Forum » Programiranje » MYSQL trim
MYSQL trim
BRBR ::
select term, hex(term) from t
where term like ' %'
" kihavka","206B696861766B61"
" kober","206B6F626572"
update t set term = trim(term)
Tale zadnji sql nima nobenega učinka na zgornja dva recorda, zakaj ?
Vitamin-B ::
Skripta je OK (meni dela).
Morda imas vklopljen safe update
izklop z ukazom > SET SQL_SAFE_UPDATES = 0;
BRBR ::
Ni to.
SHOW VARIABLES LIKE 'sql_safe_updates'
--> OFF
Oboje , tabela in column sta utf8_slovenian_ci ampak to najbrž nima veze.
--> OFF
- spremenil: BRBR ()
BRBR ::
npr, tole ne dela:
update t set term = trim(both ' ' from term)
tole pa dela:
update t set term = trim(both UNHEX(20) from term)
Kakšen komentar ?
tole pa dela:
Kakšen komentar ?
| » | [MariaDB] Kolikokrat se pojavi tekst v tekstu?Oddelek: Programiranje | 1135 (828) | BigWhale |
| » | Zanimiv ...hm... problemOddelek: Programska oprema | 3515 (3010) | poweroff |
| » | MYsql: Error: Incorrect decimal value: '' for column '' at row -1Oddelek: Programiranje | 956 (881) | Vazelin |
| » | Apocalypse Now - the GameOddelek: Igre | 4077 (195) | oo7 |
| » | Kaj za vraga je to RAID?Oddelek: Pomoč in nasveti | 2838 (2503) | krucymucy |
