PPTP + kernel 2.6
PPTP + kernel 2.6
mile ::
Iama sledeč problem...
S kernelom 2.4.20 sem imel delujočo VPN povezavo do firme... Z upgrade-om kernela na 2.6.0 test 11 pa mi zadeva ne deluje več...
Uporabljam kernel 2.6.0 test11 s tem patchom
http://www.polbox.com/h/hs001/linux-2.6.0-mppe-mppc-0.98.patch.gz
pppd je verzija
http://www.polbox.com/h/hs001/ppp-2.4.2-cvs20030715.tar.gz
s tem patchom
http://www.polbox.com/h/hs001/ppp-2.4.2-mppe-mppc-0.82.patch.gz
Nastavitve za pppd zgledajo tako
noauth
lock
nobsdcomp
nodeflate
mppe required
mppe stateless
mtu 1000
mru 1000
debug
dump
logfd 2
nodetach
lcp-echo-failure 10
lcp-echo-interval 10
pptp (zadnja verzija 1.3.1) pa mi izpljune sledece zadeve
rcvd [IPCP ConfRej id=0x1 compress VJ 0f 01>]
sent [IPCP ConfReq id=0x2 addr 10.0.0.2>]
rcvd [CCP ConfNak id=0x1 mppe -H -M -S -L -D -C>]
sent [CCP ConfReq id=0x2]
rcvd [CCP ConfReq id=0x5 mppe +H -M +S -L -D +C>]
sent [CCP ConfNak id=0x5 mppe +H +M +S +L -D +C>]
rcvd [IPCP ConfAck id=0x2 addr 10.0.0.2>]
local IP address 10.0.0.2
remote IP address xxx.77.147.92
Script /etc/ppp/ip-up started (pid 6136)
Script ?? finished (pid 6127), status = 0x0
Script /etc/ppp/ip-up finished (pid 6136), status = 0x0
rcvd [CCP ConfNak id=0x2 mppe -H -M -S -L -D -C>]
sent [CCP ConfReq id=0x3]
rcvd [CCP ConfReq id=0x6 mppe +H -M +S -L -D +C>]
sent [CCP ConfNak id=0x6 mppe +H +M +S +L -D +C>]
rcvd [CCP ConfNak id=0x3 mppe -H -M -S -L -D -C>]
sent [CCP ConfReq id=0x4]
rcvd [CCP ConfReq id=0x7 mppe +H -M +S -L -D +C>]
sent [CCP ConfNak id=0x7 mppe +H +M +S +L -D +C>]
rcvd [CCP ConfNak id=0x4 mppe -H -M -S -L -D -C>]
sent [CCP ConfReq id=0x5]
rcvd [CCP ConfReq id=0x8 mppe +H -M +S -L -D +C>]
sent [CCP ConfNak id=0x8 mppe +H +M +S +L -D +C>]
rcvd [CCP ConfNak id=0x5 mppe -H -M -S -L -D -C>]
sent [CCP ConfReq id=0x6]
rcvd [CCP ConfReq id=0x9 mppe +H -M +S -L -D +C>]
sent [CCP ConfRej id=0x9 mppe +H +M +S +L -D +C>]
rcvd [CCP ConfNak id=0x6 mppe -H -M -S -L -D -C>]
sent [CCP ConfReq id=0x7]
rcvd [CCP ConfNak id=0x7 mppe -H -M -S -L -D -C>]
sent [CCP ConfReq id=0x8]
rcvd [CCP ConfNak id=0x8 mppe -H -M -S -L -D -C>]
sent [CCP ConfReq id=0x9]
rcvd [CCP ConfNak id=0x9 mppe -H -M -S -L -D -C>]
sent [CCP ConfReq id=0xa]
rcvd [CCP ConfNak id=0xa mppe -H -M -S -L -D -C>]
sent [CCP ConfReq id=0xb]
rcvd [LCP TermReq id=0xa 0a 44 5c 48 00 3c cd 74 00 00 02 e6]
LCP terminated by peer (^JD\H^@ M-Mt^@^@^BM-f)
Script /etc/ppp/ip-down started (pid 6138)
sent [LCP TermAck id=0xa]
Script /etc/ppp/ip-down finished (pid 6138), status = 0x0
Connection terminated.
Connect time 0.1 minutes.
Sent 140 bytes, received 190 bytes.
Ima kdo kaksno idejo?
Gandalfar ::
Glede na to, da je vse skupaj development se ti pomojem najbolj splaca vprasat na pppt-devel mailing listi.
mile ::
bom probal ja, ne vidim druge moznosti :)
MUC ::
Probej it pod VPN povezavo v winsih pa ne mej odklukan, da client prekine povezavo, če ne najde pravega data encryptiona
mile ::
MUC: In kaj je smisu tega?
MUC ::
Tapru povej, če ti dela zdej? Smisu.. sej piše kaj to pomen :))
mile ::
v winsih mi ze dela (nima veze ta opcija pri meni, sej se znata zment glede protokola), problem je linux...
MUC ::
Jah, po pa 0 če ne probaš, pa ni vse v linuxu, ker če linux ni čist dobr naštiman alpa kkšn patch ne dela dobr, se mu tko pomaga.
kraja identitete email naslov
142581 (1879) zmaugy
PPTP na Mac OS
Oddelek: Omrežja in internet
91778 (1400) poweroff
TPLink TL-MR3020
174617 (3436) Jao13
SIOL TV dela samo 5 minut (IGMP snooping)
113132 (2868) bulekk
net in gentoo
Oddelek: Operacijski sistemi
121916 (1782) Poldi112
