Forum » Pomoč in nasveti » ko prižgem računalnik se ne prikaže slika
mrbomb ::
Ob vklopu računalnika, se mi na monitorju ne prikaže nič. Probal sem odklopiti trdi disk in cd rom, menjal grafično kartico, kaj bi lahko bilo? Hvala
Aasimar ::
Če piskne, potem je najbrž grafa. Drugače pa matična oz. proc. Preveri tudi PSU ( če ni nobenih lučk oz. se ventilatorji ne vrtijo).
Seljak ::
Če se že razpravlja o piskih potem ni vse,da napišete,če piska,ampak tudi kako zapiska. Obstaja več vrst beep opozoril. Ker se mi ne da pisati sem prilepil nekaj beep errorjev in razlag za kaj je kateri namenjen.
How to recognize the beep errors
Very short beep
This problem is linked to your motherboard. It can also mean that you are facing a problem with your system memory (BIOS AWARD)
Short beep
No problem.
Long beep followed by three sequential short beeps.
This issue is linked to your graphics card configurations.
Short beep followed by three sequential long beeps
You are facing a system memory problem.
Beep, pause, beep, pause, two sequential beeps
This error is linked to your CPU.
Three beeps, pause, three beeps, pause, four beeps
You have an issue with the video memory.
One long beep and nine short
Problem with the ROM (Bios AWARD).
Three beeps, pause, four beeps, pause, beep
This is linked to an error with your graphics card.
Four beeps, pause, three beeps, pause, beep
You have a system memory problem.
Five short beeps
You are facing a problem with your CPU.
Long constant beeps
It's a system memory problem.
Very short beep
Short beep
No problem.
Five short beeps
Long constant beeps
Proc: AMD Ryzen 7 9800X3D
GIGABYTE GeForce RTX 5080
Ram: 32GB
Ram: 32GB
- spremenilo: Seljak ()
Seljak ::
Premalo si opisal svoj sistem,si nazadnje posodabljal gonilnike za grafično kartico,kako star je napajalnik,.....
Ram: 32GB
Ram: 32GB
mrbomb ::
Nič ne piskne niti, verjotno matična nima tega zvočnika za piskanje?. Napajlnik je star, računalnik cel je star okoli 8 let.
FX6300B ::
jaz sem imel podoben problem z matično pa sem kupil novo čez 1 mesec je pa tudi stara začela delovati
če še nisi naredi clear cmos- resetiraj bios
matična res nima tega zvočnika vendar mora imeti pri kabelčkih za gumbe pa usb na ohišju zraven mora biti tudi priklop za speaker (zvočnik) poglej če ima ohišje zvočnik če ga ima ga priklopi če pa ne pa poglej doma če imaš kakega
kot je že rekel benji si premalo opisal sistem povej npr komponente če si kaj posodabljal in čim več napiši da lahko drugi morda lahko vejo točen problem
- spremenil: FX6300B ()
| » | Pri menjavi graficne prislo do problemaOddelek: Pomoč in nasveti | 4325 (3968) | franseliski |
| » | Problem z grafično (strani: 1 2 )Oddelek: Pomoč in nasveti | 8958 (8323) | him |
| » | Računalnik z RAID poljem se noče obuditi v življenjeOddelek: Pomoč in nasveti | 1631 (1565) | ibozic |
| » | porodne težave računalaOddelek: Strojna oprema | 2281 (1824) | dustphoenix |
| » | BEEEEP...BEEEEP...BEEEEP ????Oddelek: Pomoč in nasveti | 2858 (2453) | prestopnik |
