Blue screen pri igricah
znamovsi ::
Živjo!
Moj računalnik ma skoz blue screen med igranjem igric (npr LOL, BF ipd.)
In sicer igra se zažene nato pa se enkrat pc samo izklopi, razlog: thread stuck in device driver (nekaj takega)
kaj bi to bilo?
naj povem da se winse naložil na novo pred 1 tednom, pri eventih mi kskoz javla napake, kot so npr:
The application-specific permission settings do not grant Local Activation permission for the COM Server application with CLSID
{8D8F4F83-3594-4F07-8369-FC3C3CAE4919}
and APPID
{F72671A9-012C-4725-9D2F-2A4D32D65169}
to the user NT AUTHORITY\SYSTEM SID (S-1-5-18) from address LocalHost (Using LRPC) running in the application container Unavailable SID (Unavailable). This security permission can be modified using the Component Services administrative tool.
The system firmware has changed the processor's memory type range registers (MTRRs) across a sleep state transition (S4). This can result in reduced resume performance.
The device driver for the Trusted Platform Module (TPM) encountered a non-recoverable error in the TPM hardware, which prevents TPM services (such as data encryption) from being used. For further help, please contact the computer manufacturer.
The driver \Driver\WudfRd failed to load for the device SWD\WPDBUSENUM\_??_USBSTOR#Disk&Ven_Sony&Prod_Storage_Media&Rev_PMAP#CB071052906115CD57&0#{53f56307-b6bf-11d0-94f2-00a0c91efb8b}.
Kaj bi lahko bil problem?
hvala
Riff ::
kakšne so pa kaj speciifikacije računalnika ? pa za katere windowse gre
  • spremenil: Riff ()
BorutK-73 ::
Rami, preveri Disk z Crystal disk info in prilepi sem SS (ScreenShot)
bluefish ::
Uporabi BlueScreenView, naredi screenshot in prilepi sliko sem.
egypt ::
Ena izmed rešitev je, da se dodeli več pravic inštalirani aplikaciji: https://technet.microsoft.com/en-us/lib...
Oziroma priporočam ogled kakšnega tutoriala kako se to naredi: -> ni najboljši video, sam je za start.
and APPID
-> iz teh IDjev dobiš info za katero aplikacijo gre oziroma kakšne vrste problem rešuješ. Lahko da samo javlja ta error za firefox (značilno za win10).
znamovsi ::
zanima me še, če je treba naložiti driverje za grafiko?
sedaj imam vse posodobljeno vendar nevem kaj naj naložim, da bo prav
imam namreč amd a8 7410+r5 integrirano ter še r7 360m, prav tako AMD
mi kdo pošlje link? trenutno sem na microsoft driverjih, ker mi delajo še najbolje vendar naj ne bi bilo zanesljivo
aja pa moja integrirana mi požre o,5gb rama od 4Gb tako da imam samo 3.5gb prostega
  • spremenilo: znamovsi ()
Riff ::
znamovsi ::
za r5 ki je v procu pa ne rabim softwara?
Riff ::
potem pa še tole: http://support.amd.com/en-us/download/a... za proc + R5
znamovsi ::
sem naložil pred 1 dnevom popolnoma isto in mi je nagajalo
Riff ::
kaj pa če probaš malo starejše gonilnik, ker včasih najnovejši niso vedno najboljši tako pri AMD ju ali nvidi se zgodi slaba verzija gonilnikov
znamovsi ::
sem šel na hpjevo stran in downloadal driverje
ju3 povem le delajo
znamovsi ::
evo sem že 5x naložil driverje, še vedno isto
ko prižgem pc z novimi driverji mi začne slika oz. windows utripat, nič ne morem odpreti/narediti
kaj sedaj?
garancija ali smeti
znamovsi ::
smeti :)
Riff ::
znamovsi je izjavil:
smeti :)
povej v kero kanto bo šlo da pol jst vzamem :D, a si probal tud kere starejše gonilnike in ne samo najnovejše
znamovsi ::
sem probal vse, nič ne dela
predn vržeš v smeti, poskusi še izklopid dodatno grafiko v igrah.
Riff ::
potem pa mogoče zamenjaj windows, naprimer sm imel od kolega računalnik z HD 5670 in nikakor ne usposobit grafično z najnovejšimi gonilniki vedno po določenem času ni imel veza al na namizju ali v igrah je bil gray ( siv) and black (črn) ali blue screen of death - kar na 1x, ko sm mu pa naložu win 8.1 pro 64 bit se je pa to zmanjšalo na 2 taka skrena na tedn tako da predlagam še druge windowse
znamovsi ::
nič pc bom menjal z frendom pa bo
žal pc podpira le win 10
Seljak ::
iloveboobz je izjavil:
Za kaj že?
Proc: AMD Ryzen 7 9800X3D
GIGABYTE GeForce RTX 5080
Ram: 32GB
Riff ::
si 100% da ne gre gor vsaj win 8.1 ali 7 ka, kva pa je za ena matična notr ??
konspirator ::
Riff je izjavil:
Ne bo povedal.
http://www.tenforums.com/general-suppor... #3 post
https://www.reddit.com/r/techsupport/co...
Odnesi na prvi rač. servis, naj namestijo os na novo in preverijo delovanje.
Težava Blue screen W10
213691 (3308) iloveboobz
Random restart računalnika (strani: 1 2 )
7517992 (16037) Pero_SLO
Random freeze računalnika
162059 (1798) Venoox
Imate rajši Win 7 kot Win 10? Imamo rešitev. (strani: 1 2 3 4 )
Oddelek: Operacijski sistemi
15358956 (49187) Cervantes
Grafična - hardware acceleration
Oddelek: Zvok in slika
242519 (2001) xdejvid
