Half-Life II
Half-Life II
14 / 34
Tilen ::
Ne, pobrskajmo se malo :)
Oblivion ::
nVidia SM 3.0 List Includes H-L 2:
nVidia seems to have made good use of its multimillion dollar investement in securing games. Much of that money has gone into getting games to adopt Shader Model 3.0 and a list, revealed on NVNews and subsequently removed, indicated that quite a few titles will support the controversial SM 3.0.
If this extensive list of titles proves to be correct then ATIs main argument, that it is too early to adopt SM 3.0 and that SM 2.0b is good enough, will no loger be valid. This list however, also puts ATIs choice to unleash the R520 in 2005 with SM 3.0 support into perspective. The Canadians, it seems, plan to use nVidias investment to their advantage.
The plot thickens however as one title is, controversially, included in nVidia's SM 3.0 list: Half-Life 2. It could be that since Valve will release the game in late September and since 3-4 months later ATI will support SM 3.0, the companies have agreed to use it in H-L 2. If that is the case nVidia will get a good 6 month window of being the only company with boards available that fully support Half-Life 2. Unless, of course, SM 3.0 support is released as a patch only after ATI releases its R520 boards. Confused? They probably want you to be, makes choosing a card a more emotional process than it should be.
G-man ::
HALF-LIFE 2 BO GOLD V PONEDELJEK!!!!!!! POST OD GABEA NEWELLA: HL2FALLOUT.COM
PO VSEH TEH LETIH!!!!! KONČNO!!!! >:D >:D >:D >:D >:D >:D >:D >:D >:D >:D
  • spremenil: G-man ()
AtaStrumf ::
He, he, forum je čist zabasan. Komaj sem prišel na prvo stran, ki si jo zlinkal, na zadnjo pa nikakor noče. Folku se je totalno zmešal :D! V trenutku je bilo pozabljeno vse nategovanje, vsaj po prvi strani sodeč. Upam, da bo že naslednji teden na steamu in pol seveda na SN.
Včeraj mi je moja beta po dolgem času, kar naenkrat začela delat-- ko sem inštaliral CS:S in HL1 port je šlo vse v P.M. :D -- kar je bilo ful čudno, zdaj pa vidim, da je očitno nekaj v zraku.
Longinus ::
Baje je fake
Wie sollte es auch anders sein, die Gold-Meldung hat sich als FAKE herausgestellt. Gemäß den Analysen der IP-Adressen im HL2Fallout.com-Forum soll es sich nicht um eine echte Nachricht von Gabe Newell handeln. Anscheinend hat sich ein Hacker in den Account von Gabe Newell eingeloggt und dann diese Meldung geschrieben. Ein Statement von Valve Software wird noch erwartet.
flisko ::
dons mi je uspel potegnat preko steama dol HL2 ,sam mi napiše: a locked copy of Half life 2 is on your computer -igra še ne dela.
AtaStrumf ::
Fool's Gold
Update: After one crazy night of theories, server mayhem and IP tracing, we've finally gotten to the bottom of this mess. In a twist of hilarity, it seems that Gabe Newell had set his account password to 'gaben'. Person x guessed this and made the "going gold on Monday" post which we've heard so much about. The user (who we believe is the same person x) then made this post just minutes ago using Gabe's account:
Maybe he shouldn't have used 'gaben' for his password. Come on Gabe, you could of thought of something better than that
After a quick double-check, it seems that this was exactly what happened. Reminds me of the good old days. For an official response concerning the hoax, see Chris Bokitch's post on Steampowered.
Original Post
After a close scrutiny of Gabe Newell’s account history on the forums, we've come to the conclusion that the gold post is a fake. While we can't be 100% certain at this stage, all indicators point towards someone hacking the forum account. That said, all Gabe's previous posts on these forums are quite legitimate.
We apologize for the confusion and will be investigating further. Theoretically, an IPB forum account should be very difficult to hack. Well, that was the theory at least. We'll keep you updated.
