minecraft in računalnik
FPSGamer ::
Ali se da sestaviti računalnik budget 100-150 evrov, ki bi poganjal Minecraft na minimum nastavitvah?
xxurban ::
Najbrž kaj rabljenega.
Yohan del Sud ::
Dovolil sem si malo poguglat:
A computer with the minimum requirements should be able to play Minecraft. However, for the best experience, please consider the recommended requirements.
Minimum Requirements:
CPU: Intel Pentium D or AMD Athlon 64 (K8) 2.6 GHz
RAM: 2GB
GPU (Integrated): Intel HD Graphics or AMD (formerly ATI) Radeon HD Graphics with OpenGL 2.1
GPU (Discrete): Nvidia GeForce 9600 GT or AMD Radeon HD 2400 with OpenGL 3.1
HDD: At least 200MB for Game Core and Other Files
Java 6 Release 45
Recommended Requirements:
CPU: Intel Core i3 or AMD Athlon II (K10) 2.8 GHz
RAM: 4GB
GPU: GeForce 2xx Series or AMD Radeon HD 5xxx Series (Excluding Integrated Chipsets) with OpenGL 3.3
HDD: 1GB
Latest release of Java 7 from java.com
Software Requirements:
Minecraft Release 1.6 or newer. Older versions will need to be updated to current versions
Please note that some users experience issues playing Minecraft while using a mismatched version of Java for their operating system (32 or 64 bit), while using certain versions of Java 7, or while multiple versions of Java are installed
If you have a laptop with an a built-in (integrated) graphics card, rather than a dedicated card, it is highly suggested that you try the demo before purchase.
A stable internet connection is required for Minecraft to download game files, authenticate usernames, and connect to multiplayer servers. You'll need to download and run Minecraft while connected to the internet at least once; afterwards, you can play without an internet connection, but will need to connect if you'd like to receive updates or play online.
Minecraft will not run on a toaster (despite some actually using Java), your car (feel free to prove us wrong, though), or a Chromebook.
www.strancar.com
Yohan del Sud ::
In za ta denar bi se v malih oglasih tudi kaj našlo. V kakšnem stanju je drug problem.
www.strancar.com
Call of Duty : Modern Warfare [4] (2019) (strani: 1 2 3 4 5 )
Oddelek: Igre
20840627 (2106) ZiedRieke
fifa 18 na starem racunalniku
Oddelek: Igre
62389 (2148) opeter
Igra se ne odziva
152838 (2555) FPSGamer
Menjava grafične kartice
121721 (1609) Isotropic
Igre- štekajo
101130 (1063) Pariah
