kako 'obnovit' izgubljeno okno procesa v w2k iz sysTray-a?
Lith ::
žalostno, da mi je program, ki ima več procesov, sam ubil explorer taskbar in s tem tudi okna, ki so bila spodaj desno v systray-u, zdaj jih pa ne morem več odpret, sicer so pa vidni procesi v Taskmanagerju (in njihovi PID), al kaj ko jih lahko samo ubijem, ne pa obnovim - rabim neke vrste restore ?
kdorkoli, prosim pomagajte....
¤ black holes rule; I like the speed, speed kills ¤
BaRtMaN ::
Isto se mi dogaja v WinXP, ko se obesi explorer in ponovno zažene. Izgubim nekatere ikone v systrayu, npr. DU Meter, BitTorrent, mIRC, SetiStash... Procesi še tečejo in so vidni v Task Managerju, a do njih se ne da priti. Sem že večkrat spraševal za rešitev, pa ni pomoči, enkrat sem pa nekje prebral, da se da nekaj postoriti preko run komande.
BaRtMaN ::
Ah, kaj lahko malo googlanja vse prnese ( edini uporaben link):
This behavior is quite normal. Icons in the systray are managed by explorer. When a program wants to add an icon in the systray, it simply calls a Win32 API function to do this. Then the program is only notified for things like clicks, dbl-clicks... If you kill explorer, all his associated memory is lost, and the new explorer process you launch does not know anything about icons that were added in the past, so it simply can't display them and associated programs aren't notified anymore, so it can't display any menu. The only way to recover the icon is to kill the client, and then to relaunch it, so the function will be called again to add the icon.
Lith ::
he he he, sem že sam ugotovil, pa sem se odlogiral in nazaj prijavil, ker pač google ni nič rekel na to....
Highlag ::
It's not a bug it's a feature! :D
CaqKa ::
to da se ti mirc pri tem postopku izgubi je fora mirca... nabavi novejšega.. za winamp je isto veljalo... ko so dali novo verzijo vun je špilalo ok spet vse
BaRtMaN ::
Mam verzijo 6.3, tako da moram pač kr potrpet.
CaqKa ::
sp1?
BaRtMaN ::
Za XPje? Natürlich.
CaqKa ::
zanimivo.. ker meni se vedno pokaže ikonca nazaj.
winampova se ti tudi skriva?
BaRtMaN ::
Uff, ne vem, mam WinAMP Agenta sklopljenga. Da ti povem kompletno stanje: ponavadi mam zagnane eMule, mIRC, SetiStash, PandaAV, DU Meter, KerioFW. Od vseh teh procesov se ikonca pokaže samo za firewall.
Lith ::
zdaj sem nekako ugotovil, kaj rabim in sem našel PS Tray Factory, upam da bo še komu pomagal (jaz sem si nastavil hotkey, ki mi požene potem ta programček, v njem pa potem odkrijem izgubljene ikone/procese)
Kako skriti System tray?
Oddelek: Programska oprema
91612 (1373) Inja
Logitech MouseWare bug (?)
272609 (2205) Swiwer
XPji se ne zaženejo
Oddelek: Operacijski sistemi
313513 (2954) Paramedic
kaj je odprtega...
181314 (1029) para!
Mirc v taskbaru (winxp)
51650 (1550) nsignific