Tr0n ::
CaqKa ::
1 leto zamude?
Zheegec ::
Zadnje čase je veliko "gone gold" novic, uradno je igra menda blizu temu, da gre Gold, datuma izida pa še ni 0:)
Janez Janša, 29.04.2014
Golden eye ::
Nisem vsega bral..... Kdaj izdide zdej HL 2 ???
AtaStrumf ::
99,9%-no enkrat Septembra 2004. Verjetno po 15. kar je čist cool, ker do takrat imam itak še en "izpitek" za opravt.
Mirč ::
100% 1.oktobra:)
mirč:) :)
tx-z ::
mogoče 30.septembra kot naj bi prejšno leto? :)) wii pol pa še gta 8-) (pa šola)
tx-z
Area_51 ::
:)) Vem da je to kdo sigurno že vprašal, ampak bom spet jaz vprašal ker me zanima in tega ne nejdem v prejšnjih postih, mogoče sem povrčno pregledal.
Na kakšnih nstavitvah bom lahko igral Half-Life2:
Moja konfiguracija:
Procesor AMD 1900+
RAM 512 DDR
Zvočna: 5.1
Windowsi: 2000 pro
Grafična: GeForce 4 MX :(
Kakšne bojo lahko približne nastavitve v igrah glede grafike in ali bo lahko igra sploh kako delovala gladko?
Hvala
Area 51
CaqKa ::
igrala bo gladko...
na kakšnih nastavitvah pa se še ne ve ker še igra ni izšla in se še torej ne more vedet kakšne sploh bodo nastavitve
tole vprašanje se mi zdi skorajda tak smešno kot, "kako se bo rešla 5. stopnja"
  • spremenil: CaqKa ()
sharp ::
Izid bo 22. septembra,sej je napisan na zgornji sliki
AtaStrumf ::
Kot sem nekje prebral, je napovedovanje izida HL2 tako popularno in tako natančno, kot napovedovanje vremena :D. Za zdaj je torej izd še uganka. Lahko, da bo res 22.9.2004, lahko pa da je to spet kaka potegavščina. BTW, kdaj naj bi izšel tale PC Gamer, da vidmo a je to res al je hoax?
AtaStrumf ::
Sem šel na stran od koder izvira slika in kot kaže je to že spet mali nategec:
It wasn't an ad for Half-Life 2, it was an ad for issue #105 of PC Powerplay. If you check my first post here the magazine had recieved every indication that they would have a review in #105, subsequent events have rendered that impossible.
The editor's notification went out the day the magazine hit news stands so it isn't some bizzare ploy, it is just part an parcel of a system where lead time from production to deployment is huge.
To tudi razloži, zakaj manjka zgornji del strani, ker če bi bil viden, bi bilo očitno, da gre za reklamo za oceno igre v reviji in ne za reklamo za igro in 22.9. je datum izida te avstralske revije (ni PC Gamer -- zgleda pa ful podobno) ne pa igre. To je to!
Matev ::
baje da izide half-life2 skupaj z duke nukem forever
Tilen ::
forever - never ;) Haha
BaRtMaN ::
Uradnega datuma izzida ni, oz. ta gotovo ni septembra.
Bo pa ta mesec zanimiv, ker pride Rome: Total War, CoD: United Offensive pa še kaj.
AtaStrumf ::
Če ni uradnega datuma izida, pol tudi ne moreš z gotovostjo trditi, da le-ta ni septembra, se ti ne zdi?
