Forum » Omrežja in internet » Router brickan?
Router brickan?
PurplePapet ::
Imam TP-Link WR741ND, ki sem ga hotel posodobiti, vse je šlo vredu dokler niso na routerju začele lučke utripati takole: Sem že probal hard reset in ne gre, verjetno je z routerjem konec?
PurplePapet ::
Restoring bricked router ?
If you brick router while flashing firmware, you will need to open your tp-link router (TL-WR741ND)
Serial connection
The router can be connected to the computer serial cable using a serial cable.
Connection can be established with the following settings on GNU/Linux or OS X:
cu --parity=none -s 115200 -l /dev/(your serial device)
In case of issue, try
sudo chmod 777 /dev/(your serial device)
TFTP
The router can be upgraded/fixed with a TFTP method, although its use should be avoided if possible. A working serial cable is required.
Steps:
prepare your tftp tools
get firmware from nodewatcher
connect to the serial interface
expect Autobooting in 1 seconds write tpl within a second
set ip of the router and computer (has to have a static IP)
setenv ipaddr 192.168.1.1
setenv serverip 192.168.1.100
start tftp server on your computer and include the desired firmware in its path
run the following commands
ar7240> tftpboot 0x80000000 yourRightTPlinkFirmware.bin
ar7240> erase 0x9f020000 +0x3c0000
ar7240> cp.b 0x80000000 0x9f020000 0x3c0000
ar7240> bootm 0x9f020000
router will reboot and start with the new firmware
Sem že gledal, pa nimam pojma kaj morm narest, kaj je serial port...
Jakka ::
Če ne veš niti kaj je serijski port, se ne ukvarjaj z njim. Šola, ki stane 20€. Pač ne delaš stvari, če ne več točno kaj počneš.
Je pa brickan in rešljiv. Rabiš le ustrezen serijski kabel in nekoga, ki ve kaj počne. :)
jocko ::
če si bolj tehničen tip, lahko preko ebaya nabaviš poceni USB to TTL konverter (LINK) in probaš rešit ruter
zgubit nimaš kaj
broken/link ::
če nima pojma kaj narest, če nima pojma kaj je serial port, in če mu ni niti toliko v interesu, da bi ključne besede v google vrgu in si mal prebral o tem, potem močno dvomim, da bo šel naročevat konverter in se igračkal z brickanim routerjem :)
markk1 ::
Bom uporabil tole temo. Pri nadgardnji linksysa wrt54gl mi je ocitno zablokiralo vse skupaj in ne morem dostopati do spletnega vmesnika. Zakaj ne naredim 30/30/30, tipka reset ne prime. Je pa ena zanimivost internet mi deluje. Povezem se lahko vanj preko ssh-ja. A obstaja kaksna resitev?
Hvala
Hvala
GTX970 ::
http://www.dd-wrt.com/wiki/index.php/Re...
tftp, če dela.
tftp, če dela.
- spremenilo: GTX970 ()
Spc ::
Hvala
Zbriši NVRAM preko ssh-ja ?
Ali pa update-aj firmware preko TFPTja / sshja.
- spremenil: Spc ()
markk1 ::
Hvala
Spc tega se nikdar nisem brisal imas kak nasvet kako in kaj.
tftp pa sem enkrat dolgo nazaj ze delal, sedaj pa mi nekako ne gre oz nek del postoka ne nardim pravilno.
Spc ::
telnet 192.168.1.1
username: root
password: admin
nvram erase
reboot
http://www.dd-wrt.com/phpBB2/viewtopic....
username: root
password: admin
nvram erase
reboot
markk1 ::
preko ssh-ja sem se povezal pa zbrisal nvram. vendar še vedno mi ne deluje web vmesnik.
TFTP še edina opcija če mi uspe, samo kot že napisal eno zadevo ne naredim pravilno.
amacar ::
Bom kr v to temo napisal. Na routerju wdr3600 imam gargoyle. Danes se je iz neznanega razloga odlocil, da ne bo vec deloval. Wifi je kao ugasnjen, preko kabla mi ne pokaze web vmesnika. Ce ga dam v flashing mode se javi na komando telnet 192.168.1.1, poskusil sem s failboot, ter nastaviti nov password, a mi potem putty pri ssh 192.168.1.1, port 22 javi, connection timed out. Kaj se lahko storim? Aja, naredil sem tudi 30/30/30 reset.
Preko telneta naredil sysupgrade, ponovno deluje.
- spremenil: amacar ()
AštiriL ::
možno je. če ethernet dela...
naloži telnet za command prompt... nastavi svoj local ip na 192.168.1.66, subnet mask na 255.255.255.0
prižgi ruter in preden se sys lučka prižge, klikaj qss gumb, dokler ne začne utripat hitreje
poveži ethernet in v cmd napiši:
telnet 192.168.1.1
si v openWRT modu. vpiši
mtd -r erase rootfs_data
da izbrišeš vse user settinge. če to nedela je edina rešitev serijski kabl. imam isti ruter kot ti samo v1.7 in isto zabrickan. kmal se lotim spajkanja... nikol pa serijskega kabla ne priklaplaj direkt v vga ali com ampak preko ttl to usb kabla, ker ima com/vga 12V tisti ruter pa 3.3!
SREČNO!!!!!!!!
telnet 192.168.1.1
SREČNO!!!!!!!!
| » | [Router] Asus WL500g Premium FAQ (strani: 1 2 3 4 … 10 11 12 13 )Oddelek: Omrežja in internet | 89533 (21294) | brez-imenko |
| » | težava z routerjem (TP-LINK tl-wr741nd) (strani: 1 2 )Oddelek: Strojna oprema | 14902 (7641) | AC_DC |
| » | Zabrickan - zafleširan router TP-LINK TL-WR741NDOddelek: Omrežja in internet | 5068 (3348) | markk1 |
| » | Kako popraviti router Linksys WRT160N po neuspešni nadgrandji firwara! NUJNO!Oddelek: Pomoč in nasveti | 3928 (3755) | Padly88 |
| » | dd-wrt in static IPOddelek: Omrežja in internet | 2003 (1920) | roli |
