Forum » Omrežja in internet » PPTP na Mac OS
PPTP na Mac OS
poweroff ::
Torej, na Mikrotik routerju imam postavljen PPTP VPN strežnik. Firewall je primerno nastavljen, uporabniki tudi. Na PPTP se uspešno povežem tako z Linux, kot tudi z Windows sistemom. Uspešna je bila tudi povezava z Mac-om (Yosemite), zdaj pa bi rad povezal še en starejši Mac prenosnik, na katerem teče OS X 10.9.5 (Mavericks).
Povezava nikakor ni uspešna. Poskusil sem tudi s tistim uporabniškim imenom, ki ga uporabljam na Linux sistemu in se ne poveže. Omrežje ni problem, ker se je Linux iz istega Wi-fi-ja uspešno povezal (z istim uporabniškim imenom in geslom).
/var/log/ppp.log na Macu pravi tole:
Kakšna ideja kaj bi bilo narobe?
Thu Jul 16 18:00:52 2015 : publish_entry SCDSet() failed: Success! Thu Jul 16 18:00:52 2015 : publish_entry SCDSet() failed: Success! Thu Jul 16 18:00:52 2015 : PPTP connecting to server '***' (***)... Thu Jul 16 18:00:52 2015 : PPTP connection established. Thu Jul 16 18:00:52 2015 : PPTP set port-mapping for en0, interface: 4, protocol: 0, privatePort: 0 Thu Jul 16 18:00:52 2015 : using link 0 Thu Jul 16 18:00:52 2015 : Using interface ppp0 Thu Jul 16 18:00:52 2015 : Connect: ppp0 <--> socket[34:17] Thu Jul 16 18:00:52 2015 : sent [LCP ConfReq id=0x1 <asyncmap 0x0> <magic 0x2ecb6d19> <pcomp> <accomp>] Thu Jul 16 18:00:55 2015 : sent [LCP ConfReq id=0x1 <asyncmap 0x0> <magic 0x2ecb6d19> <pcomp> <accomp>] Thu Jul 16 18:00:56 2015 : PPTP port-mapping for en0, interfaceIndex: 0, Protocol: None, Private Port: 0, Public Address: 0, Public Port: 0, TTL: 0. Thu Jul 16 18:00:56 2015 : PPTP port-mapping for en0 inconsistent. is Connected: 1, Previous interface: 4, Current interface 0 Thu Jul 16 18:00:58 2015 : sent [LCP ConfReq id=0x1 <asyncmap 0x0> <magic 0x2ecb6d19> <pcomp> <accomp>] Thu Jul 16 18:01:01 2015 : sent [LCP ConfReq id=0x1 <asyncmap 0x0> <magic 0x2ecb6d19> <pcomp> <accomp>] Thu Jul 16 18:01:04 2015 : sent [LCP ConfReq id=0x1 <asyncmap 0x0> <magic 0x2ecb6d19> <pcomp> <accomp>] Thu Jul 16 18:01:07 2015 : sent [LCP ConfReq id=0x1 <asyncmap 0x0> <magic 0x2ecb6d19> <pcomp> <accomp>] Thu Jul 16 18:01:10 2015 : sent [LCP ConfReq id=0x1 <asyncmap 0x0> <magic 0x2ecb6d19> <pcomp> <accomp>] Thu Jul 16 18:01:13 2015 : sent [LCP ConfReq id=0x1 <asyncmap 0x0> <magic 0x2ecb6d19> <pcomp> <accomp>] Thu Jul 16 18:01:16 2015 : sent [LCP ConfReq id=0x1 <asyncmap 0x0> <magic 0x2ecb6d19> <pcomp> <accomp>] Thu Jul 16 18:01:19 2015 : sent [LCP ConfReq id=0x1 <asyncmap 0x0> <magic 0x2ecb6d19> <pcomp> <accomp>] Thu Jul 16 18:01:22 2015 : LCP: timeout sending Config-Requests Thu Jul 16 18:01:22 2015 : Connection terminated. Thu Jul 16 18:01:22 2015 : PPTP disconnecting... Thu Jul 16 18:01:22 2015 : PPTP clearing port-mapping for en0 Thu Jul 16 18:01:22 2015 : PPTP disconnected
sudo poweroff
poweroff ::
Tule piše, da je morda problem povezan specifično z Maverickom (Mac OSX LCP/PPP doesn't support MD5 authentication): https://superuser.com/questions/335169/...
Možen problem bi bil še: "Check if the Lion client LAN subnet isn't the same as the remote PPTP server" - sem preveril in je drugi IP range.
Na Mikrotiku imam v PPP, Profiles, default-encryption nastavljen local address in remote address, Change TCP MSS = yes, ostalo je neaktivno
Pod protocols pa:
- use MPLS: default
- use compression: default
- use VJ compression: default
- use encryption: yes
Pod protocols pa:
- use MPLS: default
sudo poweroff
noraguta ::
Aj to arhaicna tema al dons res se kdo postavlja pptp?
poweroff ::
Tole sicer ni tema vprašanja, ampak zaradi zahtev določenih uporabnikov imam tudi PPTP. Drugače prisegam na varnostno ojačan OpenVPN. Back to topic, pls.
sudo poweroff
poweroff ::
V bistvu je bil čisto normalen, pač pisalo je connection establoshed from x.x.x.x, pa potem par firewall info logov.
Rešitev je bila pa preprosta: Mac OS mašinp je bilo treba rebootat.
Se pravi zdaj uradno vemo, da je Mac OS eden bolj shitty OS-ov!
sudo poweroff
poweroff ::
Ja, seveda. Apple deluje samo z Applom. Pa še tam so težave. Žal, ali pa na srečo, pa ljudje uporabljajo različne sisteme. Ki morajo biti povezljivi med seboj.
sudo poweroff
l0wc4 ::
Jaz sem imel težave tudi kadar sem se želel povezati na PPTP server, ki je bil narejen na OS X Server. Nekaj časa sem uporabljal DigiTunell program, ki so pa ga nehali razvijati, nato pa sem prešaltal na L2TP in IPSEC, ki je deloval brez težav. Vem da z odgovorom nisem pomagal, morda samo v razmislek. Sedaj pa imam raje OpenVPN in Viscosity Client na OS X.
LP,D.
LP,D.
poweroff ::
Ja, z L2TP je stvar taka, da dela samo z Maci (Mac client na Mac strežnik). Ostali (zlasti telefoni) imajo težave.
OpenVPN je sicer moja primarna izbira, ampak na žalost ni podprt na klinčevem Berryu. BB podpira samo kao "enterprise grade" VPN rešitve...
sudo poweroff
| ! | Postavitev Apache serverja s podporo za PHP in MySQL (strani: 1 2 3 4 5 6 7 )Oddelek: Izdelava spletišč | 275656 (19557) | miko22 |
| » | OpenWRT in OpenVPN (strani: 1 2 )Oddelek: Omrežja in internet | 13068 (10928) | BivšiUser2 |
| » | Brskanje v tujini z domačim IP-jemOddelek: Omrežja in internet | 3084 (2373) | MrStein |
| » | PPTP + kernel 2.6Oddelek: Operacijski sistemi | 1781 (1704) | MUC |
| » | mircOddelek: Omrežja in internet | 1918 (1562) | perci |
