če hočeš da bo bootable.
http://www.howtogeek.com/193669/whats-t...
Installation on 3TB disk (Non Uefi)
http://www.tenforums.com/installation-s...
razdeli hdd na 2.2 tb in ostanek, potem bo delalo v mbr načinu (bootanje).
https://hardforum.com/threads/3tb-drive...
#6
Windows 7, using GPT, but it showed the drive only have 746GB.
Apparently this is due to the board not having EFI. Gigabyte did release a utility to work around the issue, but it only works with newer boards, not the P45.
http://www.gigabyte.us/MicroSite/276/3t...
But I tried the jmicron ports and it sees my full 3TB drive just fine, something the other 6 ICH10R ports wouldn't do.
#15
Something is wrong at the OS level, my ancient P5B-Deluxe (P965) board with ICH8R chipset can see 3TB drives (Hitatchi 3K5000 model) just fine, formatted in GPT as a single 3TB partition in Windows 7 Pro x64. There was a Windows 7 patch within the last year (probably rolled into SP1) that fixed 3TB issues. I don't know how ICH10R could have an issue, being two generations newer.
There is an issue in the first version of WHS (not 2011) and 3TB drives, I remember doing research on it and there is an in-depth KB article about it, can't find the link at the moment.
Isotropic ::
čak, a bi lahko pa imel 500gb za boot MBR in ostalo prek GPT (non-boot)?
konspirator ::
Vse imaš lahko preko mbr, od 3tb hdd: 500 gb boot particija, ostalo druga particija.
Isotropic ::
aha, potem mora biti samo boot particija pod 2.2tb?
hvala
Spc ::
Isotropic je izjavil:
Jaz sem imel probleme z win 7 / 2008.
Zadeva deluje zelo zelo dobro z Windows Server 2012 R2 + ReFS.
ReFS laufam že 4 leta in do danes še ni niti enkrat nič crknilo.
Žal ReFS deluje samo v Windows Server 2012 R2 ali Windows Server 2016.
Uporabljam pa te 3TB diske, na p45 plati:
SeaGate SkyHawk 3TB ST3000VX000
http://www.seagate.com/gb/en/internal-h...
konspirator ::
Dokler ne dobiš na zaslon tega
http://www.refs-data-recovery.com/Defau...
Spc ::
Sej pravim, z NTFS na p45 in 3TB diski sem že zgubil podatke, ker je začel driver writeat na začetek diska po 2TB limitu.
z ReFS-om še ni bilo težav.
Isotropic ::
pa si imel tisti gpt?
Spc ::
GPT je bil disk ja.
Medijski predvajalnik z podporo 3TB+ diski
111981 (1601) misek
Domači server (strani: 1 2 )
Oddelek: Omrežja in internet
6915790 (12053) MrStein
Ali je pol HDD-ja umrlo ?
417449 (6545) opeter
Nov 3TB disk ampak uporabno samo 2TB!
71659 (1247) metalhead71
3TB disk - kateri?
255556 (4644) dr.Akula
