Forum » Operacijski sistemi » Win XP SP2
Win XP SP2
jozerus ::
Zdravo,
Na prenosniku imam inštaliran Win XP, ki mi ob zagonu (nomalen zagon) javi napako :Faild to get proc addrss for GetLogicalProcessorInformation(KERNEL32.DLL).
Drugače dela vse ok, sem pa opazil dako hočem zagnat Skype ni namest zagona javi to isto napako. Poskusil sem download Skype pa mi pri inštalaciji spet javi isto napako. Kaj lahko storim ne da bi ponovno nalagal Windowse.
Drugače vse dela bp.
dej povej malo več specsov od računalnika..
Sicer pa, interneti pravijo, da je treba updejtat win na SP3..
- spremenil: iloveboobz ()
sfc /scannow nebo nič pomagal, ker je to problem odsotnosti service packa 3, ne pa curruptanih sistemskih fajlov.
s6c-gEL ::
Lahko da pomaga, če je kernel32.dll poškodovan.
http://blog.vilmatech.com/kernel32-dll-...
Cause of Kernel32.dll Errors
Missing or corrupted Kernel32.dll. A missing or corrupted Kernel32.dll may disable the normal operation of program and application directly. Such as the popular Fatal Kernel32.dl error in Skype: "Failed to get proc address for GetLogicalProcessorInformation (KERNEL32.dll) ".
Invalid or corrupted registry files. Windows registry is kernel database used to store hardware, software settings and options of Microsoft Windows operating system. An important invalid or corrupted registry file can lead to numerous system errors, including Kernel32.dll error.
Outdated Kernel32.dll file. The system files should be updated to the latest ones regularly so that to keep its normal operation. A outdate Kernel32.dll file can cause random errors as well.
Infected Windows files by virus or spyware. Virus or spyware is a primary factor that may generate Kernel32.dll error through infecting vital Windows files.
- spremenilo: s6c-gEL ()
| » | Internet explorer se ugasa - sam od sebe... HELP !Oddelek: Pomoč in nasveti | 2090 (1978) | jarni2 |
| » | Neka napakaOddelek: Pomoč in nasveti | 1402 (1284) | primzx |
| » | kernel32.dllOddelek: Pomoč in nasveti | 1841 (1662) | alf__ |
| » | Odpiranje dat.exe v VBOddelek: Programiranje | 3852 (3645) | webblod |
| » | KERNEL32.DLLOddelek: Pomoč in nasveti | 1338 (1196) | blue96 |