BaRtMaN ::
Point there! :D
SleepLess ::
pomoje pa bo veni do konc leta (res je da sem lani mislil isto :8) ), in mislim da bo raztrgal gate dumu. No ce bo vsaj priblizno tak kot pravijo :)
Caligula ::
Ma kaj se vam sploh tok gre za to. Ce bi te spili prhajal takratko naj bi, bi bli se dorbi. Tko so pa s tem ,da po eno leto zamujajo v bistvu lih tolk ,da so za spilat. Bi se jim velik bolj placal pac mal manj se preseravat pa vsaj narest takrat ko naj bi nardil. :|
AtaStrumf ::
To je pa zelo res! Lani bi HL2 100x bolj gate trgal kot jih bo letos. Vmes so izšli Far Cry, Painkiller in Doom 3, ki so večino stvari, ki jih ima HL2 za pokazat že pokazali, samo ne v kombinacijo kot bo pri HL2. Pri tem imam v mislih inteligentne nasprotnike, DX9 vodo, Havoc fiziko, hude pošastke in impresivno oblikovane stopnje. Vse to je bilo lani tak čas neviđeno, zdaj je pa že čist normalno.
Glede izida le še to. V uni reviji, k je bila objavljena una reklama, so mislili, da bojo dobili HL2 za oceniti že za oktobersko številko (105), ki izide 22 sept., a se je po tisku izkazalo, da temu le ne bo tako in da bo HL2 zamudil preveč, da bi ga lahko vključili v izdajo 22 sept. Če računamo, da morajo revijo končati vsaj 1 teden preden jo lahko kopimo, to pomeni, da HL2 do 15 sept. ZELO verjetno ne bo zunaj, po drugi strani bo pa precej verjetno vsaj do 15. oktobra, saj sedaj obljubljajo oceno v 106. številki, ki bo, predvidevam, izšla cca. 22. oktobra.
CaqKa ::
no jaz upam da meni nebo nobenih gat trgalo :)
Matev ::
mah revije samo reklamo zase delajo
v resnic pa ne vejo (ne morejo vedeti) ker še avtorji sami ne vejo kdaj bodo nardil
kar se pa tiče AI nasprotnikov - jo pa obljublajjo že od wolfensteina naprej - pa je nikoli ni bilo - tudi sedaj ne verjamem da bo takšna kot pravijo
AtaStrumf ::
Začel se je 2. del HL2 preload-a. Tokrat so na vrsti zvočne datoteke v skupni velkosti cca. 900 MB. Skupaj je to zdaj že zelo zajetnih 2000 MB. Le tako naprej :D.
Tilen ::
In jaz sem nabavil (z veliko sreče) novo grafo, ki bo sposobna to kulturno poganjat. >:D
Hammer ::
Tilen ::
Vidim da bom moral spet vecinoma igrati podnevi. :(
Najbol sovrazim pajke v vseh spilih in nasplosno grozne posastke ki skacejo v tebe. Like tisti iz Far Cry ko skacejo... grrrrrrrrr.
  • spremenil: Tilen ()
AtaStrumf ::
Headcrabsi :D. To so zakon, sploh niso tolk hudo nadležni, k se jih da fajn z crowbar-om mlatit, čeprav en najhujših šokov v HL1 so bili prav tile vragci, k so v kakšnem prezračevalnem jašku iz teme ven skočil. To so bili časi, ja.
Slikce ne prikazujejo kaj dost novega, vseeno pa je važno da se na sceni nekaj dogaja, da vemo, da niso pozabili na nas.
snajper-slo ::
malo pa je razlike med lanskim in letošnjim filčkom.Za primer kako je v lanskem spotu z crowbar-om les sipu al pa letos.Pa se mi zdi da so tut sence mal bol zrihtal
AtaStrumf ::
Vedno več se nekaj govori o novemberskem izidu :'(. Plis ne mi rečt, da je to res.
Highlag ::
Valjda, da ni res izšel bo za božič. :D
AtaStrumf ::
Ne, ne, definitivno bo pred božičem, edino vprašanje je katerim :D?
Matev ::
potem bi lahko rekli da bo po božiču.... a katerim
ali pa med dvema božičema - katerima
skratka naj povejo ali pa rečejo: takrat kot duke nukem forever
AtaStrumf ::
Good point :D!
pingec ::
a kdo zej ve kdaj bo izšla in ali kupončki ki se jih dobi zraven grafičnih bodo veljali ker sem dal 4k za cd-key s kupončkov?
