HDD prenosnik Lenovo
scipascapa ::
kupljen aprila 2013, shodil disk....1tb samsung disk notri, preverim samsung rma, pa javi tole.
Component
The product you identified was sold as a system component. Please contact your place of purchase for service. Seagate sells many drives to direct OEM (Original Equipment Manufacturer) customers. These products are usually configured for the OEMs only, as components for their systems. You must contact your place of purchase for any warranty support on these drives.
If you purchased this unit directly from Seagate, please return to the previous page and verify your Seagate customer number, because the customer number you entered ( ) does not match our records.
kaj ni vseeno minimalna garancija na diske na splošno 2 leti ne glede ali so retail ali oem? nekateri imajo celo 3 letno.
Evolve ::
scipascapa je izjavil:
Component
Ne.
tako kot piše. Garancija velja tako dolgo kot velja garancija prenosnika.
MIHAc27 ::
Tako. Za diske vgrajene v prenosnike, velja pač garancija od prenosnika, in ne za disk posebej.
Če prenosnik ni več v garanciji potem tudi disk ni več.
Geekbuying garancija
456689 (5041) N0t0ri0us
Garancija pri spletnem trgovcu (strani: 1 2 3 )
11518842 (16514) kratos
Nategavščina ???
265133 (3420) amigo_no1
Preveč poceni Apple oprema - nateg?
122891 (2205) premak
Kje kupit Windows XP Pro in koliko stane?
Oddelek: Operacijski sistemi
385358 (4308) bond007
