Forum » Pomoč in nasveti » Malo za duso malo za res :)
T-Mac ::
Pozdravljeni,
danes sem za duso priklopil stari racunalnik:
- Intel Pentium 4, 2400 MHz
- Gigabyte GA-8IPE1000
- 1024 SDRAM
- NVIDIA GeForce FX 5200
- Realtek AL655
- 10GB disk
Pa se hecam, da bi nalozil Win XP preko usb-ja, pa zdaj ne vem, ker ga ne prepozna BIOS ali je sploh mogoce na tej stari kisti tako naloziti windows XP :)
Ima kdo kake izkusnje :)
Hvala
- 1024 SDRAM
- Realtek AL655
- 10GB disk
Hvala
T-Mac ::
Ko sem gledal po BIOS-u se ga ne vidi USB kljucka, ceprau sem delal boot na usb 8Gb na exFAT
Pa ti sploh podpira boot preko USB?
Boš moral kar v FAT16 sformatirat. Dvomim da pozna BIOS exFAT32.
T-Mac ::
Ne vem ce mi podpira, v nastavitvah v BIOS-u imam moznost nastavit Boot Device:
- USB-FDD
- USB-ZIP
- USB CDROM
- USB-HDD
Se kako drugace pogleda? Sem nekaj bral ja, da je nekdo delal boot na usb na FAT16, jaz imam program samo za delat boot na FAT32, FAT, exFAT. Ko sem delal preko tega programa boot na FAT mi je vrglo ven, Je FAT sploh FAT16?
- USB-FDD
- USB-ZIP
- USB CDROM
- USB-HDD
T-Mac ::
Na to sem tudi pomislil, da rabim nek mali usb 1gb ali 2gb, jaz imam 8gb. Cisto za foro da preko usb-ja, drugace pa nimam nobene stvari vec na cd-jih ali dvd-jih zato tudi ta podvig :)
T-Mac ::
Mogoce po teli metodi:
Method 1 - Simple Method to Make a usb Thumb Drive Bootable
By far the easiest way to create a bootable usb thumb drive is to use a program from hp called "HP Drive Key Boot Utility"
Step 1 : Download from HP USB Disk Storage Format Tool - v2.1.8 Download - EXTREME Overclocking and install the program.
Step 2 : Download the windows 98 system files @ Windows 98 System Files Download - EXTREME Overclocking extract the files in to a folder.
Step 3 : Make sure your usb thumb drive is inserted in to your computer and format it with fat32 file system. Now run the HP drive key program.
Step 4 : Make sure the correct usb thumb drive is selected under device, Select fat32 under file system, Tick "Quick Format" box, Tick "Create a DOS startup disk" then click on the three dots in the square on the right and browse to the folder where you extracted the windows 98 system files in step 2. Then click on start and follow the prompts. (All the options you need to take are shown in the picture below.
Now if you put the usb thumb drive in your system and boot to it your system will boot to a windows 98 dos screen which will include a few basic programs such as edit, print, echo. If you want to add more programs search the web for such programs.
Blinder ::
Ma pozabi dej. Se lga775 plosce ne podpirajo bootanja iz usb-ja. Ti pa bi na starejsi 478 bootal iz usb. Good luck with that.
Priskrbiš si DVD pogon pa je problem rešen.
T-Mac ::
Sem malo brskal in videl res da bo stala, ce bom naprej raziskoval :) Ja bom pa preko cd-ja instaliral, ampak poizkusiti ni bil greh :)
OvCa77 ::
Jaz sem na podobno kišto naložu z USB Windows 7
Laptop: Probook 440 G3 | i5-6200U | 12GB DDR3L | SSD Plus 240GB
Desktop: Ryzen 1600X | Gigabyte AX370 K3 | 8GB DDR4 | MX100 256GB
OvCa77 ::
Z Windows 7 DVD/USB toolom
T-Mac ::
Iz CD-ROM-a sem ze nalagal XP-je na to kisto. Danes sem dal nazaj CD-ROM hotel bootati iz CD-ROM-a in nic, testiral na svojem prenosniku in je bootalo normalno. Sedaj pa ne vem, kista prepozna CD-ROM v biosu v windowsih tudi ampak ko kliknem na kisti v windowsih na CD-ROM particijo pokaze 0 bytov. Je mogoce pokvarjen CD-ROM ali ?
T-Mac ::
Ko recimo kliknem eject ga odpre tudi prikazan je v mojem racunalniku ampak ko vstavim cd ni nic kakor da ni notri cd-ja?
T-Mac ::
Nekaj sem bral da bi kupil clean cd in scistil leco da je dostim odpravilo napako ko je recimo nekomu bralo samo dvd-je cd-jev pa ne, kaj pravite?
zee ::
Lahko riskiras en DVD in speces Windows XP instalacijski medij na DVD.
zee
T-Mac ::
Mogoce sem ze malo tezek :) V glavnem zrihtal cd - dvd rom enoto, naredu boot win xp, ko zazenem racunalnik me vprasa press key za boot lepo pritisnem zazene cd rom s cd-jem kjer je boot win xp in namesto da bi zacelo nalagati samo preprosto preskoci racunalnik nalaganje in zacne se nalagati stari sistem win xp? Kaka ideja?
dronyx ::
T-Mac ::
Iz neta sen potegnil win xp bootable iso in z nerotom zapekel sliko. Racunalnik zazna pri zagonu boot cd in isto zapekel na dvd ista zgodba cd dvd rom zalaufa pocaka malo in potem nic... Z istim cd-jem sprobal bootcd z win xp na drugem kompu in je lepo bootalo... Na tej kisti v windowsih trenutnih prikaze sliko na romu in windowse? Cudno res...
T-Mac ::
Ne ni bla tukaj tezava :) Tezava je bla v tipkovnici, presenetlo me je tipkovnica na usb je del prijela tipka enter ali space pa ne zelo zanimivo... Priklopil staro tipkovnico na okrogli vijolcni vstop in je zadeva stekla... Res ni mi jasno zakaj ta fora?
| » | Bootcamp ne pokaže v start-upu (MAC)Oddelek: Pomoč in nasveti | 3007 (2808) | luky |
| » | Windows 7 problem pri nalaganjuOddelek: Operacijski sistemi | 1860 (1732) | Han |
| » | BIOS recovery flash problemOddelek: Pomoč in nasveti | 2061 (1858) | DeeCoy |
| » | trdi disk hitachiOddelek: Strojna oprema | 2524 (2159) | kerrigh |
| » | deinstalacija windowsov xp na notebookuOddelek: Pomoč in nasveti | 1668 (1539) | Imagination |