Normalnost je povprečje nenormalnih ljudi.
AtaStrumf ::
BTW, v petek se je začela tretja faza preloada, tako da je vse skupaj sedaj že cca 2,4 GB materiala :). King, če imaš kuponček začni preloadat, ker si že 3 loade zadaj, ko pa izide boš pa samo aktiviral in igral.
Malo sem razmišljal, zakaj bi šel vALVE v tako blamažo lani, ko igra več kot očitno ni bila nikjer blizu tega, da bi bila končana in sem prišel do hipoteze, da so morda potrebovali eno fajn finančno injekcijo (mogoče je založnik po petih letih postal malo neučakan), ki so jo dobili od ATi-ja v zameno za kupončke, ki so pomagali prodajat nove Radeone. Druge racionalne razlage si skor ne morem spomnit.
Pa še to, če je 15. sept. res dan ko Vivendi dobi RC v roke (k bi se saj poštar zmotil pa dostavil komu z 100 mbit-no linijo :D), je v idealnih pogojih še vedno možno, da do 31. sept. vALVE izda igro preko Steam-a, rajt?
Bevcan ::
King tisti kuponček ni nič drugega kot listek na katerem je napisana koda s katero se potem registriraš. Nikjer ne piše da si ni človek ,ki ti je to prodal tiste kode prepisal in se bo registriral pred tabo. Tako da lahko samo upaš na poštenje.
pingec ::
8-O ja ne vem no koda je še ne spraskana in ne vem kako i jo lahko pogledal?
Bevcan ::
AtaStrumf. LOL 31. september upam da ne ker pol to ne bo nikoli.
BaRtMaN ::
king: če si kupil kuponček je v redu. Prej si napisal tako, kot da si ti kupil samo kodo, prepisano s kupončka.
pingec ::
aja sorry than
Bevcan ::
Aja, no jast pa nism vedu da ma zaščitni premaz ki ga moraš spraskat da vidiš kodo.
AtaStrumf ::
Neowin.net
Valve officials confirm that the long-delayed shooter is thisclose from gold status.
After years of missed launch dates and release mishaps, the Half-Life 2 saga is entering its final chapter. Doug Lombardi, Valve's director of marketing, confirmed to GameSpot today that the release candidate for the game has been sent to its publisher, VU Games, for approval. "Yes, the release candidate went to VUG yesterday," he said.
Word of the submission first came via a forum post from Valve CEO Gabe Newell. "The RC went to VU yesterday," read Newell's one-line post on the hl2fallout.com forums. In light of the recent false postings on the site, shacknews.com confirmed the post's authenticity. "Yes. Getting close," Newell responded.
No vsaj ena napoved glede HL2 se je uresničila. Včeraj sem zloadal tist kao nov HL2 Coast filmček, pa se mi ne zdi ravno nov, pa tudi skor zaspal sem zraven. Damn, kaj se to dogaja, a sem čist zgubil zanimanje al kva :O. Mogoče sem pa že mal prestar for this shit :\. V enmu letu lahk človk kar velik odraste :D.
globoko grlo ::
in kakšne so zdej procedure, a to pomen še kkšn tedn, dva, pa jo bomo že mel
14 / 34
Half Life 3 (strani: 1 2 3 4 5 6 )
Oddelek: Igre
29473801 (1316) Horas
Half Life 3 je zaščitena znamka (strani: 1 2 )
Oddelek: Novice / Igre
5131151 (23052) LordTado
Half-Life 2 Episode Three (strani: 1 2 3 )
Oddelek: Igre
12322873 (14219) tt2
The Orange Box (strani: 1 2 3 4 )
Oddelek: Igre
16819743 (13817) Bor H
half-life2
Oddelek: Igre
282339 (1859) Ahiles
